Question about Vizio Televison & Video
Apologies!! By trying to delete duplicate message, both were deleted. 5yr old 55" Vizio LED loses sound after 10-20 min. Both speakers & AV jacks. Both cable and dvd.
Software reset. Cables changed. Main board? Power supply board? Cannot find Audio board listed. ShopJimmy, Vizio, and VizParts no help. Please suggestions.
    Top Expert:
  • Vizio Master
  • 75,032 Answers
Check and replace the damaged component/s at its audio output section circuit. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Dec 26, 2016
Vizio 42 inch smart tv Model # M420sv
You have to check the audio settings of your tv. There would be n option which allow you to choose the option between internal speakers or external speaker. You have to choose it as external speakers of amplifier.
If you wish to get some more details then check the following link
Jul 22, 2016 | Vizio M420sv 42 Inch Class Edge Lit Razor...
How do I fix a 55" Vizio smart TV
Fuses but try one of those neiborhood fixers their cheaper for that piece
Mar 20, 2016 | Vizio 55" Class LED 1080p 120Hz HDTV,2.49"...
Does sound bar connect to AV-IN?
This is an old post, but I will answer just in case the owner has never gotten his answer.
This model TV has a 1/8th inch headphone jack. You will need a converter cable that converts from 1/8th inch stereo to dual left and right RCA connectors. Get one of sufficient length to reach from your TV to the soundbar and you should be good to go.
Feb 23, 2014 | RCA PLED2435A - Proscan 24 LED 1080p 60hz...
1.5 year old Vizio 55" M550SV now has color vertical lines edge to edge. Audio ok. Image here: Likely cause. Happened after first cold night. Worked ok first 10 mins,...
it looks like the panel is going bad or the main board. try to change the main board if that does not fix your problem the panel is bad. open the tv and get the main board part number and look for it on ebay.
Oct 24, 2013 | Vizio 55" M550SV 1080p 240Hz Widescreen...
I have a viz e550vl good pic no sound at all no matter what i do, tried unplug tv hold power button for 10 sec. any help please thanks
have you been already check the speaker does it good?. if ok, tried to hooked up a powered pc speaker at the audio output jack of the tv. turn on, if you can get sound there the cause it would be bad amplifier circuit but if you can not get sound from there you have bad sound processor at the board.
Oct 02, 2012 | Vizio E550VL 55 in. LCD HDTV
LCD TV Has Sound, Backlights Work, but No Picture
I have been having the same problem with my LG. people say there are bad capacitors on the power supply board. I don't have the know how to replace them and don't have the money to pay. I can get mine to work by blowing hot air with a hair dryer into the back of my tv through the vents over the board. Heat it up for a couple minutes and turn it off and then back on and the picture comes back. I just never turn the set off now.
Sep 08, 2012 | Vizio M550sv 55 Inch Class Edge Lit Razor...
No sound from speakers but audio out from rc jacks work is this a main board problem?
Either loose wire or bad speakers. If it was a main board problem then the audio out wouldn't work either.
Oct 16, 2011 | Vizio VF550M 55 in. LCD HDTV
I have no sound on my Vizio 55" hdtv
Let verify first to narrow down to where the problem can be. First, make sure the MUTE function is not activated, then check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Aug 12, 2010 | Vizio VF551XVT 55 in. HDTV
Audio buzzing
check where your pluging the red sounds like your pluging a video signal into an audio jack or your red cable ha an open ground
Dec 22, 2009 | Vizio L37 Television
Televison & Video Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
