Question about Apple iPhone Smartphone
Battery my problem is when i plug my iphone via wall socket or even usb, my phone shows charging but when i pull it off, it did not chrage at all or it wont even go to a green status. i turned it off again and still the same problem occurs. if i let my phone charge for a moment, it will show it is fully chraged but if i pull it off again, its still on the low level state... help please...
  • 4 Answers
Your battery is gone, you will need to replace a new battery because the old battery is at it age. When you get a new battery, charge it 24 hour to fully charge it before you use, it is very crucial to maintaince the life of battery
Posted on Jul 20, 2009
My panasonic Hc-v100 camcorder is not charging when plugged in to USB cable - cursor light is not flashing and battery is running down
you DON'T charge the camcorder with the usb cord,you only move files between cam and computer,you need a power cord that plugs into the wall,see pic, LETO 2A AC Power Charger Adapter USB Cord For Panasonic HC V100 HC V500 HC...
ihave the same camcorder,
Mar 24, 2015 | Video Cameras
After connecting the charger cord and plugging it into the wall socket, is the iPhone to be turned off or turned on?
If you turn it off, it will charge faster. I've done both. This morning my charge was very low. Then I noticed the plug became out of the socket. Try it both ways,see what happens. If you are charging with it on, have you closed all your apps? Double press the on/off button on the bottom front. Any open apps will appear half size. Place your finger on the app, and slide it UP and "OFF" the unit. Turn it off, try charging. Be sure your plugs are all the way in. If you try it turned off, the unit will briefly show your current charge, then turn itself off.
Sep 22, 2014 | Apple iPhone 5c
IPhone 5 was working perfectly, but when I plugged it in to charge, it didn't start charging. I could still use the phone. Now the phone died and nothing happens. Is the battery dead (as in broken)?
I would guess that you battery is fine, it is either your charger is not working or worse case your charger socket on you phone is damaged. Try connecting your iphone to your computer via the USB port and charging cable, if your phone starts to charge you know you have a problem with the plug side of your charging cable which is where your transformer is. Be aware that if your battery is totally flat it could take several minutes before you hear the beep from your phone to indicate that it is charging. If that doesn't work it could be your charging lead that is damaged so try charging with a different lead. If still no joy then you could be in trouble as the charging socket is soldered to the mother board and could be an expensive repair so fingers crossed it is only the charger that is damaged.
Jan 02, 2014 | Apple iPhone Smartphone
IPhone 3GS battery replaced, connected to itunes via USB cable and synced, battery percentage indicator showed a power plug didn't start charging. Charger removed and over night the battery seemed to have...
Is the replacement battery an original equipment battery? I bought an aftermarket battery for my Samsung and the phone will not recognize the battery even though the specs are identical. Nice trick by Samsung. See if I ever buy another product of theirs again. Anyhow try putting the old battery back in and see if it will function while plugged in. Otherwise head to the phone store.
Nov 01, 2013 | Cell Phones
My IPhone will not turn on. It suddenly went off, like it powered down, but wont turn back on after a 20 minute charge...even when still plugged into charger.
Try to connect it with you PC via usb cabal...and if your PC shows that he founds device (Iphone), you will see on Iphone screen that he is start charging...after that you can put it to electicity charging, with regular adapter and charge it for 1 hour and then turn it on and it will work :) That happens when battery lose her voltage (need to be 3,7V)...Otherwise if you PC, when you connect it does not show nothing, than you have some hardware failure and you need to take you Iphone to some mobile service to fix it..
Best Regards!
Sep 05, 2013 | Cell Phones
My iphone won't charge
Try a different cable.
Try a different power supply.
When removing your power cable from your iPhone, NEVER wiggle the cable! Always pull out in a straight line, and NEVER pull it via the cable.
Mar 25, 2012 | Apple iPhone Cell Phones
Hello, My Iphone is completely dead. The battery went down and I was about 2 months without using it. Now I'm trying to unlock it but the Itunes doesn't recognize it. The screen is black with no battery....
First, plug the iphone into the wall with your usb cable and power adaptor. Then hold down the sleep/wake button (button on top left) and the home button (bottom middle button). Keep holding those two buttons until you see the Apple logo. This should turn it back on and then charge it. If not, Genius Bar.
Mar 10, 2011 | Apple iPhone Smartphone
How do I charge my new iphone 16GB?
Your new iPhone comes with a USB cable and a wall charger in the box. If you don't have a computer, you can plug the wall charger to any socket in your house and connect your iPhone to the wall charger using the USB cable. However, if you have a computer, you can plug the USB cable to any USB slot from your computer and connect it to your iPhone.
You can also charge your device from any iPhone dock, or even those docks attached to your home theater system.
For more iPhone / iPod touch tips, click here.
Feb 12, 2010 | Apple iPhone (16 GB) Smartphone
My iphone 3g won't charge more than 10%....
it has corrosion in the charging hole or insde where the battery charging slots are
Jul 12, 2009 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
213 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
