Question about Refrigerators
Side by side Refrigerator shuts off . If you mess with temp control it will restart and run for short time then it shuts off again.
  • 552 Answers
There must be other symptoms. There must be more info re frig mfg, age, and type. Causes can be control board, thermistors, thermostats, compressor overload, etc.
Posted on Dec 09, 2016
I have a General Freezer,Ltd model 16 Upright and it shuts itself off periodically without my being aware . When I see food defrosting , I am able to restart the unit by tapping on the temp control dial...
You need to replace the temperature control, (unless you find a bad wire connection to the temp control first). You can find a control that is close enough at any appliance parts store, bring the old one in for a match up. Make sure it is NOT a 39 degree constant cut in type and you will want a differential of at least 6 or 8 degrees minimum so that it wont "short cycle" which means it would run for a few minutes, shut off for a few then run again before the high side pressure comes down.
Oct 01, 2011 | General Freezers
Entire cooling shut down - restarted 10 hours later, shut down again 12 hours after restarting.
Hi and welcome to FixYa, I am Kelly.
The defrost cycle is usually terminated by a 60 Deg bi-metal thermostat. If the defrost heating element is not heating up the unit will shut off until the internal temp reached 60 Deg F and then restart.
Defrost cycles are 10 - 12 hours apart depending on the defrost control installed so that explains the 12 hr repeat. I really think you have a bad defrost heating element. Here is why I say that...
1. The Defrost cycle is 12 hours after last defrost. (Means the defrost control /board is working)
2. The defrost cycle terminates at 60 Deg F
3. No working defrost element will cause very very long defrost cycles due to the time it takes for the compartment to warm up to 60 deg F and terminate the defrost cycle.
The element is item 33 of this link:
Just looking at the drawing it appears that the Defrost heater and defrost thermostat are an assembly.
You should be able to read resistance end to end on the heater assembly. If you have no resistance it is most likely open / has failed.
The defrost thermostat will read resistance anytime compartment temp is BELOW 60 deg F.
Thanks for choosing FixYa.
Jan 19, 2011 | KitchenAid Superba Architect KSCS25INSS...
About 36 hours ago our Whirlpool 25.2 cu. ft. Side-by-Side Refrigerator ED25CQXFW02 was not cooling (frozen was thawing, and refrigerator was not cold) the compressor and fan were running, I cleaned the...
depending on your model. if its just a reg, side by side, you more than likely need a relay/ overload which is located on the compressor,the relay only works after it cools down. unplug ref from wall, remove rear cover to see and touch compressor to see if it starts when you plug back in to the wall. if it doesnt start in three attempts. replace it. easy way to diagnose..
Jan 17, 2011 | Whirlpool 25.2 cu. ft. Side-by-Side...
Why does the freezer portion temp indicator bounces between 0 and -12 degrees periodically.
Temps should fluctuate, as the refrigerator will go into a defrost mode every so often. Some models will go into defrost mode after you open the freezer door X amount of times, say 6. So every 6th time you open the door it will go into defrost. Then some models go every 4 to 6 hours depending on settings. Then also, it is normal due to temp control. Temp setting is -10 The fridge will run to that temp setting, -10 and shut off the compressor at -10 but due to pressures it will still cool a bit to your -12. it will stay in this off mode until the temp rises 8 to 10 degs. then kicks back on the compressor. Again due to pressures it may take the system 2 - 3 degs to catch back up and start cooling again. But you maintain average temp of -5 to -6 which is great for frozen food and saves a bit of electricity. As long as the door seals are in good shape and you clean the coils underneath once twice a year it should work fine for many years. Then lastly It may have a lag in the thermostat meaning it has gotten week or going bad. Hope this helps.
Jan 10, 2011 | Frigidaire FRS3R5EMB Side by Side...
Problem is side and medium strip in between doors is getting extremely hot and compressor fan was replace by tech and fan ran for 2 minutes and shut off. However when we unplug refrigerator and replug in...
you didnt list a model number but im betting there is a control board beside the compressor that has gone bad not allowing the compressor fan motor to run. if you will list a model number i will gladly help you trouble shoot the control board/.. thx peyton
Oct 07, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Turns off won't turn back on unless you move thermostat
Sounds like a defective cold control ( off/on thermostat).
They will tend to stick in the off position. Your moving the knod unsticks it.
May 24, 2009 | Whirlpool ES5FHAXS Side by Side...
Refrigerator noises
your refrig will have "normal" off cycles for when the temp control is satisified and when it goes into defrost cycle. normal run time for most units is 60-80%. main thing though is that your temps are normal. thx peyton
Jan 22, 2009 | Jenn-Air JCD2389G Side by Side...
Refrigerator stops cooling, but if I adjust the temp it restarts
temp control wire dodgy turn off take plug out of socket trace wire repair it switch back on i had one temp mate it was wire
Dec 17, 2008 | Frigidaire FRS23KF7AB Side by Side...
Oven will not shut off broiler element stays on
The control knob more than likely operates a relay that has gotten stuck in the energized position. If this isn't the case then the Temp sensor or thermostat probably shorted internally. Unplug the unit before attempting any work.
Nov 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
