I want to know the function of that port at the back of LCD TV 22"
  • kakima Dec 08, 2016
    Hi Langson Lungu, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
UUuuhh how do i send photos
You TV will not be able to send photos, as it has limited functions and is not set to work as a full computer. You however can view (receive photos for viewing on the tv screen.) If your TV has a USB port, you can transfer your photos from your computer or camera to a thumb drive (A USB memory storage stick) which you then can plug into the USB port on your tv.
There are other ways to send photos to your tv, but there is not space here to get into how to do that.
Nov 05, 2014 | Vizio M220nv 22-inch Full Hd 1080p Led Lcd...
I need file for upgrade firmware daewoo lcd tv 32" chassis sl-602m/p
Please check the site linked here. It has details you want to know. It is very difficult to include all details here by this window, as it has illustrations with descriptions. Check the site with patience. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Timeslide option.
Jul 11, 2013 | Daewoo DLT22W4T 22 in. LCD TV
22" flatscreen LCD Westinghouse TV.
try use a lowest resollucion 720p and after change to 1080
Sep 20, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
Hello , My TV is 42PFL7422 LCD , The problem is oprating function change itselfs and also chanel TV with AV port. How to stop it Thank you
he problem of your TV is the button of the channel will not getting back so channel can't stop
you have to do is replace the button if you will or use a remote control to access the channel and never use manual changing channel again
Mar 09, 2011 | Philips 42PFL7422D 42 in. LCD TV
How to connect laptop to my coby tv?
Check if you have an HDMI or VGA/DVI port in your LCD TV and LAPTOP. Once you have those ports you can just buy an HDMI cable or VGA/DVI cable to plug it to your laptop.
Jan 31, 2011 | Coby TFTV2225 22 in LCD TV
Just tried to hook my aoc 22" to high definition
I beleive you have to enable audio in the HDMI SETUP so it will send the digital audio through HDMI ports, check the cable box and the TV HDMI sound setup.
Nov 19, 2010 | AOC L22W861 22 in. LCD HDTV
Can't shut the tv off with remote or button on side of tv?
Ur remote might be dead.Ur remote other functions works?Try website 1-800-Remotes Factory original to buy an exact remote.Very common on remotes some functions work,other dead.
Feb 23, 2010 | ViewSonic N2230w 22 in. LCD TV
Where does the hdmi cable go on my tv
If you have an HDMI tv, and just because it is a wide screen does not me it is High Definition or HDMI compatible, you will normally find the connector on the back marked HDMI.
Not knowing what TV you have, I can't really tell if it is HDMI compatible or not, but you will know by the shape of the connector if it is.
Aug 27, 2009 | Televison & Video
I have a 19" Genesis LCD TV and I need the Remote Control Code
I have a 22" genesis LCD and can not get my Direct tv remote to work?
Jul 08, 2009 | RCA Universal Remote Control
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
