Question about LG Televison & Video
Have Philips 55PFL6007T repair manual doesn't list the components of the LG lcd side panels, of which two blown caps, on board 6870s-1333d need values of c121 and c124 any idea how i get that info?
    Top Expert:
  • LG Master
  • 34,100 Answers
Ask Philips
Posted on Dec 08, 2016
Coldcut
  • 1554 Answers
SOURCE: Philips LCD model 26TA1000, vertical lines and blank white screen with no picture
it would be easier to find it stripped from a damaged set on ebay.
I see several there but need the part number to search
of course you may purchase that and find it to be the lcd driver.hopefully not.
Posted on Feb 18, 2008
  • 116 Answers
SOURCE: philips 50" plasma ysus board troubles
Check for shorts, blown fuses on ysus, if blown replace entire board, easier than locating many of the parts installed on the board.
Posted on Dec 11, 2008
  • 92 Answers
SOURCE: LG 47LC7DF LCD TV Remote Sensor not working
IR senor may not be bad. Try using a different remote (universal) and program to TV. If universal remote works and your doesn't, you may need to purchase a remote instead of IR board. If you confirmed that the IR board is bad then replacing the IR board will fix the remote issue. IR board is an easy fix. Just open the back cover out and it's located right in the middle toward the bottom of the TV.
Posted on Jun 22, 2009
  • 4 Answers
SOURCE: Need info on component 3071 on power supply board - burned up.
Its been a while since i worked on that power board. But I believe you are refering to the orange diode that runs into the single connector for the video board next to the power supply. I replaced mine with a 1n914 diode after replacing the 2200uf lytic cap and the tv fired right up.
Posted on Sep 11, 2009
SOURCE: I have a 37" Philips (37PF9431D/37) flat panel tv....
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
Posted on Dec 27, 2010
Won't turn ON. Found F601 fuse blown on power supply/inverter board. What's the most likely culprit?
Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2
www.shopjimmy.com/emerson-a17f1mpw-power-supply-co...
ShopJimmy
$19.94 - ‎In stock
This Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2 ... board. If the TVhas no power it is most likely because of a blown fuse and failure of other preceding components. ... I tested F601, Q600, R602, 608 and 611, and found them to be bad. ...Power Supply / Inverter Board - Joseph A. on March 4th, 2015.
Common TV Repair for Emerson, Sylvania, Philips ...
? 5:35
https://www.youtube.com/watch?v=nQHWrJJg4Mc
Oct 11, 2013 - Uploaded by Tampatec
... LCD TV repairs for Emerson, Sylvania, Philips, Magnavox,blowing fuses "no power" i recommend a TV service LCD repair kit at ... powersupply power-supply "power supply" powerboard "power board" part2 part 2 pt2 ...
What Causes a Blown Fuse in TV Sylvania LCD - YouTube
? 15:31
https://www.youtube.com/watch?v=4P_0aLDZgBY
Jan 01, 2016 | Televison & Video
Free tv repair advice
Potentially so, however I would get the TV fully checked over by a professional if it has been subject to a surge. If a component further down the line caused the initial surge replacing the blown cap will only result in another bang as soon as you plug it in.
Mar 21, 2014 | Televison & Video
Lg tv has sound but no picture
inverter prob. psb board works turning on main that makes sound,could be main as well. but if tv is lcd, . inverters have problems (one or two boards on sides ) look for blown caps.
Nov 08, 2012 | LG 42LC2D 42 in. LCD HDTV
Picture is out on LG LCD TV
The problem can be blown up components in the back lights inverter board or in the 24VDC power supply section. You need to open up the back look to see if you can locate blown components. There should be 24vdc on one of the power supply output connectors pins.
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=LG+42LC2D+&limit=200&stock=all
Jan 02, 2010 | LG 42LC2D 42 in. LCD HDTV
Samsung LE32 tv does not turn on. blue indicator light flashing
this is a common fault take back of and look on main power board for blown capacitor's ( raised tops ) they look like little batteries with white line down one side replace then with same value e.g ( 2000mf 25v)
remember what side line is on (TAKE PICTURE) for capacitors look on Charles hyde and son web site(CHS) under general components listed on left side of page
Dec 13, 2009 | Samsung LE32R72BX 32 in. HD-Ready LCD TV
Tv keeps clicking red light blinking but doesnt come on first it was fifteen minutes then thirty now an hour and it i still not on?
the red light blinks due to a problem in the power supply or deflection circuit, this usually happens when one or two components start changing specified value or just entirely go out. Some samsung tvs do have replaceable boards but you still need to pinpoint the problem to a certain circuit board, either deflection or power board. It may be worth it to call a service tech and describe the problem to get a good idea on the repair cost.
Oct 13, 2009 | Samsung PCK5315RX TV
Sony Bravia V series is on standby. Does not turn on.
That is true. You need to change a new board as when the chip is blown, all the related SMT cap, resistors, and transistor were gone, too. Those tiny component are hard to repalce one by one. Importantly, some of them was changed value and it only happens when the TV is warm up.
Aug 18, 2009 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Jul 23, 2009 | Philips Televison & Video
Philips 50" plasma ysus board troubles
Nov 26, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
Televison & Video Logo
Computer Repairing
Computer Repairing
