Sun quest pro 16e 2 bulbs in lower unit not lighting, changed bulbs still not lighting
How to take lower unit apart to check ballasts
techman
  • 3130 Answers
SOURCE: no picture, sounds fine. Fuse blown
This set, I am sorry to say has no bulb and has no ballast circuit. There are three picture tubes inside this TV set. What exactly was the part you pulled out? Can you post a picture of the Part you pulled out?
Posted on Jul 29, 2007
projdoc
  • 2237 Answers
SOURCE: flourescant lights flickering
is there a ballast or a starter? if there is a starter (little silver metal or white plastic can), then replace the transformer inside the lamp housing. if there is a ballast (long black rectangle with many wires) and you replaced that and the lamp, then there must be a power drain in the unit somewhere.
Posted on Aug 26, 2009
  • 30 Answers
SOURCE: two different size ultraviolet ballast. The .71AMP
I usually test the ballast simply by excluding everything else.
1) Put in bulb that you know works
2) Replace starter (if you have one)
3) check that wiring is intact (sounds like it is for you but I had one light that the wiring barely made contact so sometimes it came on and sometimes it blinked)
4) If all that is good, then it's probably the ballast.
Posted on Sep 30, 2009
Jahn27
  • 1554 Answers
SOURCE: I bought 2 ICN-2P32-N for
Here's the wiring diagram for each ballast with two lamps.
ICN-2P32-N @ 120V
Posted on Jan 30, 2011
  • 4 Answers
SOURCE: I have a 04 acura
Be sure to check the ground side conn.
Posted on Jul 16, 2011
Plugged in to 220 volts now it plugged into 120 volts. I replaced all bulbs with new ones still won't come on. What is next?
Hello Jerry
your post was answered in your other post. Please only post once so that all the answers are in one place.
There is more to it that just the bulbs. You have blown all the chokes/ballasts that supply the power to the tubes. Nothing is going to survive twice the recommended voltage.I found this from an old Fixya posting.
You probably have T8 ballasts controlling your lights which are electronic. Its pretty much a sure bet that these are fried and will need to be replaced. Open up the tray that is between the bulbs and write down the F32T8x? Number that is on the front of the ballast. The ? Will be the number of bulbs it is designed to run. As long as the number matches up you can just cut the old ballast out and it wire the new one in. Ballasts generally run ~ $20 a piece. Hope this helps!
You realise these tanning beds are bad for you? Get out in the sun with a good quality sunscreen.
May 02, 2015 | Wolff Sunquest Pro 16SE Limited Edition...
I pluged this into a 240 volt supply and all of the lights went out. I bought new bulbs still will not come on after I switched it over to 120 volts. What is going on please?
I have a Sunquest Pro 24S four upper bulbs went out together. I changed bulbs and starters. What else can it be?
Assuming the ballasts are good, Do a continuity check on the tombstones. If one stab wire arcs out, it could daisy chain down several bulbs. You can also wiggle the wires at the tombstones and see if the bulbs light up. If you replace tombstones, be sure to select the same style shunted or unshunted (electronic ballasts will be shunted).
Aug 11, 2014 | Home
My ballast making a humming noise but will not light up my 600w hps bulb?? small bit of purple light in the bulb when turned on but not lighting up?? tried a 400w bulb in hood with the 6oow ballast and...
NANOLUX BALLAST 400W-1000W
NANOLUX HPS and MH electronic ballasts can be light up
E-MAIL :cly@sznumber.com
Skype:sznumberballast
May 18, 2013 | Sunlight Supply 400 Watt Hps Sunsystem I...
Sunquest pro 16 se
You may have a wire burned out going to that set of ballasts/bulbs. Have a trained technician to check and repair this.
Feb 08, 2013 | Wolff Sunquest Pro 24RS 220 Volts
One of my two hps bulbs is brighter than the other one the bulbs and one of the ballast are new the other ballast is a year old
Hi .. it could be the ballast .. an easy thing to do to troubleshoot this would be to swap the lamps. If the problem follows the lamp. then that is the problem. If the pronblem stays with the fixture, then I would replace the ballast in that fixture.
May 03, 2010 | Sun System 600 Hps Cool Grow Light System...
Hello...need help.. replaced 600mh bulb then
Have you tried the switch yet? The plastic switches inside some ballast boxes don't do well with the heat produced by the ballast. You can try to simply bypass the switch and hard wire the ballast to the plug to test whether or not that might be your issue. If you need a new switch, just call Sunlight Supply directly http://www.sunlightsupply.com/hort/contact.aspx they should be able to send you a replacement switch.
Feb 18, 2009 | Sunlight Supply 400 Watt Hps Sunsystem I...
Under cabinet light not working
probably not defective bulbs. Flourescents use either a starter and transformer or a ballast. When lights are weak, could be either. Very simple to change too. One other thing, could be connections that go into the lamp holders. If not good connections, light will be dim. On a stretch, if unit is located in an area that us lower than about 50 degrees, this could cause them to be dim. Check ratings on ballast/ starter and transformer. Finally, if voltage is either too high or too low, this could be a dimming problem too. If it has worked in the past, and this is a current problem, then chances are it's not the voltage but may want to check it anyway to eliminate that possibility.
Feb 05, 2009 | Jenn-Air Attrezzi JSM900 Stand Mixer
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
