I'm trying to configuration of my router 192.168.1.18
  • Brett Duxbury
    Brett Duxbury Dec 08, 2016
    Hi David , we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    Do you have the user name and password for the admin login to the router ?
    What is the make and model number of the router ?
    Did you try logging into the router from a browser by typing in the router ip address into the url address box of the router .?
    What are you trying to config ?
Hi, I have bought a new router DIR 600 and while I am trying to configure it as per the manual it shows this router can not be configured.I am using "du" internet connection in Dubai.Can u...
In the case of configuring router first u have to configure your computer as the same ip of router it mean the default address of router is 192.168.0.1 or 192.168.1.1. you have to configure your computer as 192.168.1.*** or 192.168.0.**** then u have to connect router into computer. In the explore address menu just put the address of router then u can get the router home page If it does not work again then once reset the router (manually reset router)
Sep 04, 2011 | D-Link DIR-600 Router
Hi, so there was a lightning storm last night and after a big crash of thunder the internet went down. It came back on but died on me again. My belkin router will blink green and stay solid for a few sec...
Hold down the power button for approximantly 45 seconds it should turn orange then back to solid green.then Get on your computer and see if there is any way you can connect. I hope that i could help. If not, please let me know.
May 28, 2011 | Belkin Computers & Internet
I have a wrt310n router and cannot get internet connectivity when trying to configure a wn2000rpt
is your wn2000rpt connected to the wrt310n or the modem? are you using DSL modem? if so you may need to call in DSL service provider to configure something on their side first. for router configuration, you need to use static IP on your computer in the same subnet of the default IP address of your router. did you configure it yet? if you already get in the configuration page, then try to use DHCP only on one router. if you are using DSL modem then you might need to choose PPPoE as the connection type. Then check the cable and reboot your computer. If your computer is configured as receiving DHCP IP address then make sure there is a DHCP on your router. Anyway, if you tell me the details of your modem and router make, model and connection and the operating system on your computer I can tell you more.
Apr 23, 2011 | Computers & Internet
Wireless Router suddenly stopped working.
Try resetting the Linksys back to the factory defaults and configure it again.
Power up the router and press the pinhole RESET button on the back of the router for 30 sec
Connect a LAN cable to the wireless router and open a browser and enter to router's configuration IP address and configure the wireless settings, remove the LAN cable when configuration is completed.
You need to configure then wireless card in the computer/laptop with the router's wireless settings.
Dec 10, 2009 | Linksys Wireless-G Broadband Router
Computer wont recognize cable hookup
You will have to start the configuration from the wired network rather than the wireless network. Connect the computer directly to the router. I am assuming you might be trying to configure the router from the wireless network. Then use the installation CD to configure the router
Nov 29, 2009 | Computers & Internet
Trying to switch routers, can't get into new Netgear to configure
To configure it you can simply contect a pc to one of its rj45 port. it will give the pc an ip address in a default range. but the must have its network connection configured to receive ip automatically.
See the status of the pc LAN connection and note the gateway ip address. then type this ip in your explore address bar to access the configuration page / program of the router.
Hope that help.
Mar 16, 2009 | NetGear RangeMax WPN824 Wireless Router...
Unable to access DLink WBR 2310 Configuration page
At the back of the router is a tiny pinhole. Using a pen try to press it for 15 secs and try to access the page using the 192.168.0.1
Jan 02, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
Aug 10, 2008 | Cnet CWR-854 Router
Configuring
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router and repeat the same steps.
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username (email address format) and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix
Jul 10, 2008 | Edimax BR-6104K Router (br6104k)
Restoring former router settings
Is there any way you could possibly delete these save files?
Try restarting it by pressing and holding the button on the back of the router for 30 seconds/
Mar 22, 2008 | Siemens Efficient Networks SpeedStream...
Computers & Internet Logo
David Payne
David Payne
