Question about Grundig Audio Players & Recorders
Grundig fine arts mod no UMs17MD plays & then shuts itself off.
Grundig s350, installed new batteries and radio keeps shutting off by itself
When you press the Power/Sleep button the radio turns on and displays a number 90, or some other numbers. This is the play time that the radio will stay on then turns itself off. It could be that yours is configured with a sleep timer set to 01 minute, 10 or 15. You need to set the timer for a longer period. Thus we turn it on by pressing the Power/Sleep button, read the timer length then press again. Keep making short presses: The timer will cycle through all preset sleep timer durations. Select the length you want.
Jun 19, 2011 | Grundig S350 AM/FM/SW Radio
My ten year old Grundig Yacht Boy-------------------------------------------------------------------------------- When I play it on battery, it's fine. When I try to play it via an electric plug in the...
Probably more than $40 and that is the buy it now price on eBay at this link:
Note that the opening price is only $25. Suggest you get a "new" used radio as a cost effective option. Alternative: buy (now relatively inexpensive) NiMH rechargeable batteries and run your P2000 on them.
Apr 04, 2011 | Grundig Yacht Boy P2000 AM/FM/SW Radio
My radio won't stay locked onto a station. When I push a pre programmed station like 107.3 it plays for a little while than randomly switches to 107.1 or 107.5.....and goes back and forth every few...
i have a funny feeling its the aerial but it could also be a faulty chip within the set itself i have had customers complaining of this before with certain makes of radio ,never get it with a grundig or bleupoint though
Mar 22, 2011 | 2003 Pontiac Montana
Hi,I've been playing sims3 for awhile but 2 days ago I uninstalled it because some of the mods wheren't working properly.Nothing big I just figured I would reinstall the game.Anyways when I try to insatll...
You'll need to do the uninstallation first, then find the map the game used to be in, delete the whole map (so the mods are uninstalled too) and the install the game again.
Dec 08, 2009 | EA - Electronic Arts Sims: Complete...
My Grundig tv turns itself off
Its Probably overheated.
happened to me before then i took to fixers and they changed some part and now its fine or if u have a warrenty call the manafactuarer
Dec 13, 2008 | Proton MM2701VT 27" TV
Failure of radio to turn on
It sounds like a component on the circuit board is heating up. Open the radio up and check if anything is overheating, if so replace the defective part.
Jun 20, 2007 | Grundig S350 AM/FM/SW Radio
Portable Grundig TV/vcr combo - screen goes blue and then set switches off.
Hi mcloud Your problem is your video circuit.the component could be faulty or it has lose solder.have a tech look on your set for repairs.good luck.
Apr 25, 2007 | Grundig GF70-600 TV
Loses sound
It is soppoused to seek when pressing search and scan and scan buttons If you dont like the idea of that for now on only use tuning up and down dial or buttons.
Nov 20, 2006 | Grundig Satellit 800 AM/FM/SW Radio
116 people viewed this question
Top Grundig Audio Players & Recorders Experts
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
