Question about Necchi Sewing Machines
Necchi type 586 Sewing machine has lack of drive from motor through spool winder for lower thread spool, to engage /disengage needle mechanism - appears that the plastic may be worn. Spare/replacement parts?
SOURCE: necchi
Same here but found this, hope it helps you out : )
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_584_586_threading_Diagram.htm
Posted on Dec 26, 2007
SOURCE: Needle touches a metal part and makes a weird noise!
Check your bobbin...make sure the handle is pointing upward.
Posted on Apr 07, 2009
Mimito7
  • 128 Answers
SOURCE: Necchi Heavy Duty Sewing machine model 3205FA,
Generally when the needle does not pick up the bobbin thread, it means the needle is either too far in or just plain the wrong length. YOu might want to try lowering the needle just a hair and see if that helps.
Posted on Apr 22, 2009
Zenqi
  • 208 Answers
SOURCE: winding bobbin- elna
The bobbinwinder spindle is on the top of the machine on the right.
Try to turn the spindle with your fingers. If it is turning easily, good. If not, see below.
Push the spindle to the right and it should turn when the handwheel turns.
If the spindle does not turn properly, remove the two screws that hold the top cover on. DO NOT REMOVE THE SCREW THAT IS ON THE SMALL BLOCK NEXT TO THE BOBBINWINDER SPINDLE.
The top cover will not remove because of the handle. While lifting up the cover, peer under to make sure that there is a small rubber tire on the under side of the bobbinwinder spindle.
If the tire is there, place a small drop of oil on the spindle and turn it until it frees up. Try not to get oil on the tire, it will make it slip. Wipe it off if it gets oily.
Replace the top and retry.
Posted on Jul 26, 2009
  • 12 Answers
SOURCE: I need a user manual for a Necchi Alco 2200 sewing machine
Contact the individual who posted this answer.
Posted on Aug 20, 2009
Necchi sewing machine
There are a number of things that could cause this.
Needle installed with flat in the wrong direction.
Excessive thread tension,top or bottom.
Lack of lubrication. If the machine can do anything more than a straight stitch the mechanism can gum up and not move the needle correctly.
Here is a link to threading directions.
Necchi 3537 Sewing Machine Threading Diagram
Aug 03, 2014 | Necchi 3537 Mechanical Sewing Machine
Please let me know where I can buy a bobbin winder for NECCHI SILVIA maximatic 586. Mrs.N.Perera.
Your machine is not actually made by Necchi, it is a standard model that lots of manufacturers buy and have their own name put on, email me and tell me what the problem is kendourof@yahoo.com
Aug 08, 2011 | Necchi 3537 Mechanical Sewing Machine
My Model # 1120 Singer sewing machine needle will not go up and down when motor is pressed. The bobbin winder, however, spins.
It sounds like your machine is set to wind the bobbin right now, so the drive is disengaged. That would explain why the bobbin winder pin is the only part moving. Check your manual for how to reset the machine when you are finished winding the bobbin.
Most machines have a way to disengage the drive for the needle while filling the bobbin. Then once the bobbin is filled, you re-engage the drive. Some machines have a separate, smaller hand-wheel that turns and clicks into place. Some machines automatically reengage the drive once the bobbin pin snaps into place away from the drive belt.
I hope this helps!
Mar 29, 2011 | Singer 1120 Mechanical Sewing Machine
My Necchi 4595 has never really worked properly,.,.,the lower thread (bobbin) is very loose and then the thread breaks,,,I've tried to adjust the tension, but maybe I'm doing that wrong.
I also own 2 necchi sewing machines, my mechanical is a 4595,,
lower thread tension
to test the bobbin tension, remove the bobbin case & bobbin & hold it by suspending it byb the thread, **** it once or twice, if the tension is correct, the thread will unwind by about an inch or two.
if the tension is too tight, it does not unwind at all, if the tension is too loose, it will drop too much.
to adjust the tension,, left is loosen & to the right tighten
thread breaks
rethread the machine making sure to get all thread guides
top thread tension usually 3 or 4
replace needle- make sure the needle is inserted correctly
some needles don't work with some thread, here's a tip
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 16, 2010 | Necchi 4595 Mechanical Sewing Machine
Why does the thread keep breaking?
check the needle to see if it's bent-roll on flat surface to see if it rolls correctly
thread tension maybe to tight-select lower number
sometimes the thread can get caught on the
1.spool pin
2.the notch on the thread spool itself
some times the thread will come off the thread take up lever
Sep 22, 2010 | Necchi 4595 Mechanical Sewing Machine
I have a Necchi 537FA sewing machine. It sill sew about 39 stitches and then the thread gets caught in the bobbin area and stope sewing. I've cleaned, changed bobbins, spent time trying to fix the...
have you checked to see if the needle is bent-lay the needle on a flat surface & roll the needle over,, if the needle does not roll good -replace
blunt needle-if the needle makes a popping sound when the needle penetrates the fabric,,the needle is blunt-replace
sometimes if the thread comes off the thread take-up lever it can jam the thread in the bobbin area
try rethreading the machine
check to make sure the thread isn't wrapping around the spool pin
check the spool of thread to see if the notch on the spool is catching the top thread
check to see if there's a burr on the bobbin case
I hope one of these suggestions helps you
please rate this using the thumbs in upper right hand corner
Aug 12, 2010 | Necchi 3537 Mechanical Sewing Machine
Singer 750 how to rewind the bobbing?
1. Push in indent (illustration 1) on hand wheel disc. This will stop the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over rim of spool to prevent thread from tangling.
4. Lead thread passing it first through the lower slot of the thread guide. Next through the upper slot, leading the thread to the right and around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim of bobbin.
8. Holding thread end, step on speed controller to run machine until desired amount of thread is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its original position. If necessary, turn hand wheel to engage needle movement.
Feb 09, 2009 | Sewing Machines
Cant get machine out of neutral after threading the bobbin
there should be a way to disengage the bobbin winder. I had a machine that had a switch in the center of the handwheel and even though it would be in the off position I still had to turn the handwheel till it clicked.
Dec 15, 2008 | Necchi 3537 Mechanical Sewing Machine
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing Machines Logo
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
