Question about Sharp Aquos Televison & Video
Sharp LC-60EQ10U video processing slow from bottom to top like a slide show horizontal lines dark screen horizontally also getting a humming noise tv is functioning with audio but unwatchable
On startup "Sharp" logo is dark with horizontal lines thru it. also constant green mass covering top left 1/4 of the screen that is translucent.
  • 8 Answers
SOURCE: sharp 2002
If you are using an analogue signal then check things like DECT phones, Wifi / DSL modems, power cables, power convertors / UPS, washing machines, dryers, microwaves etc are kept as far away from the cables as possible.
Have you bought anything new recently, when it happens think what things are turned on... is it the garage door being opened etc.
If you are using a digital signal (and ideally something like a DVD player or a games console rather than a cable TV box) then check the HDMI cable.  If all appears well then it could well be a fault with the television, especially if you get interference from multiple source (i.e. cable TV, DVD player, console etc)
Posted on Nov 18, 2007
  • 103 Answers
SOURCE: Horizontal black line running through tv
You need to take it back to the place of purchase.It has a bad panel.I don't know why the other person didn't answer this is a easy one.
Posted on Mar 05, 2008
SOURCE: Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Posted on Jan 10, 2009
  • 1779 Answers
SOURCE: Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Posted on Feb 28, 2009
chanddra2009
  • 615 Answers
SOURCE: My Sharp LC-60C46U LCD TV will not display any
Dear guestcomp,
This problem is due to faulty display panel.So replace it with new one.It will solve your problem.I think it helps.Let me know.
Posted on Jan 04, 2011
My sharp aquos is having problems with the picture. It gets lines across the screen and then the picture goes dark and it goes off. The power light blinks 5 fast 2 slow repeatedly. Any ideas?
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 02, 2017 | Sharp Televison & Video
Two horizontal lines appeared near bottom of screen
You can spend $300 to $500 fixing this or just do the best thing most cost effective thing and replace the TV.
Aug 23, 2016 | Sharp Aquos Televison & Video
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
How do I fix my Sharp tv model LC-42D62U? On the tv screen now shows horizontal lines with repeating ghost images.
Hi Paul,
The horizontal lines on the screen are virtually NEVER caused by a bad T-con board. These horizontal lines indicate a defective LCD panel (screen). The Screen has small ICs that become defective overtime and that it isn't fixable unless replacing the entire screen.
Sep 13, 2015 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Faint horizontal lines from top to bottom after an hour of use...
I can tell you right off the bat that is a service issue you will have to take up with sharp. Contact their operational support, they have a quick turnaround with things like that. When you call, they will most likely ask you to take digital pictures of these black lines and have you e-mail the pics to them.
Dec 08, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Noise and horizontal line
Very easy Fix, The problem is the cable box is not grounded properly. (not your fault) Go to the Local store and get a Plug adapter, just to change the TV plug that goes into the wall or surge protector from 3 to 2. Trust me on this....
Best regards
CircuitCity
Nov 29, 2007 | Samsung LN-R328W 32 in. HD-Ready LCD...
Black horizontal lines
this is a manufacture defect with the panel call sharp.They know about the problem.Be persistant
Mar 08, 2007 | Sharp LC-45GD7U 45 in. HDTV LCD
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
