Question about Sony Wireless Controller for PS3
Does any one know how to add a second controller? I have tried everything!!
    Problem Solver:
  • 12 Answers
Hook it up to a USB cord and connect it to your PS3, then hit the PS button to turn it on. It will register itself to the PS3.
Posted on Jul 20, 2009
If you bought dreamgear or something that doesn't have a cord to plug in use the USB port that came with it. Turn controller on. Press the connect button. It will blink a red light slowly. Press menu on the controller. Then press connect on the USB another time.
Posted on Dec 04, 2011
Ihave a p0171,p0175 checked everything,replaced almost everything help
Rather strange combination of codes. First is running too lean, second is running too rich. It could be that the O2 sensors have failed and computer is cycling between lean and rich mix, but this should set a code for O2 sensor issue. The O2 sensors only regulate fuel mix within narrow ranges, but if you have not checked the output voltage sweep from them, might be worth a try. It would be helpful to know everything you have done so far.
Jan 01, 2015 | Cars & Trucks
I can't add other controllers to play
Try plugging the second controller in to the ps3 using a provided usb cord then press the PS button on the controller. Do this just to make sure that the controller is paired to your PS3. If your still having issues you may need a new controller.
Feb 17, 2014 | Sony Playstation 3 (PS3) Console
Printer will not print
Let's assume the cables are OK and connected. Click on Start, Control panel, Printers and faxes (or similar). Delete all printers. Click Add printer, choose Local printer, USB port, Next. Choose brand on the left side, and model from at the right. Confirm everything and this should be OK. If not, try to find printer model on manufacturer's web site, and install it. If this does not help, probably the problem is with printer, try to reinsert cartridge, paper, pull out cables, put them back after 10 seconds and try again.
Sep 24, 2012 | HP Pavilion dv6000z Notebook
I have a 1990 Wayne Dalton opener with remote control model 61wd. it uses rolling codes. Everytime i try to add a my new KLIK1U univeral remote controller, the original controller quits working. When I...
The system is limited in the number of openers it can store. Usually 3 though I don't know about your model..
You need to clear all stored openers, and then re-add what you want to use. If there are 4 or more it will not work.. The last one entered will be replaced by the new one. (What you're getting now)
Usually to clear memory, hold down the program button for ten seconds or so.
Wait a few seconds, start installing your openers.
Good luck
Dec 27, 2010 | Chamberlain Clicker Universal Remote...
How do i remove the driver, i have tried everything
Go to the Control Panel and click on Add/Remove and find the item and then click remove, this will take it off the system. PLEASE let me know if you still have problems, I would be glad to assist you further..... Take care, Guy S. :)
Oct 15, 2010 | Konica Minolta magicolor 2400 Laser...
Code P1792
P1792;
It's Either / OR; IF your car have those systems:
Powertrain - Manufacturer Controlled DTC - Manufacturer Controlled;
AT - engine control module (ECM)
OR;
ECM to TCM Engine Coolant Signal (4L30-E Transmission),
OR;
AT - AT EEPROM checksum error
OR;
Barometric pressure (BARO) sensor - circuit malfunction
Caused by your
ECM/Programming
OR;
Key on or engine running, then the PCM detected that the ECT sensor signal was below the lower or over the upper limit, or that the ECT signal was unreliable, conditions met for one second
Try it, & PLZ; let me know if I add any benefits to you.
I hope I add some thing valuable to you.
Regards;
MAR;
soer2@yahoo.com
Nov 09, 2009 | Daewoo Cars & Trucks
I need the wattage on a GE microwave WES1450DMBB
Product Features
  • Electronic controls are easy to operate and offer one-touch operation
  • 1.4 cu. ft. capacity accommodates everything from small snacks to family size meals
  • 1150 watts of cooking power and 10 cooking power levels allow you to reheat and defrost quickly
  • 5 sensor cooking options automatically monitor cooking progress and adjust time and temperature for delicious results; sensor options include beverage, reheat, popcorn, potatoes and vegetables
  • Auto and time defrost functions make it easy to thaw food quickly
  • Express cook control with 1-6 minute intervals for cooking or reheating leftovers
  • Add 30 seconds option
  • 12-5/8" glass recessed turntable provides ample cooking space for oversized and oblong-shaped dishes
  • Clock and countdown timer allow you to conveniently coordinate meal times; reminder signals let you know when cooking is complete
  • Black finish adds a touch of style to your kitchen
try{ var divArr = document.getElementsByTagName('div'); var rpDiv = document.getElementById('tabbed-overview'); var spDiv = document.getElementById('saleprice'); var rp = getRegPrice(rpDiv); var cp = getCurrPrice(spDiv); if(rp!='none'&&cp!='sale'){ spDiv.parentNode.insertBefore(ocRegPrice(rp,cp,'pdp'),spDiv); } }catch(e){}1150 WATTS
May 10, 2009 | General Electric Microwave Oven
I have a presario f500 and it will not turn on
Try this:
Unplug everything (and I do mean *everything*) from the laptop and remove the battery.
Then with no power of any kind for the laptop, hold down the power button 15 seconds.
Attach A/C power and try to turn it on.
If that does not work, remove power and take out the CD/DVD drive and if you feel
comfortable with it, take out the RAM and hard drive.
Connect power and try to turn on. See if you get beeps or a power light on the laptop. If
you get beeps, put the RAM back in and try power again. If that gives you a display, add
back the hard drive.
Let me know what happens.
Honest1abe
Jan 12, 2009 | Computers & Internet
No power to control unit
Basically your service did not add anything I had not tried already. I had to send the product back.
I would like a refund.
Apr 10, 2008 | Audio Players & Recorders
Sony Wireless Controller for PS3 Logo
1,265 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
