Question about Kitchen Appliances - Others
My oven won't preheat past 280. I notices a flicker in one of the small openings in bottom where the bottom element is, it was a flame or a sparking so I turned my oven off.
When it was cool I started it again, but it won't preheat past 280. any ideas what could be wrong.
  • 6 Answers
SOURCE: Hotpoint - RB525 H3WH Oven shuts off past 250 degrees
bad temp. probe
Posted on Feb 06, 2009
farfield
  • 462 Answers
SOURCE: my broiler element wont cool down after starting
It may have a grounded element. If the flame came from the element do not touch it! The only way these elements flare up is if they coma apart. The element could be going to ground from the outer case and it would feed power from the ungrounded end. turn off power and remove element. look for wire grounded too.
Posted on Mar 27, 2009
jumptrout51
  • 3361 Answers
SOURCE: Baking Element Caught fire
Elements wear out from the inside. Sooner or later it happens to all of them.
Posted on Apr 01, 2009
SOURCE: bottom element doesnt work in oven, but top does.
NOPE!
  1. Broil element does not have welded-on legs and will touch the bottom of oven, overheating itself and will end up the same way your bake element did; besides, the bottom of the oven will corrode pretty quick
  2. Many ovens use both elements during bake cycle
  3. self clean cycle uses broil element
  4. The bake and broil elements typically have different mounting brackets and screw holes ate in different places
  5. you'd have to cover the hole, left after removing the broil element, and insulate the wires, which went to broil element
  6. the ends, protruding behind the mounting bracket may have different length and different connectors. you may end up shorting the wiring to the casing, which may in turn destroy the control board if there is one
  7. Bake elements usually cost only $40-$60. No jury rigging required.
Hope this helps ;)
Posted on Mar 29, 2010
Daniel S
  • 4323 Answers
SOURCE: Hello: We have a Thermador SC302TS double oven.
Hi
The issue can either be a bad electronic control/clock assembly or the oven temperature sensor (probe) has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control and door switch and replace the part that is bad. Hope this helps...
Daniel
Posted on Jan 02, 2011
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    Gas oven takes 30 mins or more to to preheat
    Open the bottom and have a look at the burner while its heating. The flame should be strong blue/white and both sides the same, if they are not you have some blocked holes in the burner. Remove the burner and clean out the holes (carefully, don\'t ream them out, use a small paperclip to clean them, be gentle.). Above all do NOT use any kind of oven cleaner on them, if they are aluminum, and most are the oven cleaner will destry it.
    Jul 29, 2014 | Kenmore Ovens
    How do I replace the bottom oven element on my Maytag CWE5800?
    This shouldn't be too difficult. Make sure the power is off. Remove the screws that hold the oven element in place. carefully pull the element out from the back wall without losing the wires back in the holes. Install the wire on the new element push it back in the wall. Reinstall the screws and you are set. Turn the power back on and check to make sure the oven cycles when it reaches the set temperature.
    Feb 08, 2014 | Maytag Ovens
    Maytag Oven won't work
    either you element is bad or the relay on your control will not open , if able check voltage to element and inspect element for defect .
    Feb 20, 2013 | Maytag Kitchen Ranges
    Gas oven is slow to ignite & preheat
    What kind of range? Taking that long to ignite and small flame. Sounds like both weak ignitor and safety valve is not opening.
    Jan 14, 2013 | Kitchen Ranges
    Kenmore oven won't heat up
    Sounds like it is dangerous. Get a gas engineer to repair it.
    Oct 15, 2017 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
    How to change the lower element on a delonghi AD 699 toaster oven?
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    Oven appears to start, takes forever to preheat,
    This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
    Feb 26, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
    Kitchen Appliances - Others Logo
    57 people viewed this question
    Top Kitchen Appliances - Others Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
