Question about Husqvarna Garden
A loud noise on fuel husqvarna lawn mower. Machine 3 months old
  • Husqvarna Master
  • 2,478 Answers
Call the place you brought unit. Should under warreny
Posted on Dec 10, 2016
nobby63
  • 10 Answers
SOURCE: lawn mower stalls when engine is hot
first thing is to check that plug is not fowling up when hot due to motor burning to much oil.
Posted on Jul 26, 2009
  • 110 Answers
SOURCE: lawn mower keeps dying
Remove gas cap. If mower now runs without stalling, your problem is the vent in the gas cap is blocked. Replace the cap. Common problem!
Posted on Sep 22, 2009
  • 3 Answers
SOURCE: Webb Diplomat 350 Petrol Lawn Mower stops running 10 minutes
The 'DIPLOMAT' series of WEBBs is bad news, its NOT a WEBB! Webb were swallowed by qualcast-atco-suffolk, who dunped Webbs tooling, & dressed up punches & commodores in thin disguises, dumped the briggs & stratten engine for their own alloy job, & charged a rip off premium for the Webb decals!
The qualcast suffolk alloy engine suffers from a WIPAC electronic ignition unit. As it gets old, it fails, sometimes completely, sometimes as it warms up. Once cool, it works for a while again.
Not too hard to replace, but hard on the wallet, £69 genuine, £40 fake! On the whole its not too bad an engine if cared for & oil changed often. better to look on ebay for a cheap used HONDA engine & transplant! R-E-L-I-A-B-L-E !............I did! ( £35 honda gc series, 5,5hp! )
Posted on Apr 02, 2010
Testimonial: "Thanks very useful information.....Many Thanks"
RonInFla
  • 86 Answers
SOURCE: Troy Bilt lawn mower used months 2009 will not
stale gas in carburator...take the screw out of the bottom of the carb and let the gas run out...
Posted on Apr 18, 2010
  • 3 Answers
SOURCE: old snapper riding lawn mower with the handlebars
Usually the drive disc . Look under mower at rear, you will see a wheel with rubber ring on outside diameter. I think, it is four small bolts holding it on. Take off and replace, will usually solve problem.
Posted on Apr 25, 2010
The noise while reversing the husqvarna lawn mower is from the gear box. Machine 3 months old
The transmission needs to be removed and disassembled for inspection. This should fall under the warranty period.
Dec 08, 2016 | Husqvarna Garden
Changed blade belt on husqvarna cth194 had difficulty restarting engine but got it going. When blades engaged going uphill lawnmower starts to struggle and threatens to cut out. this is a two month old...
I do not think this is a belt issue, i had some problems like this, it turned out to be a fuel issue, with the fuel tank completley full it was ok, as the fuel level became lower the mower stalled, the problem was the fuel tank did not have enough fall for gravity to allow the fuel into the carb, we ended up fitting an electric fuel pump.
Aug 10, 2013 | Husqvarna Garden
Husqvarna YTH1842 stops running when hot
Try slackening the fuel filer cap, if the breather is blocked in the cap it will vacume and stop the fuel from flowing, if it runs ok with the cap loose replace the cap.
May 18, 2013 | Husqvarna Garden
Speed of the lawn mower governor is missadjusted
The engine revs are turned down to make the machine noise compliant, increasing the revs will greatly increase the noise, the engine revs shouold not realy be increased, however a dealer with a suitable engine taco may do it for you, it is very important not too over speed the engine or it will self destruct,
Apr 11, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
Starting
Pull the air cleaner and check for obstructions, dirt, oil etc.
Leave off and try to start.
Check plug for oil or wetness from fuel. Have a spare handy to check for spark.
A shot of instant start into the air cleaner housing might help if the mower has bad or old fuel. You should drain the fuel out if it over a month old and unpreserved.
Also, if the mower has been sitting with fuel in it the main jet sometimes gets clogged up due to todays alcohol enhanced fuels. You should get some help with removing the main jet and cleaning it out.
Jan 19, 2013 | Husqvarna Rear Propelled Rear Bag Lawn...
Made loud noise than just quit
remove the cylinder head and rotate the engine over
Sep 17, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
WHAT CAUSES METAL ON METAL GRINDING NOISE IN HUSQVARNA 173CC MODEL 917 MOWER AND HOW TO FIX
I would check any pulleys if self propelled and the rotation of the blade as well. I had one recently that made the same noise and it was just a rock stuck on a pulley. Hope this helps!
Jun 12, 2012 | Garden
How to reset oil change indicator on my husqvarna riding lawn mower
depends on how old the mower is, for the past 3-4 years, Husqvarna made it so that you have to replace the unit, unable to just reset it.
Jul 02, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
What is fuel oil mix for the 136
Page 8 of your manual says 40:1 (3.2oz/1gal) Stihl or Husqvarna 2 cycle oil.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 3 months old use up in a 4 cycle engine. HTH
Lou
Oct 30, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
57 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
