Question about GE Dryers
I have a GE Profile DPVH880EJMG Dryer. It drys but shuts off before clothes are dry. It doesnt matter what sensory cycle it is on or time dry.
If you let the machine set for about 10 minutes and restart it, it will continuing drying but the clothes still wont be dry. This procedure takes sometimes three or four times before getting the clothes dry. The repair man has checked the venting and found no problem. He has replaced the main control panel board, the motor. He now says he has no idea what it could be. Do you have any other ideas of what the problem may be?
  • GE Master
  • 5,323 Answers
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
OR you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposed to be if the motor does not run , the heater should not heat in order not to create fire but if the motor is not running, and the heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater.
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :
How to Check Dryer Thermistor eHow
I have a GE Profile DPVH880EJMG Dryer. It drys but - 26390714-bszy215dbxllk1sw2ym4qmfg-4-0.jpg
26390714-bszy215dbxllk1sw2ym4qmfg-4-2.jpg I have a GE Profile DPVH880EJMG Dryer. It drys but - 26390714-bszy215dbxllk1sw2ym4qmfg-4-5.jpgt/uploads/images/26390714-bszy215dbxllk1sw2ym4qmfg-4-5.jpg" alt="26390714I have a GE Profile DPVH880EJMG Dryer. It drys but - 26390714-bszy215dbxllk1sw2ym4qmfg-4-9.jpg"h_mi" />
Posted on Dec 08, 2016
Testimonial: "Thank you so much for your advice. Hopefully by checking what you have recommended will take care of the problem. I sure appreciate you taking your time to answer my question. God Bless and Take Care."
  • Jorge Rendon
    Jorge Rendon Dec 09, 2016
    your welcome let me know if u need more assistance
Takes 4 to 5 dryer cycles to dry one load
usually thats a blocked vent to the outside..Its wet on the inside because its holding the condensation from the clothes .also check blower wheel ..One sure way is take your vent off the back of the dryer and dry a load if it drys in a normal time you know your out going vent is plugged
Feb 18, 2015 | GE Dryers
Dryer is not drying clothing, takes approx 4 hours to dry one load, I can see condesation build up behind electric panel where numbers are.
Sounds like you have a blocked vent. Make sure there is good airflow. Heat and airflow is what drys and if one is removed you will not operate correctly.
Jun 29, 2010 | GE Profile Harmony DPGT750EC Electric...
try timed dry to see if it does it
Apr 19, 2010 | Kenmore 63942 Dryer
GE DPGT750 Gas Dryer runs but no heat
if your blower motor isn't getting up to speed it won't heat.check troubleshoot mode by holding my cycles and help at the same time for three seconds.may need a new blower motor
Mar 09, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Machine drys fine on timed cycles but shuts off before clothes are dry on automatic cycle.
First try cleaning the moisture sensors with rubbing alcohol, these are two silver colored strips located inside the drier just below the lint cleanout
Oct 31, 2008 | Whirlpool GEW9250 Electric Dryer
Taking long time to dry
before we do that run a load in the dryer with the vent in the rear off the unit It sounds like the vent going to the outside is clogged more than a dryer problem if it drys ok then you know that is the problem if not it is internal I will send you the book either way let me know
Aug 03, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Clothes are not drying
your blower motor is probably not working. enter the troubleshooting mode by pressing and holding my cycles and help at the same time for 3 seconds. this will tell you the problem. if blower is not getting up to speed you'll have to replace it.
Dec 03, 2007 | GE Profile Harmony DPGT750GC Gas Dryer
Dryers Logo
125 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
