Question about AEG Washing Machines
Detergent not completely dissolving and small amount of water on the floor
AEG Washing machine, L63470 FL
  • 103 Answers
Check detergent is properly inserted. if the tray is not fully in detergent will not dissolve and also water will spill. OR the water pipe may have pushed back.
Posted on Dec 11, 2016
I want to soak my washing because of bad stains. But I don't know how to with an aeg lavamat washing machine
Pick your cycle, add clothes and detergent, switch off once filled and all the soap has dissolved. Turn back on tomorrow :>)
Dec 13, 2016 | AEG Washing Machines
What type of detergent is best liquid or powder
Liquid detergent is better for all washing machines.
Apr 22, 2016 | Miele Washing Machines
Build up of dirt in tub making clothes dirty... How do I clean inside of machine?
If you use powder detergent ( clay carrier) the build up is from undissolved powder ( clay)
It forms cakes between the spin tub and the outer bowl
The fix is to pull the washer apart and physically remove the caked up mud from all parts of the machine
The prevention of future mud is to use liquid detergents rather than powders
It works like this powder detergents have a small percentage of actual detergent in use and that is dried onto a clay base as a transporter agent
In the wash , the detergent is released but the clay will not dissolve
Most is pumped out with each spin but a certain amount remains , dries and starts the dirt process through the clothes
With liquid detergents there is the same amount of actual detergent but the carrier is water and that is diluted in the spin and completely flushed away
Dec 30, 2015 | Washing Machines
Magkakatuluyan ba kami ni shelumiel
things you'll need:
* Laundry detergent
* Clean cloths
* Measuring tape
* Plywood (if necessary)
* Wrench (if necessary)
1.Verify that the Kenmore top-loading washing machine is completely plugged into a grounded, three-prong power outlet. Reset the fuse or circuit breaker, if necessary; do not plug the washing machine into an extension cord.
2.Make adjustments to the feet on the washing machine if it is shaking or vibrating. The front and rear feet must all be touching the floor evenly. If the floor under the machine is flimsy and cannot adequately support the washer, set a 3/4-inch piece of plywood under the machine for better stability. Load the tub evenly when placing items inside the washing machine and do not overload the tub.
3.Examine the washing machine drum, including between the inner and outer basket, if the machine is clicking or rattling during use. Remove loose objects from inside the drum. If objects are caught between the drums, unplug the washing machine and pull the items out with a pair of pliers, if possible.]
4.the fill hoses behind the washing machine if there are water leaks and ensure the drain hose is connected to a laundry tub or drainpipe. Look at the plumbing throughout the home for drainage problems and correct as necessary.
5.Turn on the water valves behind the washing machine and clean the water inlet hose screens if the water is not running or filling. Do not overload the tub, and use only high-efficiency (marked HE) laundry detergent in high-efficiency Kenmore washers. Note that energy-efficient washing machines often use less water than other machines; this is normal.
6.Choose a wash cycle with a higher spin speed if the water is not draining as expected or items are extremely wet when washing is complete. Reduce overall load size and select a new drain/spin cycle to remove the extra water from the washer. Ensure the drain hose is properly installed on a drainpipe or tub and is not set more than 96 inches above the floor.
7.Reduce the number or volume of items inside the washer tub if the clothes are not rinsed when the cycle is complete. Verify that the water valves are turned on and the correct type and amount of laundry detergent is used.
Mar 12, 2011 | Kenmore 22422 Top Load Washer
Why does a lot of detergent remain in the soap dispenser after a washing cycle is complete
Was the dispenser cup wet when you added detergent?
Make sure the dispenser cup is dry before adding powdered detergent. If dispenser cup is wet, the detergent can clump.
Is the cycle incomplete?
If the previous cycle did not complete, the detergent can become caked in the dispenser cup if it is left sitting in the dishwasher.
Is the detergent old?
Older detergent exposed to air will clump and not dissolve well, which will cause the dispenser door to stick to the detergent. Replace detergent if necessary and store the detergent in a tightly closed container in a cool dry place.
Is the water temperature too low?
For best washing and drying results, water should be 120oF (49o C) as it enters the dishwasher.
Were items blocking the dispenser that kept it from opening?
Items blocking the detergent dispenser will keep it from opening. Make sure water action can reach the dispenser.
Detergent guidelines
  • Use automatic dishwashing detergent only.
  • Other detergents can produce excessive suds that can overflow out of the dishwasher and reduce washing performance.
  • Store tightly closed detergent in a cool, dry place.
  • Fresh automatic dishwasher detergent results in better cleaning.
  • Add detergents just before starting the cycle.
  • The amount of detergent to use depends on the hardness of your water and the type of detergent.
  • If you use too little, dishes won't be clean.
  • If you use too much in soft water, glassware will etch.
  • Suggested fill amounts are for standard powdered detergent. Amounts may vary if you use liquid or concentrated powdered detergent. Follow instructions on the package when using these detergents.
  • Water hardness can change over a period of time. Find out your water's hardness by asking your local water department, water softener company, or county extension agent.
Nov 25, 2010 | LG Washing Machines
Clothes stink on top load model
Continually washing with cold water and liquid detergent can cause a buildup of undissolved detergent between the inner and outer tubs (unseen). This buildup of detergent feels like grease and will pick up dirt from each load and hold it on the grease surface. Over time...the dirt held in the greasy detergent can give off an odor.
This problem may be able to be cleared up by running many loads of hot water (to dissolve the detergent) with no clothes or detergent. Switching to powder detergent will also keep the liquid detergent gel from forming. If you like liquid I recommend using hot water for ALL your white loads. This should make every third or fourth load hot and help dissolve buildup from previous loads.
If you are not in the habit of using cold water and liquid detergent consider other sources of the odor. Some typical examples are sewer or septic backup through the drain and into the machine between the tubs where you can't see it. Also, the laundry is usually in the basement if you have one. The basement is the lowest part of the house drainage system and if you are developing a slow drain you may find some dirty water backing into the machine if it can't go down the drain quickly enough. Usually these drainage issues show up as a floor leak when you drain the washer in the spin cycles...but not always.
Good Luck.
Sep 17, 2009 | Kenmore Washing Machines
Suds residue left on clothes just washed
ck drain hose end of drain hose should be at least 36 ins from floor also be sure drain hose fits loosely in drain water may be siphoning out resulting low water level to wash/rinse ..also recommend using liquid detergent dry doesn't dissolve good in cold water and even though it may be recommended for front load the lower water levels used may not be enough to dissolve it properly
Nov 27, 2008 | Washing Machines
AEG lavamat w 1020
Just pull out the dispenser quickly. May be a bit hard to get out.
Jan 19, 2008 | AEG Lavamat W1050 Front Load Washer
Washing Machines Logo
35 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
