Question about Exercise & Fitness
I think the belt has sand in it and keeps slipping. How can I open it and give it a clean?
  • 6,694 Answers
Try to adjust the treadmill belt tension
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Dec 31, 2016
Belt sander runs until I put pressure on it
It sounds like the sand paper itself is slipping. There should be an adjustment to tighten the pressure on the sand paper itself.
Feb 28, 2015 | Ridgid Makita 98462 9910 Belt Sander 120v...
How can i tighten the spring so the sanding belt does'nt keep slipping off?
Hi Anthonyk,
The view of the b&d br300 I saw was rhat the sanding belt goes automaticly.Maybe you need to check the system or try to telephone local shop where you bought it .
Greatings from holland
Appie
Jun 19, 2011 | Black & Decker BR300 3''x18'' Belt Sander
Porter Cable 362 belt sander - the paper slips off
there might be a buildup of sawdust in the tensioning mechanism or the yoke might be bent. I would look at excess buildup in the mechanism first. there are 3 screws on the outside of the tool so you can remove the assembly as a whole. try and clean as thoroughly as possible. the mechanism should move freely and "snap" when lever released.
Jul 18, 2010 | Porter Cable Tools & Hardware - Others
Sander Belt keeps slipping off.
what I would do is using compressed air clean the underside as best you can there might be a buildup of dust not allowing the yoke to extend fully, then look at the condition of the rear roller, is should have a crown in the middle, make sure the belt tracking mechanism moves freely and I believe there was a plastic cap over the screw head to push the yoke. If it is not there it might be part of your problem. Lastly make sure if you are using directional belts that they are installed correctly, You can find a breakdown for this tool at Makitatools.com
Jun 09, 2010 | Makita 9404 4'' x 24'' Belt Sander
Power steering stops when I turn on the air conditioning
YES. or the belt may be slipping. does the a/c work? if the belt is tight and the a/c does not work, then the a/c compressor is trying to sieze and will need replacement. if you dont need the a/c disconnect the wires to it.
Sep 19, 2009 | 2000 Chevrolet Tracker
Disk drive ejects audio cds after a few seconds
I think that the mechanism of the cd accepter must be not accepting the cd due to blockages such as dust or sand particles. If you are experienced, open the case and try to find blockages. If problem persists, Call the company's support.
Aug 25, 2009 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
One of two engine belts squeals when car is started.
How does the belt fit in the groove? It should fit well with no space under the belt (which, if it were too wide, it would have a space). A belt can get 'glazed' over time, and slip and cause the squeal you describe. If the belt is dried up, oiling it seems logical, but in reality you are making it easier for it to slip and make the squeal noise. I would replace the belt, and clean off the pulleys with a clean dry rag the best you can to remove any traces of oil. There is also a product called 'belt dressing' that helps the belt grip better. I would not use this on the belt with oil though, I think you should replace it.
Apr 14, 2009 | 1989 Lincoln Town Car
Sanding Belt Slips Badly
Check and see if the pulleys on the sander are not glazed this somtimes will cause the belt to slip. Give them a good cleaning. If this does not help there is a good chance the spring on the belt tensioner is weak and need changed.
Hop this helps
Jan 09, 2009 | Tools & Hardware - Others
Exercise & Fitness Logo
66 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
