Try lcd monitor & tv serial # 190807080104037
I have an LG model #60PK750 serial #010RMWV8M569, the other day I was watching and the screen went black and no sound, I did get a display on the screen that said lost signal.
Fixya is a free tech support site. There is mo shop. No replacement parts.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Apr 07, 2015 | LG Televison & Video
Need a hp part number for a lcd display for a HP Pavilion dm4t-1200 laptop.
I would like you to try using HP's Part Surfer.
1) Put your Product Number, or Serial Number in the Quick Search box,
(P/N = Product Number.
S/N = Serial Number.
{DO NOT give out the serial number on a public forum such as this. Only on the HP website}
2) Then click the blue down arrow on the right side of the - Select a country or region - box, and click on your country.
3) Finally go back to the Quick Search box, and click on the side arrow to the right.
Post back in a Comment as to your findings.
We'll go from there.
On the back of the LCD screen is the HP part number.
http://www.screentekinc.com/HP_Pavilion_DM4T--14-inch--1366x768-wxga_hd-laptop-lcd-screen.shtml
{Scroll the page down, and see if any of the 36 part numbers may be a match}
Display LCD screen replacement instructions,
http://www.insidemylaptop.com/disassemble-hp-pavilion-dm4-laptop/
http://www.insidemylaptop.com/replace-lcd-screen-hp-pavilion-dm4-laptop/
Awaiting additional questions. Please post in a Comment.
Regards,
joecoolvette
[ P.S.
You can disconnect the LCD display, and use an external VGA monitor, while you wait for the replacement LCD screen.
1) Laptop off, VGA monitor off.
2) Connect the VGA monitor to the Left side of the laptop.
( External monitor port. The VGA connector resembles this one,
http://en.wikipedia.org/wiki/File:SVGA_port.jpg
3) Turn the VGA monitor on. Wait for it to 'warm up'.
Turn the laptop on.
If the display does not automatically go to the external monitor;
Press, and hold down on the Fn key.
Tap the F4 key.
(The VGA monitor can be a CRT monitor, {Looks like a small TV}, or a flat LCD screen monitor that has a VGA connector, and a VGA cable ]
Sep 04, 2011 | Computers & Internet
I got this monitor as a gift got all the cables correct in but cant get TV to go on just a blue screen an its says its on video but when i connect to dvd player no picture but sound
Use the controls on the LCD monitor to cycle through the available "inputs" (cable, A/V, VCR, DVD, HDMI1, HDMI2, VGA) that are available. Which inputs are available, and which are "greyed-out" ?
Jul 19, 2011 | Jetway (Avidav Serial) LCD-M1731SF 17in...
I'm having problems with my Sony LCD monitor input
you make sure that your pc has 60 herz frequency on the verticle speed. the pc connection is at the back of your tv written pc with serial and a jack connection.
Jan 26, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
TV isn't acting as a computer monitor - doesn't recognize computer connection
you need to use the right cable that plugs into your pc serial port in tv to the video card of your computer or same looking connection as your tv one but on the back of the computer ok
Jun 23, 2009 | SVA-USA VR-20 20" Flat Panel LCD Monitor
I have Zenith projection TV 60" model# 1QB60M90W-1, Serial#071-25350934, when pluged up all TV does is roll from one station to another no sound only thing that works is the on and off switch. When...
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Abctay com China Wholesale Wholesale Electronics Gadgets tv parts power...
Oct 16, 2017 | Televison & Video
Polaroid FLM-3732 LCD
looks like it need to be serviced , but before taking out to the shop , lets try this , open TV , check the PC board for some COLD SOLDER or BURNT SPOT , especially in the POWER SUPPLY area , hope this helps , let me know AJ
May 25, 2008 | HP Pavilion F1703 17" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
