Question about Hunter Ceiling Fan Remote Receiver 85112-01
My light works works from the siwtch but my fan will not come on.
The fan only works with the remote. the remote will not tunr fan or light on and off. remote number 85095-01 hunter fan
    President:
  • 1,185 Answers
Have you changed the batteries?
If they are low on power you may get an Led to light up but not a strong enough signal to operate the fan
Posted on Jul 20, 2009
Wd-62725 tv was turning on but after a few it would tunr off to the point that now it does not. the power button does not light up
Indicates clogged filters or dust clogged fans. Clean and vacuum cooling fans and filters. Replace lamp assembly with new lamp. Should work fine. Also, try unplugging TV, wait ten minutes and plug it back in. The controller will reboot which may alleviate the problem. Regards.
Nov 06, 2015 | Mitsubishi WD-62725 62" Rear Projection...
Buttons and remote not working properly
sounds like a short or parasitic load dimming the light levels. could even be a "dry" solder joint
Dec 23, 2013 | Denon AVR-3300 Receiver
Newly installed Hunter remote will work light and fan if only 2 of the 3 bulbs are installed.
Did you install the correct wattage? If you put in 2-60 watt try 3-40 watt instead .
Dec 30, 2012 | Hunter 52" Ceiling Fan With Light And...
Hunter fan remote control 99600 not working
This must be a common problem, since I Googled the part number and it popped up before I completed the number. I am going to have to order a new remote, since I don't have a solder pen. Wish me luck.
Jun 22, 2012 | Hunter Dryers
New home have a hunter fan with no remote receicer is a cp911OR were can a buy a new kit with remote
call hunter at this number: 1-888-830-1326
have the model number of the fan handy and explain to them your problem. in most cases they will be able to get you a replacement part or kit for what you are missing
Aug 15, 2011 | Hunter 52" Ceiling Fan With Light And...
Remote missing on a Hunter Ergonomic fan. do not know how to take the base cover or light cover to see serial number. light cover has screws with no slots. base cover has no sign of srew holding it up. How...
Purchase the remote control, install batteries, and try it before taking anything apart. If the new remote control does not work, the internal receiver may have failed.
Dec 07, 2017 | Hunter 21871 56'' Ergonomic Brushed Nickel...
I NEED TO REPLACE THE CONTROL AND THE HUNTER TELPHONE NUMBER LEAVES ME ON HOLD FOR OVER AN HOUR WITH ANNOYING RECORDINGS!! HELP!!!!!!!!!!!!
i have a hunter ceiling not sure model but i have the model number 23530-300 with a remote ,the remote light comes on when you press any button but the fan does nothing any help good voltage
Jun 28, 2011 | Hunter Ceiling Fan Remote Transmitter...
Red light does not come on when buttoms pressed ,even with new battery,an I obtain a new remote?
Hi and welcome to FixYa, I am Kelly
Kmart and Sears both have replacement remotes for Hunter Fans.
Look on the back of your remote for the model number and you can search
http://searspartsdirect.com using a model search for a replacement.
You can also call the Hunter Fan Company to find out the model of your remote here:
1-888-830-1326. They will ask for the model number of your fan.
The Hunter remotes for the original fans can be one of these 3 models: 27187, 22691 or 27189.
See if you can find one of those 3 numbers on your remote.
Thanks for choosing FixYa,
Kelly
Apr 25, 2011 | Hunter Designer's Choice 5-Switchblades Lg...
Dryers Logo
841 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
