Question about Pitco Frialator 45C Deep Fryer
When placng seafood in fryer at work a foam quickly forms and rises to the top of the fryer. What's causing this and how can I change this?
    President:
  • 1,185 Answers
The seafood contains water, the water reacts with the oil and causes the bubbling.
Try placing the seafood onto some absorbent paper for a few minutes before adding it to the fryer.
Or try dunking it in to seal it for a few seconds before you fry it off
Posted on Jul 20, 2009
Does anyone know how I can obtain a manual for a Masterbuilt Turkey Fryer & Seafood Kettle combo cooker?
Here's a manual for one of the older models. They are all fairly similar. Note the cleverly hidden reset button in the handle, most Masterbuilt fryers have one and frequently it is the only thing wrong!
https://www.appliancefactoryparts.com/content/pdfs/137637-1.pdf
Nov 27, 2015 | Masterbuilt Grilling
How big of turkey will a Morrone TKF 300 A turkey fryer cook.
Turkey Fryer is deep enough to fry a 12 to 14 pound turkey and wide enough to be used as a seafood boiler. Heating element is made of stainless steel. It comes with aluminum bailing basket with adjustable quick drain system, control with safety shut-off and a built in digital control with thermostat and timer. Swing out drain valve for easy draining and clean up. CSA certified.
Deep enough to fry a 12 to 14 pound turkey and wide enough to use as a seafood boiler, the Cajun Injector's Electric Turkey Fryer provides home fried cooking without the mess and hassle of stove top or outdoor methods. Equipped with a 30Qt. aluminum bailing-basket, you can submerge and fry a whole turkey or any other foods you'd like to cook fully covered. When the food is finished cooking, simply lift the basket up with the hanger hook, and allow it to drain over the pan with the adjustable quick drain system. A swing-out drain valve to empties the used oil when its time for clean up and a built-in digital control with a thermostat and timer ensures that the food cooks exactly as you intended. The CSA certified fryer features a clear lid so that you can check on the food without risk of burning and is equipped with a stainless steel heating element for long lasting quality.
Oct 21, 2014 | Grilling
What is causing my imperial fryer to burn my fries when the thermostat se at 300 this wasb not happening before
Sounds like your thermostat is not calibrated properly. this is a job for a pro. If you don't do this correctly the grease temps can rise above safe levels and cause the high limit to open.
Jul 11, 2014 | Imperial IFS40 Deep Fryer
My oil is foaming up. Changed oil and cleaned well but still foaming up. I am using the same oil as always and never happened before. {This happened after changing the thermalcoupling.
Hi there.
Oil foaming is caused by water, saturated oil itself and/ or overloaded product. Make sure your fryer does not have any of the things mentioned above.
Try performing tank boil out to ensure the cleanliness of the fry tank.
Regards.
Oct 08, 2013 | DCS Kitchen Appliances - Others
What are foam mattresses?
Foam mattresses are made of several layers of foam to help cradle your body. There are two types of foam mattresses: memory and latex. Memory foam mattresses are denser and are quite supportive. They are made of temperature sensitive foam which mold quickly to your body. Latex foam mattresses breathe better and are naturally hypo-allergenic. Latex foam mattresses can easily form to your bodies contours but lacks memory impressions.
Jul 25, 2012 | Furniture
Automatic shutoff red ball in recovery tank rises to top when recovery tank is about 20% full.Thus we are only able to use the steam cleaner for about 2 minutes before having to empty the recovery tank....
Your cleaner should have a foam sock around the float cage in the recovery tank. Remove the foam sock and rinse it out with clean water. If these are very dirty, they may cause the airflow to be disrupted, causing the float to raise prematurely.
Oct 29, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
The freezer temperature changes sporadicaly. It
The temperature would charge due to change of cycles in the refrigerator operation. For example, the temperature would slowly rise if the compressor has shut off. Also, the temperature would rise significantly during the defrost process. A heater is activated at the evaporator coil to thaw the ice that forms there. This heat would transfer to the freezer unit and would cause the temperature to go up.
As long as the cycles are constant, and the temperature does not rise significantly and keep rising for a long period, there is no problem.
Oct 19, 2009 | Refrigerators
Oil foams after putting foodin. new oil help
The product that you put in the oil should be room temp,if not this will happen.
Apr 19, 2009 | Oster ODF520 Fry Right Deep Fryer
Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Aug 29, 2008 | Zanussi ZI921 / 8FF Bottom Freezer...
Boiling oil seeping from tefal deep fat fryer
check where the thermostat or hi-limit bulbs go into the tank and see if thats where its leaking.if not you may have a cracked tank,let me know.
Dec 27, 2007 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
296 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
