Question about PRINTER Office Equipment & Supplies
How to get to print head clean maintenance on printer
Mix-it-up
  • 832 Answers
SOURCE: printer trouble
read my answer here:
http://www.fixya.com/support/t247395-brother_dcp_110c_error_51
Posted on Nov 30, 2007
Soulvisitor
  • 1113 Answers
SOURCE: brother 420
error 51 = The purge cam switch does not come ON or OFF even after the purge cam has been driven by the specified number of pulses.
Fix is
Switching arm assembly not engaged correctly If the switching arm does not move smoothly, clean it.
Ink cartridge/purge switch harness not connected correctly
Correct the connection.
Purge cam switch broken Replace the purge cam switch.
Gear(s) on the maintenance unit broken Replace the maintenance unit.
Paper feed motor broken Replace the paper feed motor.
Main PCB defective. Replace the main PCB.
Cleaning of these print heads rarely if ever is successfull, they are electronic devices unlike other brands of printers
Posted on Dec 04, 2007
SOURCE: epson 830 u
go to admin tools, then services, scroll down (in services) to print spooler. click stop the service (lh side) when that has done click start the service.
what this does is basically resets the printer memory.
good luck.
Posted on Jan 28, 2008
SOURCE: Brother MFC-210C won't print
I have cleaned, retested and new ink and it still will not print Black
Posted on Jul 31, 2009
Benimur
  • 6966 Answers
SOURCE: It is saying that the print head cannot be cleaned
Hi and welcome to FixYa,
A possible workaround is to use "Deep Cleaning" feature of a 3rd party utility program. Please check for model compatibility and if workable, download, install and run "SSC Service Utility". Additionally, there special cartridges that contain cleaning solution rather than ink that maybe used in this process.
Good luck and thank you for asking FixYa.
Posted on Aug 15, 2009
Pixma mp210 how to manually clean print heads
see manual for maintenance tools in cleaning print heads or maintenance tab in printers and devices for head cleaning. dont do it manually. you might damage the cartridge
Aug 12, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
Tip
How to clean the printer heads
When it comes to printer issues, there are few things as frustrating as expecting a clearly-printed document and ending up with something that looks like a cross between a Picasso and a Rorschadt blot. If you notice that the print quality of your documents has decreased considerably or if you are bringing an old inkjet out of retirement, you need to clean the print head to ensure you?re getting the best from your printer. A dirty or clogged print head will hinder a regular flow of ink from the ink cartridge to paper. The first step is actually knowing where the print head is and what it does. As you print a document, ink droplets leave the ink cartridge through the cartridge?s nozzle and go to the print head. The print head then lays the ink on a precise point on the paper. As you print, tiny droplets of ink can get stuck around the print head opening. If these drops get time to dry, they can form a crust around the print head opening and cause it to print poorly. Clean It With Software There are a few ways to go about cleaning the print head. Potentially, the easiest way is to let your printer clean itself. Many inkjet printers will have maintenance options in the printer?s software that will actually clean your printer for you. We used a streaky Canon BJC-80 for our testing, and the driver we installed on our system for this inkjet had quite a few maintenance options. (Keep in mind that the process for cleaning your specific printer?s print head may be slightly different than what we?re describing here.) To check these out in Windows XP, click Start and then Printers And Faxes. Right-click your printer and then Printing Preferences. This displays the Canon Bubble-Jet BJC-80 Printing Preferences dialog box, which houses various layout and print-quality preferences, as well as the printer?s maintenance options. Click the Maintenance tab to view what your printer can do from a software perspective. Our printer has two cleaning modes?Cleaning and Deep Cleaning. Cleaning isn?t quite as time-consuming as the Deep Cleaning mode, but Deep Cleaning mode does a more thorough job and can resolve some issues that the normal Cleaning mode can?t. Just click the proper cleaning mode to start it and let the cleaning process run its course. You may have to do this a number of times to get the print head clean. If you don?t see a maintenance tab, it doesn?t necessarily mean your printer doesn?t have a self-cleaning function; it just means that it doesn?t use commands from your computer to do it. For instance, on the BJC-80 you can also start the cleaning process by holding down the Resume button until you hear two beeps. Check your printer?s manual for ways to clean your print head. Clean It Yourself Some software bundles that come with printers have cleaning functions that you can use to clean your print head. If the built-in cleaning functions don?t seem to do the job, there are a few ways to clean your print head manually. Some swear by isopropyl alcohol, while others believe in just plain ol? water. When used correctly, either can help your printer perform better. First, remove your ink cartridges from your printer and then dip a cotton swab in hot water or isopropyl alcohol and rub it against the print head. This should loosen any crusted ink. Some printers, such as many Canon models, feature removable print heads that give you easy access to the print head and its nozzle(s). Many other inkjet printers don?t have this feature, so you?ll have to do your best to work around parts in your printer. Be careful, especially if you use isopropyl alcohol to clean your print heads: Some printers use rubber gaskets; if you get isopropyl alcohol on the gaskets, it could dry them out. If you have a removable print head, remove the ink cartridge from the print head and take the print head out of your printer. Put some isopropyl alcohol or hot water into a saucer and set the printer head in the saucer. Let it soak for at least an hour. If it?s really dirty, it might be a good idea to let it soak overnight. Let it air dry, reinstall it in your computer, and run a cleaning cycle. This should get rid of any dried ink that was loosened during the soaking.
on Apr 21, 2010 | Office Equipment & Supplies
Clean the printer head
Go to Printers and faxes and right click on your printer and click on Properties - Maintenance tab - then select Cleaning or Deep cleaning
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
Jul 09, 2012 | Canon PIXMA iP3000 InkJet Photo Printer
The printer will not print in black ink
Hi
Try going into Printing Preferences in the Kodak Printer Program and perform Maintenance.
You do not say which operating system you are using.
Start > (Control Panel) > (Category View) Printer > right click on the Kodak icon > Printing Preferences > Maintenance > Nozzle Check > Head Cleaning > test print > repeat nozzle check, head cleaning & test printing until problem is gone.
If this does not fix the problem, replace the black cartridge > head cleaning > test print.
You might need to perform head cleaning after every cartridge change.
I hope this helps.
Aug 28, 2011 | Kodak EASYSHARE 5500 All-In-One InkJet...
I would like to put the cleaning process through, as i hav'nt used it for 6 months. epson stylus TX710W.
The print head clean maintenance is usually located in the printer Properties.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Aug 26, 2011 | Epson Stylus Photo R800 InkJet Printer
How can i clean a printer
Apr 30, 2010 | HP LaserJet P2015dn Printer
How do I clean my printer heads
Apr 08, 2010 | Epson Stylus C86 InkJet Printer
The colour is faint, a new catridge was installed
When printing becomes faint or colors are incorrect, even if ink remains in the ink tanks, the print head nozzles are probably clogged. Follow the procedures below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
If white stripes are noticeable
Step 2 : "Aligning the Print Head"
If print quality is poor
Step 2 : "Print Head Cleaning"
if the problem remains
Step 3 : Print Head Deep Cleaning"
if the problem still remains
Step 4 : Replacing Ink Tanks.
Note : * If the ink tank replacement does not resolve the problem, contact the Customer Care Center.
* You will be alerted if low ink warning is enabled.
* When the Maintenace button on the operation panel is pressed, the maintenance mode is shown. Numbers and functions that can be selected on the maintenance mode as follows :
01 : Printing the Nozzle Check Pattern
02 : Print Head Cleaning
03 : Print Head Deep Cleaning
04 : Aligning the Print Head
05 : Reset the ink counter.
06 : "Display" or "Not Display" remaining ink volume.
07 : Date and order setting.
Printing the Nozzle Check Pattern : Print the nozzle check patterb to determine whether the ink ejects properly from the print head nozzles and to verify print head alignment. Use this function when printed results are blurred or the color is incorrect,
1) With the printer on, load a sheet of Letter paper in the printer.
2) Print the Nozzle Check Pattern.
a) Press the Maintenance button,
b) The Maintenance icon and 01 appear on the LCD.
c) Press the OK button. The nozzle check pattern is printed.
3) Examine the nozzle check pattern output by the printer.
a) Lines missing in this pattern indicate that the print head of black ink requires cleaning. Perform the Print Head Cleaning.
b) White stripes in this pattern indicate that the print head of color ink requires cleaning. Perform the Print Head Cleaning.
c) Uneven patterns indicate that the print head requires alignment.
Perform Aligning of Print Head.
d) Noticeable white stripes in this pattern indicate that the print head require alignment.
Print Head Cleaning : Clean the print head if you suspect that the nozles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
1) Ensure that the printer is on.
2) Start print head cleaning.
a) Press Maintenance button.
b) Press right arrow once to display 02 on the LCD.
Important : Do not perform any other operations until the print head cleaning finishes. This takes about 50 seconds.
Note : After the print head cleaning finishes, print the nozzle check pattern to verify that the print head nozzles are clean.
If the problem persists, perform printhead deep cleaning.
Print Head Deep Cleaning : If print quality does not improve by standard print head cleaning, try print head deep cleaning, which is more powerful process. Print head deep cleaning consumes ink, so perforn this procedure only when necessary.
2) Start Print Head Deep cleaning.
b) Press right arrow twice to display 03 on the LCD.
Important : This process takes one or two minutes to complete so simply wait until the Power lamp stops flashing.
Note : After printhead deep cleaning finishes, print the nozzle check pattern to verify that the printhead nozzles are clean.
If the printhead is still not clean after the second deep cleaning, replace the ink tank.
If ink tank replacement does not resolve the problem, the print head may be worn out. Contact the Customer Care Center.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 07, 2009 | Canon i475 InkJet Printer
My bjc printer won't print. The paper goes through. The head/cartridge moves like it is printing but nothing. Tried everything in the maintenance manual.
If you have fresh ink cartridges installed and you have run the head cleaning maintenance and still have problems then the problem is most likely the print head ink nozzles are blocked.
This occurs then the printer has not been used for some time. To keep the nozzels from blocking the printer should be used once a week or the clean head maintenance run weekly.
There is no option other than to buy a new print head, they are not cheap.
Sep 08, 2009 | Canon Office Equipment & Supplies
Can you help? After changing the cartridges, I keep getting a message about the ink head being incorrect...I am directed to press 'OK' which does not help; then to turn printer off and on again, which...
Cleaning your head might resolve your problem. Perform the below steps to clean the head:
Print Head Cleaning / Head Refreshing If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head (Cleaning) or print head deep cleaning (Deep Cleaning). Note:
  1. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
  2. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
Overview:
Step1:
To check whether the print head nozzles are clogged, print the Nozzle Check Pattern.
downicon.gif If the print quality is poor, perform print head cleaning.
Step 2:
Perform print head cleaning.
This unclogs the print head nozzles
Print the Nozzle Check Pattern again.
If the print quality is still poor, perform two print head cleanings.
downicon.gif Print the Nozzle Check Pattern again.
Step 3:
Perform deep print head cleaning.
This is a more powerful cleaning.
Displaying the Maintenance screen
  1. Ensure that the printer is powered on.
  2. Press the <Menu> button.
  3. Press the left or right cursor to select [Maintenance/settings], then press <OK>.
  4. Press the left or right cursor to select [Maintenance], then press <OK>.
Print Nozzle Check Pattern
  1. Press the Open button to open the output tray.
  2. Load letter-sized plain paper in the auto sheet feeder (ASF) or the cassette.
  3. Display the Maintenance screen on the printer.
  4. Press the up or down cursor to select [Nozzle check], then press the <OK>.
  5. Press the up or down cursor to select [Yes], then press <OK>. (The nozzle check pattern is printed.)
  6. Confirm the nozzle check pattern.
05sj00160_03a.gif 05sj00160_03b.gif < 1 > The normal nozzle check pattern
< 2 > The abnormal nozzle check pattern
< 3 > Some black ink lines are broken.
< 4 > White lines are present in the color ink pattern.
< 5 > Both black and color inks are not present.
Note:
  1. When all patterns are printed normally, press the up / down cursor button to select "All A" and press the OK button.
  2. When any patterns are printed abnormally, press the up / down cursor button to select "Also B" and press the OK button.
Print Head Cleaning:
  1. Display the Maintenance screen on the printer.
  2. Press the up or down cursor to select [Cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head cleaning.
    Note:
    Do not do any other operations until print head cleaning is completed.
  4. Print the nozzle check pattern and check the print head status.
Deep (Print Head) cleaning:
  1. Display the Maintenance screen.
  2. Press the up or down cursor to select [Deep cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head deep cleaning.
    Note:
    Do not do any other operations until print head deep cleaning is completed.
    Note:
    If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. (After a given time interval, ink could dissolve itself, resulting in ink unclogging.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
Top PRINTER Office Equipment & Supplies Experts
Gene
Hardeepak Bhambh
Hardeepak Bhambh
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
