I am looking for a speaker for z-640 speaker #901447-0401r
How do I activate the speaker?
look for an icon that looks like a speaker with bars in front of it
press that once for speaker , press again to turn speaker off
Jan 04, 2016 | O4Jelectronicswarehousecom Vtech 3 Dect...
Telefunken TLC037fhda no sound picture good
take a look at the speaker,use a multimeter see if the speaker have the rated resistance.( eg .8 ohms) if speaker bad replace if.if speaker good. see if your audio amp is getting power (multimeter needed) set to d.c volts.have voltage then look for the input pin that brings audio into the amp,use a 16 -32 ohms speaker across gnd pin and input pin(bring volume up hi on tv) if audio replace audio amp.
(also look for cold solder) on p.c board before replacing amp.
May 23, 2014 | Televison & Video
Missing cord to speaker to speaker, what dose it look like?
According to the owner's manual, the 'speaker to speaker' cable is not removable. The speaker to computer cable is.
It's a 6' 3.5mm stereo to 3.5mm stereo cables such as this: http://www.walmart.com/ip/Link-Depot-AUDIO-6-35MM-Link-Depot-3.5mm-Male-to-Male-Audio-Cable-6/15779608
Apr 02, 2014 | Altec Lansing Speakers Acs43, Tested,...
I am purchase my laptop before one year , now my compaq610 model speaker is problem , i am cotact to authries delar he is told me purchase one speaker , how i have know this speaker is origional , is it...
you could ask the dealer to look the purchase up they should have a receipt or a copy or if you have a receipt for the speakers the model and number should be on the receipt otherwise it looks like they are external speakers i will need the name and model so i can look them up there are many
http://www.sparepartswarehouse.com/HP-Compaq,500B-505B-Series,Computer,Speakers.aspx
hope this helps
Jul 18, 2011 | HP Compaq Computer Speakers
Where do I plug speaker cables in ?
Hey!
If you're using a desktop, look at the back of the tower. You will see there a small green port where you can plug in the speakers.
If you're using a laptop. Look at the front side of the laptop, Try to look for an small icon that looks like headphones. That's where you're gonna plug your speakers in.
Hope this helps!
Sep 09, 2010 | Dell A215 Computer Speakers
I'm looking for the speakers for my Compaq cumputer,I would like to know where to get them
Any speakers will do, you can either get speakers that plug into the audio inputs (Jack plugs)
Or you can get USB speakers.
If you want Compaq branded speakers take a look here
http://www.amazon.com/s?ie=UTF8&keywords=compaq&rh=n%3A172471%2Ck%3Acompaq&page=1
Jul 12, 2010 | HP Compaq Computer Speakers
Connect speakers to computer
DESKTOP :
You want to look for 3 colored ports on your computer if it is a desktop
Green - Headphones / Speaker Ports
Blue - Audio In (from CD player or other device)
Pink - Microphone
You will want to take the plug from your speakers and plug it into the Green spot on the back of your computer.
LAPTOP:
If you have a laptop look on the front of the machine (usually) again you should see 3 connectors (May not be colored) but there will be a symbol next to each jack. You want to look for the speaker symbol .
Plug your speakers into there
let me know if this helps.
May 25, 2009 | Acer (90.18612.36B) Computer Speakers
MY AMPPLIFIER KEEPS BLOWING THE FUSES WHEN IT REACHES HIGH VOL. i HAVE IT BRIDGED WITH THREE 10" SPEAKERS.
LOOK THE SPEAKER AND IMPEDANCE WILL SAME TO OUTPUT OF AMPLIFIER OR LOOK FOR THE OTHER SPEAKER WHICH MORE IMPEDANCE,FOR EXAMPLE ,IF YOUR SPEAKER HAVE 4 OHM PUT THE SPEAKER IN SERIE FOR INCREASER THE IMPEDANCE,NEVER CHANGE THE FUSE FOR A TO HIGT.
Aug 10, 2008 | Car Audio & Video
Reinstalling into new vehicle looking for wiring color codes?
yellow (memory 12v+) red (accessories) black (ground earth) blue (power antenna) blue (amp rem) white with stripe (left front speaker + white( left front speaker - )grey with black stripe (right front speaker + grey (right front speaker -) green with stripe (left rear speaker+) green (left rear speaker -) purple with stripe (right rear speaker +) purple (right rear speaker-)
May 25, 2008 | Pioneer DEH-1000 CD Changer
Rear left speaker not playing
If the speaker itself is working then the problem will most likely be the connection point where the speaker plugs into. If you dont know how to check for this problem, i dont really want to tell you just in case you hurt yourself. Take it to a shop and have it looked at by someone thats knows what there looking for.
Sep 06, 2006 | Logitech Z-540 Speaker
67 people viewed this question
 Grubhead
Grubhead
