SOURCE: My iron doesn't steam up anymore
Time for a new iron. I last one went to the iron graveyard and I then spent $150.00 on the top of the range Phillips with the gold plate. Has cut my ironing down to a 1/4 of the time. Well worth it
SOURCE: Won't steam
The steam irons I have see have a separate button to allow water from the reservoir to enter the steam chamber. This button latches down for steam and you unlatch it for dry. Also, there is a temperature range on the temp dial for steam.
The reservoir must have water in it for the iron to make steam. If calcium from the water has built up on the reservoir valve, it may prevent the water from entering the steam chamber. Straight white vinegar instead of water may help.
SOURCE: Steam Iron
The cycling on and off of the steam iron is not abnormal. The themostat in the iron on and off the power supply to the heating element, keeping the temperature of the sole plate constant at the desired temperature. Without this on and off mechanism of the themostat, the sole plate will contiune to heat non-stop till extreme temperature.
My question to the op is how do you know if the iron is not fully heated? I suspect that you misinterpret the cycling of the iron as a defect and assumed that the iron will not fully heat up.
But in fact if the temperature of iron did not raise to expected, then it is a different issue.
SOURCE: Hi, I just got a Euro Pro Flat Iron EP470 but it
Yes... you can use it dry...
Cleaning a Steam Iron White Scale and Brown Water
http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown
heatman101
SOURCE: steam boiler iron
you can download instr. manual from www. fitness.manualsonline.com or www.retrevo.com or www.manualsfactory.com
service manual go www.pdfservicemanual.com
God bless you. However see the diagram is universal for repair small appliances.
