Question about Husqvarna Garden
The noise while reversing the husqvarna lawn mower is from the gear box. Machine 3 months old
  • 486 Answers
The transmission needs to be removed and disassembled for inspection. This should fall under the warranty period.
Posted on Jan 24, 2017
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
SOURCE: Husqvarna YTH180 runs but won't go into gear
Check the drive belt. If it looks good and turns the pulley on the trans you will need to have the trans looked at.
Sam
Posted on Jan 08, 2010
kel1guy2002
  • 3740 Answers
SOURCE: lawn mower has hydro gear transaxle reverse was
Most of the time when this happens the reverse shift linkage is too short. It is usually cause by either a bent linkage or worn linkage bushings.
The internal shifting fork can be bent inside the transmission which is rare but does occasionally happen... most of the time it is a linkage problem. Also check on the side of the transmission to make sure the shifting lever has not moved from the original position on the Yoke shaft.
Thanks for using FixYa.
Kelly
Posted on Mar 29, 2010
  • 3911 Answers
SOURCE: i cant replace the deck belt on my husqvarna ct151 lawn mower
The manual shows how the belts are put on, if you do not have one they may be purchased through dealers or small engine repair shops or online. On mine there is also a little diagram on the top of the mower deck. Another way to check is find an identical one that is functional and look at its belt. There are only so many ways it could fit and these are all made by just one or two manufacturers so there is not much variance.
Posted on Jun 01, 2010
  • 3074 Answers
SOURCE: need a belt diagram for
ttp://www.partstree.com/parts/dispdiagimg.php?src=r&ilFN=D%3A%5CEMPARTweb_52%5CCatalog+Data%5CEMP_IMG%5CHUS%5Cimages%5C90%5C35%5C0019.TIF&ilSC=10&ilIV=0&ilBR=0&ilIF=G&ilRE=8&ilSH=0&ilEG=0&ilRO=0&ilSC=23
Posted on May 22, 2011
A loud noise on fuel husqvarna lawn mower. Machine 3 months old
call the place you brought unit. Should under warreny
Dec 08, 2016 | Husqvarna Garden
What would cause my mower to not move in reverse at all?
Transmission if it's a hydrostatic... a belt... or a pulley issue... is the gear selector going all the way back to engage reverse?...
Only other way I can give you a more accurate answer is with a make and model. There are too many kinds of riders and with all different set ups... thanks
Oct 10, 2015 | Husqvarna YTH22V46 46 inch 22 HP Briggs &...
How could gas be entering the crankcase of my Husqvarna 48" riding lawn mower?
Sounds like you have a hole 'burnt' in the piston top allowing fuel combustion mixture (normally compressed above the piston) getting down into the crankase or that the piston rings are shot allowing the same thing.
As the piston is continuously moving, the reverse happens giving oil at the intake or carb.
. Looks like a strip down, good inspection and rebuild of engine required .
Sep 20, 2014 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Speed of the lawn mower governor is missadjusted
The engine revs are turned down to make the machine noise compliant, increasing the revs will greatly increase the noise, the engine revs shouold not realy be increased, however a dealer with a suitable engine taco may do it for you, it is very important not too over speed the engine or it will self destruct,
Apr 11, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
Husqvarna Riding Lawn Mower Problem
sounds like a linkage problem or the valve in the trans some older ones had a problem with a roll pin inside the trans falls out of place cheap fix but a lot of time to pull the trans out and apart
Jul 12, 2012 | Garden
WHAT CAUSES METAL ON METAL GRINDING NOISE IN HUSQVARNA 173CC MODEL 917 MOWER AND HOW TO FIX
I would check any pulleys if self propelled and the rotation of the blade as well. I had one recently that made the same noise and it was just a rock stuck on a pulley. Hope this helps!
Jun 12, 2012 | Garden
How to reset oil change indicator on my husqvarna riding lawn mower
depends on how old the mower is, for the past 3-4 years, Husqvarna made it so that you have to replace the unit, unable to just reset it.
Jul 02, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a 2005 husqvarna lawn tractor. 24 hp, 48 in deck, the transmission runs fine on level ground but when i go to an incline the tranny slips and i hear a clunking sound, and if i travel farther up hill...
sorry. I don't have an ansewer for you however I might have some helpful hints. Your mower should be going dam near 5 MPH. But yes can't cut in reverse. you have a belt going from the trans axle to the motor. It could be slapping against the frame. The idler puller or the tension pulley could be wobaly where the bearings are gone out. If you remove the 4 bolts on the back of the mower under the seat and gas tank it should visable tell you the story. My question is mine hits gears real hard as if trans mission needs oil or internal damage.
May 09, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
279 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
