Mistral mss6.5 manual - Heating & Cooling
I lost the manual to a mistral doughnut maker and
Look on the Mistral web site is the best option
Oct 12, 2014 | Kitchen Appliances - Others
Hi, my daughter has just moved in to a property with a mistral mss6.5 system, with no instructions left behind on how to operate it. they replaced the batteries in the remote, but do not know how to reset...
Without being able to see the remote, there are three possible solutions which spring to mind. Firstly, contact the people from whom they bought the property, or place an inquiry through the sales agent. Ask if they have the manual, or if they can explain how the remote functions.
Another possibility is to take the remote into a local store that installs and repairs air conditioners and ask how the remote works. Presumably when she bought the house your daughter was told that the unit was in working order, so if after a sales or service assistant has shown her how to operate it, the air conditioner still won't function, she need to tell the house agent about it.
Finally, she could use the link below to the Mistral website and send them a query and also ask for a manual. I hope this helps!
http://homeappliance.manualsonline.com/ex/product/headline/m/mistral/d/air_conditioner/p/MSS6.5
Aug 21, 2011 | Heating & Cooling
HOTPOINT MISTRAL plus 8596 fridge E2 code
Go to this site: http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewforum&f=35
Type "Mistral Thermistor" into the search and help will be availible. You have a very common problem which is an easy fix in most cases. Good luck.
Mar 13, 2010 | Hotpoint Refrigerators
Cant unlock my rankarenna tv model ba34combo tv lost the manual
This TV is manufactured by Mistral and distributed by Target. There is no widely available information on it.
It should be a simple procedure to unlock the TV but for the exact combination I suggest you contact the customer support nearest to you. They can instruct you over the phone.
Mistral have several support phone numbers so I have included the link where you can choose the one that is nearest to you.
http://www.target.com.au/html/refund/refund3.htm
Hope this helps and you get it sorted out soon.
Many thanks for using FixYa. Please remember to accept and rate my answer if it has helped.
Dec 31, 2009 | Televison & Video
Mistral Air-con split system shows F6 fault! What does it mean?
F6 INDICATION MAY MEAN THAT THERE IS A PROBLEM WITH THE BLOWER MOTOR. WHEN THE BLOWER MOTOR GETS HEATED UP (WHEN ITS WINDING BECOMES WEAK) THIS MAY HAPPEN. SO U GET UR BLOWER MOTOR AND PCB BOARD CHECKED.
Nov 23, 2009 | Heating & Cooling
Need instruction manual for mistral mpac140 portable air con
They do not have a downloadable manual that I could find but I have included their contact info so you can contact them directly. They may be able to get you the info you are requesting.
http://www.mistral.com.au/contact_us/contact_us.asp
Apr 01, 2009 | Heating & Cooling
Lookin for hotpoint mistral plus schematic diagram
i have a hotpoint mistral plus 8596 a couple of days ago it started defrosting and showing a diagram of a box with an arrow pointing to the top compartment next to it is a minus 13 degrees
Jun 28, 2008 | Refrigerators
MISTRAL MTLW7..2 too many probs!
e4 error on my mistral MTLW7 washing machine want spin
Mar 27, 2008 | Washing Machines
Instruction manual
Here is a link:
http://www.mistral.com.au/products/manual/BMH110.pdf
Dec 09, 2007 | Kitchen Appliances - Others
Heating & Cooling Logo
101 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
