Question about Vacuums
Crazy fit massager panel shows err but plates do not vibrate and belt is on
2 Suggested Answers
ka4iup
  • 3957 Answers
SOURCE: Burning smell and cutting off use when using the crazy fit massage by prestige. Any advise?
Stop using immediately. There is a problem that can cause fire or electrical shock if used. Have this unit checked by a service technician.
Posted on Mar 23, 2015
How do I get to the belt on my dirt devil
On the bottom of the dirt devil have to remove cover plate with screws and replace belt on motor
Apr 20, 2015 | Dirt Devil Featherlite Bagless Vacuum...
Mar 23, 2015 | Vacuums
Hoover UH70935 windtunnel agitator spins like crazy with plate off after cleaning but will not with plate replaced.... what is going on?
If the brush roller was removed, it may have been reinstalled incorrectly, causing it to bind on the bottom plate.
Aug 08, 2014 | Hoover WindTunnel 3 Pro Pet Bagless...
I need to change the belt. How do I get it off inside the vac.
Turn the vacuum over so you are looking at the brush.Remove the screws and that plate will come off.The belt fits on the brush,in a groove.The other end of the belt fits on a small wheel about 6 inches back,form the groove on the brush.There may be another plate over the wheel.When you get the plate off the bottom you will see what I am talking about.It is not hard.
May 19, 2011 | Dirt Devil Vacuums
Revolving brush is not turning
The belt is broken.Turn the vacuum so you are looking at the brush.That palte needs to come off.Some screw and some just pop on and off.When you have the plate off lift the brush out.The belt fits in a groove on the brush.The other end of the belt fits on a small wheel about 6 inches behind the brush.Put the new belt on and replace the plate.
May 18, 2011 | Kenmore Vacuums
The brush is not rotating
The belt is broken.Turn the machine so you are looking at the brush.The plate on the bottom of the vacuum needs to come off.Most are screwed,some plates just pop on.Remove the plate and then the brush.The belt fits in a groove on the brush.The other end fits on a small wheel about 6 inches back from the brush.
May 18, 2011 | Dyson Vacuums
The beater motor will not turn. Is there a fuse? I've tried the reset, but this still doen't work. My wife smelled a burning smell and quit using.
Sounds like you need a new belt.Turn it upside down and locate the screws on the bottom.Remove those screws,and then the plate they hold on(if there are no screws then the plate will be held by clips just pull it off,carefully.The brush now may be lifted out,but before you do.The belt fits around the brush.Find which side,if the belt is broken and still in the vacuum,it should still be on the side it came from.If the belt is not still in the vacuum,there is a groove in the brush about one inch wide.That is where the belt fits.The other end of the belt fits on a small wheel about 4-5 inches back from the brush.There may be a small plate over the belt and wheel if so just remove it and you will see what I am talking about.
May 17, 2011 | Eureka Capture Upright Vacuum Vacuum
I need to know how to change the belt on a fantom xt
Turn it upside down.On the bottom where the brush is are 4 screws.Unscrew those 4 screws.Remove the plate.Now you can see the belt.There may be a second plate covering part of the belt,if so remove it too.The belt fits around the brush in a groove the same width as the belt.The other end of the belt fits on a small wheel about half way back from the brush.Put the plate back on and you are done.
May 14, 2011 | Vacuums
How do I change the belt on the motor?
Hi. This is easily done. Flip the vacuum over, beater bar up. With the machine unplugged, locate the screws or tabs that hold the base plate on, surrounding the beater bar. Remove the plate. The beater bar is held in place by fitting into sockets that then fit into the vacuum frame, so be careful in removing the beater bar. Pay close attention to the sockets, so you can get the bar assembly back in easily. Replace the belt. When you fit it over the motor shaft, you'll have to slip the belt onto the beater bar, and fit the bar into the frame at the same time. Reinstall the plate, and test your work by revolving the beater brush a bit by hand......If you're satisfied, you should be good to go!
Best regards, --W/D-- please feel free to rate this solution! Thanx!
Jul 30, 2009 | Hoover U6630-900 WindTunnel Bagless...
Dyson DC07
Hi.
Depending on wether your machine has A clutch fitted will decide how easy this job will be.
The non clutched model is very simple turn the 3 plastic screws on sole plate to unlock position lift plate off remove belt from motor shaft & lift out brush roller.
Replace belt & roller fit sole plate & its done.
The clutched version will require the removing of the sole pate,
Then remove brush roller. & brush roller housing.
Then remove clutch cover,
Replace both belts & reassemble.
Its A lot to explain in great detail so try this site if your struggling.
http://dysonmanuals.llc.nu/
Jun 18, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuums Logo
24 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
