Question about Husqvarna Garden
The mechanic says the noise while reversing the husqvarna lawn mower is a transmission problem. How can I fix it
  • 486 Answers
The transmission needs to be removed and disassembled for inspection
Posted on Jan 24, 2017
  • 109 Answers
SOURCE: MTD PRO RIDING MOWER/LAWN TRACTOR 18 HP ENGINE HYDROSTATIC DRIVE
In the back of the mower...probably under the seat, there should be a lever to release the transmission, or it is on the back plate. As far as the noise when trying to move drive the mower, the brake in the back, next to the transmission is jammed, use a 1/2 inch wrench to loosen it maybe 1/4 turn and this should unlock the brakes
Posted on Apr 22, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 396 Answers
SOURCE: wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Posted on Oct 10, 2009
rockmeister
  • 2047 Answers
SOURCE: craftsman lawn tractor automatic transmission
Just like motor vehicles when transmission gets stuck on a particular place without moving forward or backward it is a sign of a jam in one of the transmission levers. This is usually caused by lack of transmission fluid in the gears.When the fluid or grease depending on what your unit uses gets low the levers begin to grind against one another and therefore bring about such problems as you are facing. Although there is an off chance that the problem could also be from the automatic selector in this case the damage might not be so much probably an electrical fault.
First get an expert to check the auto selector if it is in good shape. If it is then i am afraid the problem is from the transmission levers.
Hope this insight has been helpful?
Posted on Apr 14, 2011
  • 14 Answers
SOURCE: Husqvarna Riding Lawn Mower 46 Cut model
I can not say this enough, check the safety switches. There should be one on the seat, the clutch /brake pedal and /or the equipment pto switch. Also, check the wires running to these switches. They tend to move and vibrate as you mow and a worn spot in the wires can cause a short, resulting in the mower not starting.
Good Luck!!!
Posted on Jul 17, 2011
The noise while reversing the husqvarna lawn mower is from the gear box. Machine 3 months old
The transmission needs to be removed and disassembled for inspection. This should fall under the warranty period.
Dec 08, 2016 | Husqvarna Garden
Suddenly all drive was lost .no forward or reverse
Hi Rod:
I would be suspicious that the drive belt between the engine and transmission has failed. It is located inside the frame above the mower deck.
With the engine off and something comfortable to lie on, use a flashlight and mirror to have a look.
Reply as a COMMENT to this post for more discussion.
Cheers.
Jan 25, 2016 | Husqvarna RZ4222F 42" 22HP Zero Turn Lawn...
How do you lock differential?
The locking is automatic:
Husqvarna riding lawn mowers, lawn tractors, garden tractors
www.husqvarna.com/us/products/riding-lawn-mowers/
Husqvarna GroupThe available, electronic or automatic locking rear differential increases ... forHusqvarna lawn and garden tractors, you are ready for every season. ... Why use your ride-on mower only for lawn mowing, when it has the capability to do so much more. ...Kawasaki V-Twin engine; Fast hydrostatic transmission; Cruise control ...
Husqvarna Riding Lawn Mowers YT48XLS CARB
www.husqvarna.com/us/products/.../960430205/
Husqvarna GroupBy using this site, you agree to our use of cookies. Learn more. Got it. Close .... Wedeveloped our LS series yard tractors with the discriminating landowner in mind. Engineered for added ... Automatic locking rear differential increases traction while cutting wet grass or on slopes. ..... WORKING FAST WHILE STAYING SAFE.
Husqvarna Riding Lawn Mowers GT54LS
Dec 06, 2015 | Husqvarna Fast Tractor YTH24V48 48" 24HP...
What would cause my mower to not move in reverse at all?
Transmission if it's a hydrostatic... a belt... or a pulley issue... is the gear selector going all the way back to engage reverse?...
Only other way I can give you a more accurate answer is with a make and model. There are too many kinds of riders and with all different set ups... thanks
Oct 10, 2015 | Husqvarna YTH22V46 46 inch 22 HP Briggs &...
WHEN I MAKE A RIGHT TURN WITH MY HUSQVARNA RZ5424 IT JUST MAKES A GRINDING NOISE AND DOES NOT GO WHAT COULD BE MY PROBLEM?
Where is the grinding sound coming from??? Could be your hydrostatic transmission. When one side goes the other will follow... Time for a new mower... Mine lasted 3 years...
Jul 29, 2014 | Husqvarna Rz5424 Zero Turn Lawn Mower...
Husqvarna Riding Lawn Mower Problem
sounds like a linkage problem or the valve in the trans some older ones had a problem with a roll pin inside the trans falls out of place cheap fix but a lot of time to pull the trans out and apart
Jul 12, 2012 | Garden
I started my ride on and it will not go forward or in reverse at all.The lock is off so it should be working..any ideas?
if you scroll through these lawn tractor questions, you will note a lot of failed hydrostatic transmissions in the husqvarna line. seems like that is the prime suspect in your problem, if the drive belt is good. i had one and the transmission failed after about 5 years, but I see many with fewer years of wear
with the same problem. a new transmission costs about half of what a new tractor costs. these are actually made by the AYP company which pays a licensing fee to husqvarna to use the name. AYP makes most of the mower lines you see in stores. my neighbor has a craftsman with a bad deck which seemed identical to the husqvarna, except color. However when i went to cannibalize his transmission it was completely different and would not bolt into mine, so i went out and bought a simplicity.
Jul 27, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Lawn tractor won't go forward or reverse
If the engine is running normally and the drive belt between the engine and the transmission is in good shape, most likely you have a failed hydrostatic transmission.
Sep 05, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Yard Machines - Won't shift into gear
The problem most likely is the shaft on which the interlock slides back and forth on inside the transmission. The yardmachines have a continous spinning shaft which ends in a bevel gear. The is an interlock plate which is connected to the Forward Reverse shift lever, this plate slides back and forth and either engages the forward gear or the backward gear. This shaft is most likely galled up, preventing everything from sliding the way it needs to. This is not a difficult thing to fix if you are somewhat mechanical. Disassemble the transmission and check if everything slides
Apr 22, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
247 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
