How to do the print head cleaning maintenance routine
SOURCE: user's guide- trouble shooting and routine maintenance
printer will not print referring me to the trouble shooting and maintenance chapter in the manual which I can't find......I have a Brothers MFC-420cn CAN YOU HELP ME......
Posted on Feb 05, 2008
Mix-it-up
  • 832 Answers
SOURCE: error message on my mfc 420 mc
this has been written many times here in the forum.
plz search forum "unable to print"
Posted on Jun 23, 2008
  • 742 Answers
SOURCE: "Unable to clean see trouble shooting and routine maintenance"
you should manually reset your PURGE COUNTER to ZERO so that your printer will work again. Follow these steps:
Unable to Clean error means purge counter is already full. Please refer below for the instructions on troubleshooting your machine.
1. To enter MAINTENANCE Mode: Press MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the following:
a. 8 then press SET
b. 0 then press SET
3. Using MONO START, just press it until the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the following:
a. 2 then press SET
b. 7 then press SET
a. 8 then press SET
b. 3 then press SET
This is to reset the purge counter. Then press stop/exit
5. Using arrow up button look for the following:
a. 0 then press SET
b. 1 then press SET (To reset unit)
a. 9 then press SET
b. 9 then press SET (To exit Maintenance mode)
Posted on Jul 11, 2009
cene765
  • 787 Answers
SOURCE: My brother dcp 110c printer is unable to initiate
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the
error is 50 or 51 there is error in Purge unit and printer require service.If the error is 48 - defective print head cable or circuit board.If the error is 46 the waste ink tank is full.Follow this:
1. Pres 'menu', 'mono start' then 'menu' one by one...
2. Press the arrow up or down to go to 'maintenance 80'.
3. Press 'mono start' several times to go to 'Purge'. Finding the PURGE will show some numeric value
which is Iassume the number of times the printer had cleaned.
4. Press 'arrow up' key and scroll for number "2" then press "set".Do the same for numbers 7, 8 and 3.
After you have entered this combination, the purge numeric value will be reset to 00000.
5.Restart printer
Posted on Nov 13, 2009
SOURCE: clean unable 46
C D WORLD NAGPUR 09960014121
HI ALL HOW TO CLEAN DCP ERROR CODE 46
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Posted on May 16, 2010
Cannot print magenta
Most likely the magenta print head nozzles are blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
May 05, 2013 | Office Equipment & Supplies
Change the ink cartridge and still will not clean
Nov 01, 2012 | Brother Office Equipment & Supplies
No black even after cleanings
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 16, 2012 | Epson Stylus Photo 1280 InkJet Printer
I have run nozzle check and head cleaning several times. My printer is still not printing. Suggesstions?
Sep 06, 2011 | Office Equipment & Supplies
I would like to put the cleaning process through, as i hav'nt used it for 6 months. epson stylus TX710W.
The print head clean maintenance is usually located in the printer Properties.
Aug 26, 2011 | Epson Stylus Photo R800 InkJet Printer
Canon pixma ip 1500. Will not print black ink. Have cleaned, and deep cleaned nozzles. Color prints good, black does not print at all.
Jul 01, 2011 | Canon Office Equipment & Supplies
Lexmark X75 won't print in color. Tried cleaning print heads, didn't work. What now?
Jun 16, 2011 | Lexmark X75 All-In-One InkJet Printer
How to clean print head of brother dcp195c Problem. there is ink clot in the head. with normal function we tried to clean but black is still giving problem
May 13, 2011 | Office Equipment & Supplies
Heads ned cleaning.. After each line f print 2feint lines follow
Apr 07, 2011 | Epson Stylus DX8400 All-In-One InkJet...
jasbo
jasbo
