Question about Janome Sewing Machines
The top tread breaks after about 1inch when trying to do chain stich on my janome cover stich machine
  • Janome Master
  • 11,493 Answers
Could be the result of several things. There could be some gunk or threads stuck in the tension disk. Be sure to remove the thread and rethread from the beginning in the order specified. ALWAYS RAISE the presser foot when threading!!!! If you haven't tried a brand new needle, do so, and make sure it is pushed all the way up and installed with the flat side facing the correct direction. Some machines recommend #90 as the largest needle to use. Also, perhaps the needle eye is too small to accommodate the thread. Watch where the thread is breaking to give you an idea of where the problem may originate. Try a different brand of thread. Sometimes black thread causes issues because the heavy dye affects the thread. Set the tensions at the midway point and then loosen the tension on that one needle. There could also be a burr or rough spot somewhere along the threadpath that is catching the thread. Last idea--could be a timing issue.
Serger needle thread breaking sewing discussion topic PatternReview com
Make It Handmade Threading Your Serger or Overlocker
Help please Serger needle thread breaking
Sewing Machine Thread Keeps Breaking
Posted on Dec 08, 2016
How do I stop my tread from popping on my Brother (17 stich) sewing machine?
Breaking thread? Presumably the top thread? AVOID old or bargain bin threads. The upper tension is too tight or the thread is not properly seated in the tension disk, the needle is defective or the needle, needle eye/scarf is not the best choice for the fabric/thread being used, there may be a snag in the bobbin area that is catching the thread. Make sure the thread is not catching on the spool's thread notch.
Why Does My Thread Keep Breaking While Sew
Sewing Machine Problem 1 Thread Breakage
Why is my thread breaking
Dec 07, 2016 | Brother Sewing Machines
On my janome sewing machine the stich ed keep getting bigger to the point that it does hold material together cos the thread cab pull out completely Can u help
Your question isn't totally clear but I'll try to explain the most likely problem:
Adjust the bobbin case tension. (guide attached)
Start the top tension at four. Make adjustments as needed.
Aug 24, 2015 | Janome Sewing Machines
How to adjust tension janome 4400
Before you go changing settings... make sure you are stabilizing the fabric correctly. Towels especially requires a stabilizer on top AND on bottom.
Dec 06, 2012 | Janome MC 4400 Computerized Sewing Machine
Tread breakage snd stich skipping
(A)Put in a new needle and rethread from the beginning. Make sure the take-up hook is threaded. Also, (B) clean lint out - sewing machines have very small margin for error when lint pushes everything out of alignment. Mostly, it sounds like your thread is stuck somewhere, which can even be at the spool, so (A).
Apr 06, 2010 | Juki DDL-8700
Machine is threadedand makes the serger chain for
My janome 634D driving me crazy . I have tread it properly and it wont stitch ?
Nov 06, 2009 | Janome MyLock 634D Mechanical Sewing...
My bobbin wont feed through
take the bobbin out check for debris (pieces of thread, lint, etc.) that may be jamming the bobbin. check under the feed plate for a thread jam or debris. check if your bobbin is wound too tightly. it can happen! then it will keep breaking. the other adjustments are mainly for thread tension- the spool on top. if they're too tight, the thread will keep breaking. you can tell- once they're properly adjusted- by the quality of the stitch. check the bobbin first! if it's too tightly wound, you can probably adjust the winding tension on top. try a different bobbin. if that works then 'rinse and repeat!'.
good luck!
Sep 24, 2009 | White Sewing 1418 Mechanical Sewing...
Skips stiches and breaks the tread
this sounds like the thread tension is to tight.this will cause it to skip stitches and break the thread
Jun 07, 2009 | Sewing Machines
Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Apr 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
42 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
