The scanner is full. What should I do? - Office Equipment & Supplies
My Canon e510 printer scanner scans with full red background
hi . if the light is not white the image sensor unit is defective and has to be replacex
Apr 29, 2017 | Canon Office Equipment & Supplies
Why does my HP Photosmart C6150 All-in-One only prints/scans full black page
Open the scanner cover and check on you to copy double-check scanner moves when the light comes from the scanner and see if it sees the glass as if it would be messy to be opened and cleaned
Jul 22, 2014 | HP Photosmart C6150 Wireless All-in-one...
Hi there! where can I find driver for the Acer Scanner: Scan Prisa 124OUT?
You won't find a Windows 7 driver for this scanner. The solution I found was to use some third party scanner software like VueScan. VueScan provides independent driver support for the 1240UT and gives you the scanner's full functionality and more.
Sep 03, 2010 | AcerScan 1240UT Flatbed Scanner
Can you pls. suggest which PCI Xpres card support Fi-5530C2 Scanr
Hi Karthik,
Please click on the following link for recommended SCSI cards for your Fujitsu Fi-5530C2 scanner .
http://www.fujitsu.com/global/support/computing/peripheral/scanners/scsi/
Please revert for further clarification.
Thanks & regards,
TechSatya
Jul 26, 2010 | Fujitsu Office Equipment & Supplies
How do i unlock a radio shack 164 hand held scanner and how do you program the scanner
The PRO-164 is a trunking scanner with many programming options, and attempting to detail the full programming procedure here wouldn't be practical. Rather, follow this link and you can download/print the full operating manual for your scanner.
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000164_PM_EN.pdf
Nov 15, 2009 | Radio Shack Pro-97 Handheld Scanner
Symbol scanners (several models) not recognizing Code 39 Extended
The barcode must be a Code 39 barcode, not a Code 39 Extended or Full ASCII barcode. The Enable Code 39 Full ASCII must be scanned from the Symbologies section of the LS2208 Product Reference Guide (page 186 of 342). The Enable Function Key Mapping barcodes would have to be scanned if you are seeing something other than the tab happen when you scan into your application. In Word, for instance you will see the italics enable/disbled whenever the $I is encountered in the barcode.
As for the Covert to Code 39 Full ASCII- that is for Wand and Scanner emulation. The setting was having no effect because you were not connecting to either of these hosts.
Nov 20, 2008 | Symbol LS2208-7AZK0100S Handheld
k24674
jasbo
jasbo
