Question about Samsung Televison & Video
Im working on samsung smart inverter i change the circuit board of the unit and when im done installing the compressor not starting up. The signal says compressor error.. how can i fix it..
javswr
  • 44 Answers
SOURCE: Samsung PS42C7S Power Board
A blinking led does point to a bad power supply board! First, Look for some bad caps (capacitors) on the board. They will look bulged on the top an may be a little leaky (brownish stain).
You should be able to find a service manual @ www.manualzone.com
Buying a power board try www.shopjimmy.com or ebay!
Good luck, hope this is helpful!!!
Posted on Mar 02, 2009
  • 610 Answers
SOURCE: im having the same problem with my samsung
probably will have to call 1-800-samsung to find your nearest repair and parts center.
Posted on Nov 16, 2009
dduncan774
  • 760 Answers
SOURCE: I have a samsung smart tv and a samsung galaxy s
Reset your TV.
With the power off - use the remote and push mute + 1 + 8 + 2 + power button.
When the set turns on, you will see a menu pop up. Just hit enter on the remote and you will see Factory reset. Hit enter again and the TV will reset.
Posted on Apr 10, 2012
SOURCE: Hi, Im working as a electronic technician in a
if your problem is solve then ok otherwise call me 9915100566 kamal
i try to help you
Posted on Mar 16, 2013
gopakumarg43
  • 75581 Answers
SOURCE: how to replace the backlight inverter board on Samsung smart tv UN55ES6100F?
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Posted on Jul 03, 2015
Toshiba 50L1400uc im not getting my 55volts for leds im only getting 15 to 21 volts pic not so bright and dark bottom of pic i think its some leds gone
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 16, 2017 | Toshiba Televison & Video
Got a Samsung smart TV un40f6300afxza has a dark picture everything else works fine what can it be?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board..
Dec 06, 2016 | Samsung UN40F6300AFXZA - UN40F6300AF 40...
My Samsung smart tv has sound but no picture
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jul 25, 2016 | Samsung 5500 Series UN32F5500AF 32" LED...
LED tv backlight issue
May 17, 2016 | LG 42LN541C - 42" Class 41.9" viewab LED...
Sound works. Why did picture disappear suddenly?
http://electro-medical.blogspot.com/
Feb 26, 2016 | Samsung 55" Black UHD 4K LED Smart Curved...
My Samsung Plasma TV screen doesnt always turn on. Often I have to turn it on and off several times before the picture appears on the screen.
Feb 09, 2016 | Samsung PN50A650 49.96 in. Plasma HDTV
I have a Samsung smart tv that has no picture. I can barely see it with a flashlight. I have sound. I changed out all 3 boards and still no picture. Any suggestions?
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sep 18, 2015 | Samsung Televison & Video
Hi i have a samsung ue40c8000, im getting problem where the left half of the screen goes all fussy with a bad picture but the right side is fine. If you tap the tv it goes back to normal again. Ive changed...
Sep 05, 2017 | Televison & Video
Candy cpca240ffk compressor running.
i don't have a diagram but im familiar with that problem its either a bad relay on the compressor a bad thermal over load in the relay box mounted on the compressor terminals or a bad compressor don't know where you live im in usa here you can get an after market relay with a start capacitor and if its not the compressor will fix the problem
Jan 10, 2008 | Candy CPCA240FFK Bottom Freezer...
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
