Trying to load os and get message can't load error code 10
  • 64 Answers
Hey,
I researched your error a little bit and i found a solution on Microsoft's website. Here is a direct link for you to follow and it basically breaks down why you got the error and how to fix it. I hope I helped!
http://support.microsoft.com/kb/310123
Posted on Jul 20, 2009
What does error message F-10 mean
Please consult the electrical schematic attached to the machine. It's has all the error codes listed and what to do to troubleshoot.
Jan 03, 2016 | Hotpoint Ultima WT960P Washer Front...
STOP 0X0000008E(0XC0000006,0XF740DFEA,0XF6F0AA14,0X00000000)
The stop is actually a OS error code abbreviated "Stop 0x8E "
"KERNEL_MODE_EXCEPTION_NOT_HANDLED"
In reality it is a BSOD (Blue Screen of Death).
The most likely cause is caused by memory hardware failures and more rarely by device driver issues, viruses, or hardware failures other than your RAM.
Type the same as the quotation "Stop 0x8E" into Google - it will take you to the error code and give you the meaning.
It's not a computer processor error, at all, but a memory or driver error. Most likely a device which is trying to be used by the OS you are loading but can't load because the device needs a driver or the memory is loose (besides bad memory). Remove the memory and re-seat. Make sure not to touch the contacts with your hands. Take a pencil eraser and clean the contacts.
For a better answer, the next time give the OS version you attempting to load, and the hard drive you are using whether ATA or SATA. The more data the better. Now to test your memory --- download MEMTEST (find it on Google) it's FREE. And run Memtest on a Floppy disk or from a CD. Run the complete ALL tests, It will take many hours, but you can write down the errors (if any) and exchange your memory for new memory under the lifetime warranty that memory maker give. Good luck.
May 10, 2014 | Computers & Internet
Strugling to download program
Post your OS, Service Pack if applicable. Have you done ALL your Windows Updates? Take a look at this procedure: http://digita7seven.blogspot.com/2012/11/how-to-fix-error-hresult-0xc8000222-net.html
Apr 01, 2013 | Nuance PDF Converter Pro 8 Windows...
Code 10
If you run into the error "This device cannot start. Code 10? (often followed by a driver identifier, for example "This device cannot start. Code 10 in audio driver"), here is what it means.
The Windows error "This device cannot start. Code 10? or "This device cannot start. (Code 10)" is a hardware error that most commonly means that you have a bad, missing, or incompatible device driver. So, for example, "This device cannot start. Code 10 in audio driver" means that you have a bad or missing or incompatible driver for your sound card.
The technical explanation for this message, according to Microsoft, is this:
"If the device has a FailReasonString value in its hardware key, that string appears as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message:
What does that mean in plain English? It means that if the device which is throwing the error has added its own custom error text to your Windows system when the device was installed, then when the device encounters an error, you will see the custom error message specific to that device. But if it doesn't have its own custom error message, then Windows uses its own generic error message for devices, which is "This device cannot start. (Code 10)"
Microsoft recommends that when this happens, you click "Update Driver" to update the drivers for the device. You can also start the Windows troubleshooting wizard by going to the general properties tab of the device, and clicking on "Troubleshoot".
Before doing this, be sure that you have the correct and most up-to-date versions of the driver(s) for that device. You can also try uninstalling and reinstalling the device, using the disk which came with it.
Finally, you can go to the website of the device's manufacturer, and check their downloads or support section for current, up-to-date drivers.
Mar 15, 2011 | Computers & Internet
CODE 10 ON TSST l632@ VISTA os
This is from Microsoft and is from their code explanation page.
Code 10 loadTOCNode(2, 'moreinformation'); If the device has a "FailReasonString" value in its hardware key, that string is displayed as the error message. The driver or enumerator places this registry string value there. If there is no "FailReasonString" in the hardware key, the following generic error message is displayed:
This device is either not present, not working properly, or does not have all the drivers installed. (Code 10)
Try upgrading the device drivers for this device.
Solution button: Update Driver
To resolve this error code, make sure the device is connected to the computer correctly. For example, make sure all cables are plugged in fully and that all adapter cards are properly seated. Follow the suggested solution button and update the device driver. It may be possible to remove the device and redetect it using the Add New Hardware wizard.
Jan 15, 2010 | HP Pavilion DV6700T Notebook
Black screen with an error code 7
code 7 means the storage blocks have been damaged...the message is saying it cant locate the kernal map..
use software to check hd for bad sectors if sectors ok insert os disk and repair os.
Dec 16, 2008 | HP Pavilion dv1000 Notebook
Hi, I get an error message when I try to connect and install a Maxtor 500 GB external hard drive to my computer. The message reads "the device cannot start (Code 10). Can you assist?
What is the error message you get?
What OS are you using?
Depends on your hard drive, some computer commonly ask for a driver when you plug something in it. might as well try reading the manual of your external hard drive, if it doesn't require a driver, then the problem "might" be in your operating system and/or in your computer.
Sep 26, 2008 | Computers & Internet
COULD NOT LOAD OS - TRIED 2000 & 2003 SERVER
Reinstall OS without repairing. Sometimes people make the mistake between a choosing repair and a full reinstall. Also backup any files before doing so.
Sep 20, 2008 | Acer Altos G530 Server
DVD driver fault - Pioneer DVD-RW DVR-212 ATA.. maybe NERO 8 fault?
Code 10 means the driver cannot load usually due to being incompatible with the OS type.
May 29, 2017 | Computers & Internet
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
