Question about Dryers
My dryer will stare run for q well and then stop. The fracker not tried but if I unplug and replug it will start again?
  • Dryers Master
  • 5,323 Answers
IT IS GAS OR ELECTRIC? DOES IT RUN FOR A FEW MINUTES, SECONDS OR 20 MINUTES? COULD BE BAD MOTOR WINDINGS, OR VERY BAD OR CLOGGED VENT SYSTEM LINES.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
my dryer will stare run for q well and then stop.  - 26390626-bszy215dbxllk1sw2ym4qmfg-4-0.jpg
26390626-bszy215dbxllk1sw2ym4qmfg-4-2.jpg my dryer will stare run for q well and then stop. - 26390626-bszy215dbxllk1sw2ym4qmfg-4-5.jpgt/uploads/images/26390626-bszy215dbxllk1sw2ym4qmfg-4-5.jpg" alt="26390626-bszy215dbxllk1sw2ym4qmfg-4-5.jpg" class="h_mi" />
my dryer will stare run for q well and then stop. - 26390626-bszy215dbxllk1sw2ym4qmfg-4-20.jpgmages/26390626-bszy215dbxllk1sw2ym4qmfg-4-14.jpg" alt="26390626-bszy215dbxllk1sw2ym4qmfg-4-14.jpg" class="h_mi" />
Posted on Dec 08, 2016
Frigidair galaxy electric dryer comes on for a few seconds and shuts right back off error code reads PF
PF means Power Failure,try unplugging the unit for 20 minutes to possibly clear the computer control inside the unit,then try starting it again,if this doesnt help try unplugging and replugging in all connections in case theres a bad connection,lastly if this doesnt solve it,replace the control board
Feb 12, 2012 | Frigidaire Dryers
Dryer buttons light up but when pressing start the dryer will not start. We have tried unplugging it and replugging, but that dont work :(
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 14, 2011 | Dryers
Dryer buzzed whenever tried to start. then refused to start again. sleaned vent and still wouldn't start. tried unpluging it and repluging it in. still won't start. think i can just push reset button but...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 21, 2010 | Dryers
Dryer will not start when I push the start button. You can hear the sound of the dryer wanting to turn on but it does not. I have already tried to unplug and replug.
If the motor is trying to start only when you have your finger on the start button but won't continue to run, the run coils in the motor might be bad. If it just buzzes (hums) when you try to start it, the start/run switch in the motor might be bad, or the starter windings might have an open. Either way, it sounds like the motor might need servicing.
Jan 02, 2010 | GE Spacemaker Washer and Dryer Electric...
I have a Whirlpool Comfort Plus II Gas Dryer that when you press the start button, it will not start. I was running last night but when my daughter went to start on a new load of clothes, the dryer would...
Try the door switch and see if it clicks to activate. Also, make sure that the dial is always turned clockwise so as to not strip the teeth. Could be the timer .
Jul 05, 2009 | Dryers
Kenmore dryer
IF THE DRYER COMES ON BY ITSELF WHEN THE TIMER IS SET AND THE DOOR IS CLOSED, THE PUSH TO START SWITCH IS SHORTED. THIS WILL CAUSE THE END OF CYCLE SIGNAL TO BUZZ WHEN THE TIMER IS IN THE OFF POSITION(END OF CYCLE).UNPLUG THE DRYER, REMOVE THE BACK PANEL OF THE CONSOLE, AND REMOVE ONE WIRE FROM THE PUSH TO START SWITCH. ISOLATE IT SO IT ISN'T TOUCHING ANYTHING AND PLUG THE DRYER BACK IN. SET THE TIMER AND CLOSE THE DOOR. IF IT DOESN'T START UP OR BUZZ, UNPLUG THE DRYER AND REATTACH THE WIRE. PLUG THE DRYER BACK IN AND SEE IF IT STARTS BY ITSELF. IF IT DOES, THE PUSH TO START SWITCH IS SHORTED AND WILL NEED REPLACED.
Apr 01, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
Top Dryers Experts
