Question about Motorola Mobility W490 Cellular Phone
My W490 phone screen just went white today
My W490 mobile phone also just went balnk/white. it displays in the external window but the internal screen is blank! What gives? Is this a common problem with this phone? What can be done?
Subsidy password for motorola w490
The term Subsidy Password is used by Motorola and other handset manufacturers to refer to the 8-digit (or 16-digit code for newer phones such as the Motorola K1) unlock code necessary to remove the operator lock (also known as subsidy lock) from cell phones. This code is randomly assigned to individual cell phones by the OEM on request of the mobile service operator and prevents the use of a particular phone on a cellular network other than that to which the phone was originally sold.
To get the Subsidy code You can reach here
Mobileunlocksolutions.com enter the code correctly following the instructions below:
Warning : Do not enter any wrong unlock codes on your Motorola W490 mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola W490 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola W490 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola W490 is locked to.
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
Aug 24, 2011 | Motorola Mobility SLVR L7 Cellular Phone
I have a motorola w490 my screen has went white
Unfortunately it's "PROBABLY" time for a new phone.
I had a W490 as well as a friend of mine that did the very same thing.
For us it was the beggining of the end for an otherwise great phone.
Sorry
Dec 26, 2010 | Motorola Mobility W490 Cellular Phone
White screen
dear,
the strip that connects the keypad with the other circuitry is damaged. you need to repair it or replace it...it will be checked by an expert technician of mobile that either it is to be replaced or repaired...
flip and slide mobile have this kind of problem..moreover, it depends upon the usage of phone for flip/slide...
dont use it roughly, next time , it needs a lot of care..
goodluck..
Sep 04, 2009 | Motorola Mobility W490 Cellular Phone
Whote Scrren on the W490.
your unit is rebooting and needs software.
Jul 12, 2009 | Motorola Mobility W490 Cellular Phone
I fell on my phone, and the screen just went white.
it means that your phones internal circuitry and programming is still working, but by the sounds of it, the screen or lcd display is broken sorry, take it to a mobile repair shop so they can actually have a look at it for you.
Brett
Jun 22, 2009 | Nokia 6111 Cellular Phone
W490 recieved minor water damage, now screen stays white!
you need to have the phone service seeing that the phone has came in contact with water, also you will need to have the LCD replaced on the phone.
Jun 06, 2009 | Motorola Mobility W490 Cellular Phone
The screen freezes when the phone is flipped open.
You didnt mention what phone it is??? However as you said it happens when you flip it open, it is most likely the flex that connects your phone main PCB to the LCD display...
All flip handsets have a flex ribbon, which connects the screen to the phone, a tiny tear or even a kink in these can cause the behaviour you explained, it can be anything from No display, to no sound, no camera, etc... depending on the phone...
Try replacing the flex ribbon
May 08, 2009 | Motorola Mobility W490 Cellular Phone
Phone screen goes blank to a grey color (externallY) .
same problem, broke my screen, ordered a new screen off ebay and replaced it. now it works fine most of the time but sometimes external display freezes. sometimes goes black, sometimes goes multicolor pixelated (full screen, in blocks, or lines) when this happens sometimes touchpad still works, others not. removing battery usualy temporarily fixes.
Mar 09, 2009 | LG VOYAGER VX10000 Cellular Phone
White screen, key pad locks up Moto W490
Update the software for your phone for free.
Click on the following link:
http://direct.motorola.com/hellomoto/support/update/
Oct 24, 2008 | Cell Phones
RAZR V3C Display Problem
you may have to get the flexcable or the lcd replaced take the mobile to a mobile service center or a mobile tech and have them check your mobile.
Aug 25, 2007 | Motorola Mobility RAZR V3
Motorola Mobility W490 Cellular Phone Logo
556 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
