Secondary remote control keeps reverting to TV 1 after awhile having been set on TV 2 Can anyone provide insight as it is quite annoying
SOURCE: toshiba 35a44
I contacted Toshiba and they said to turn unplug the TV for at least a minute, if that didn't reset it, then they gave me a service to contact. So I unplugged the TV when I was going to be gone all day, and tried it when I got home, no change at all. I had a repairman come by and he said the problem were the buttons on the TV that had to be replaced. He quoted me $240/labor and $5 for each button to replace (7), considering I only paid about $500 for the TV in December of 2004, I decided to just get a new tv with a warranty. I ended up getting the LG LCD Tv.
Posted on Aug 02, 2008
toddg
  • 171 Answers
SOURCE: REMOTE CONTROL
If you're lucky it will respond to code 10178, if not then you will need a rc64 directv remote and try the proview codes. The proview codes are worthless in any other directv remote other then the rc64 series.
Posted on Oct 04, 2008
SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Posted on Mar 13, 2009
SOURCE: Dish 20.0 IR Remote works for awhile then it
I MAY have a solution!! We too have the VIP722 Dish Network receiver. Ours is the "K" model. I called the place where we purchased the TV and they said that the "brightness" on the TV may need to be turned down. He walked me through this, and it worked. The remote WORKS now!! Our TV is a 40" Sony Bravia that we purchased a couple of months ago. Evidently at night, the TV was so bright in the room, it interfered with the Infared Remote control. By turning down "off" brightness detector on the TV, the IR remote was able to send the signal to the receiver. Our TV is on a cabinet and the receiver is directly underneath on a shelf. I hope this solves your problem and anyone else's that may have this problem with the remote.
Posted on Mar 18, 2009
SOURCE: Need remote control code for ATT U-verse
well i have a vizio 32' lcd hdtv and the code 1343 worked for me!! the 922 didnt.....1343
Posted on Nov 09, 2009
Anyone know Insight Communications R/C codes for a GPX TV? GPX TV/DVD Combo Model: TDE3253B and Insight's Remote Model: M2067BX3
It will be best to lead you to these sites, I thinks. Check. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option
Sep 22, 2013 | Televison & Video
My AT&T U-Verse remote control is not responding anytime I click it. Does anyone have a solution?
Hi Yoav! The AT&T remote control from U-Verse can be quite buggy sometimes-- trust me when I say you're not alone.
Thankfully, the fix is quite simple and should only take you a couple of minutes. If this doesn't work you need to get a replacement remote.
All you have to do is turn your receiver off, keep it off for about a minute, and turn it back on again. For whatever reason the U-Verse remote and your cable box will intermittently lose the ability to interact with one another, but going through this type of "soft reset" will usually solve the problem.
I know AT&T has had this issue for awhile but it looks like they haven't been able to solve it yet. Big surprise right?!?!
Mar 01, 2012 | AT&T UVerse
How do i unlock the panel lock on samsung portable combi tv vhs model no:TE-14N5
Hello
Unlocking your Samsung TV requires access to the Samsung TV service menu, which will allow you to reset or remove any previous lock in the settings. In order to unlock your Samsung TV you will need your remote control. All you have to do is simply follow the instructions provided below and you can use the service menu to guide you from there. Also note that upon entering the Service Menu, all User Menu settings will revert to factory default
Steps To Unlock A Samsung TV 1. Turn the power off.
2. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
3. You should now see the service menu. To exit the Service Menu always select RESET.
You must have its orginal remote control with you to perform these functions. If you haven't it with you, contact Samsung Electronics at your country.
OK.
Jan 07, 2011 | Samsung CXJ1352 13 in. TV/VCR Combo
My tv keeps reverting to the Philips TV Menu
If that TV has a 'menu' button on the front of the set, make sure nothing like coca-cola has spilled into where that switch is located. I would try a different remote in case the remote is getting flaky....
Oct 21, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
How do u program Bush DFTA13HD STB TV buttons
The following is an extract from the Bush DFTA13HD/ DFTA13HDSIL user manual, page 9;
1. Press STUDY key until Red LED remains lit (for about 3 seconds)
2. Point Converter (Bush) remote control to TV remote control directly, keep the distance about 1~3cm
3. Press the "Power" key at TV/s remote control to send signal to Converter remote control. The LED light will flash till steady. Then press "Power" key at Converter remote control. It will record the signal.
4. Now the Power key can turn on/off TV/s power
5. Repeat settings of learning for the other keys
You can repeat Step 3-4 for setting of learning for the other keys at TV remote control, such as VOL /-, CH /-, and F1, F2 are reserved for any other keys you want to set up.
Note:
1. When you have finished setting the learning keys, press the STUDY key to leave the learning status, and the LED light will turn off.
2. The learning function of this remote control may not support all types of TV sets, if you still can not control your TV after you have attempted the above steps, then this remote control may not support your TV or its remote control.
Jul 19, 2009 | Televison & Video
Set TV Code for Yamaha Remote RAV-290
Do any experts know the answer to this question? It has been posted multiple times, but I dont' see any answers! It is a pitiful manual that is provided by Yamaha for this purpose and nothing is intuitive about making this work. If anyone know the answer, PLEASE POST IT!
Jul 12, 2009 | Yamaha RAV-300 Remote Control
Cant get the dmtech lq17xts tv's freeview to work
General reset procedure for DM tech is:
1. Have Analogue station showing,
2. Press display button on remote,
3. With display info panel in view on screen, press 1 1 Line buttons on remote, this should bring up reset menu on left hand side of screen.
4. use up/down arrow buttons on remote to select either Reset or EEPROM then use right arrow button on remote to select the appropriate procedure
NB - on my set, selecting OFF the annoying melody that plays when the TV is turned ON/OFF diasbles Digital TV (Freeview). Turning ON the annoying melody makes DigiTV work again!
Jun 24, 2009 | Televison & Video
RCA RCR311B Remote Control
if It is similar to most RCA universal remotes, to get the code follow these steps(Manual code search MAy take awhile):
1:Manualy turn on the component that u want to control
2: press and hold the component key (ie TV) while holding TV press ON-OFF key(button) for three seconds until all of the components light up and release the keys(button).
3: keep pressing ON-OFF key until your component turns off.(Note may take awhile)
4: one the correct code is found hit the STOP key and it will save your component IF YOU DO NOT HIT THE STOP KEY THE CORRECT CODE WILL NOT BE STORED.
Hope this works
Oct 26, 2008 | RCA 3-Device Universal Remote
REMOTE OPERATION
Looks like a common frequency and coding problem. Try to keep the TV and Cable box far away and try the remote. If it works, then, escalate to Cable operator for providing a new box with remote or ask for a different brand of cable box.
Jun 10, 2008 | Protron PLTV-37 37 in. LCD Television
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
