Question about Mirage DPD-4200 42 in. Plasma Television
Plasma Digital Device DPD-4200
In my plasma Digital Device DPD-4200 (NEC) is wrong formatting of picture in TV mode: the image is shifted up and left (near 20 percent) (and may be some zoommed..), picture are normally synchronized and normal colored,; but in VGA mode image are fully normal . Sorry for my english-I am from Ukraine. I think that it wrong loaded data pre-setup in initializing, but I can't get into SERVICE MODE! Please help, HOW CAN I GET INTO SERVICE MODE? There are is serial port RS 232, but I have no information about interface programmer and software for "DPD -4200- control"
With regards, IGOR
NEC PX-50XM4A 50" plasma tv - I get a picture but no sound. I have my cable box plugged in to the DVI port converted to HDMI going to my cable box but I cant get sound when I plug external speakers in to...
HDMI carries both video and audio.
Do you get video and audio on TV. Just to be sure.
Now are the external speakers powered ?
are you connecting the Speakers to Audio Out of the TV ?
By the way, I cannot see any RCA port that is output port on your NEC plasma. NEC 50XM4 User Manual Specifications The audio input is for audio from dvd for example.
Oct 23, 2013 | NEC Televison & Video
CAN YOU SHOW ME THE THE PICTURE OF REMOTE CONTROL OF NEC PLASMA TV
There are several different ones depending on the model. Look at this google image link: https://www.google.com/search?q=NEC+PLASMA+TV+remote&tbm=isch
Sep 09, 2013 | Televison & Video
Red hues all over the images on screen
The TV is a plasma screen. There are several circuit boards that will go bad over time that affects the picture quality. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get the parts here and replace those boards yourself.
Apr 10, 2017 | Panasonic TH-42PZ700U 42 in. Plasma...
Lower half of the screen has a digital ghost that is
Tv have a convergence problems,it dead.Tv convergence board is dead.Require changing the 2 STK convergence ICS and some or all it resistors.To solved the tv convergence problems.Tries Websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergencce kit.To replaced those convergence parts on the board.
Jul 28, 2010 | Samsung HL-S5679W 56" HDTV
The problem with my NEC 68T90 TV is that the screen resolution is not correct. At 4:3 ratio, I can't see the sides of any video or TV program that I'm watching. Is there a problem with the hardware?
Try the aspect button on your remote, or if you have this hooked up to a cable or satellite converter, there are screen resolution preferences, you can change the screen resolution here, go the the menu portion and look for video/audio field
May 07, 2008 | Televison & Video
Image has shifted to the left
You need to contact a technician who has the software jig to fix your problem.....The part number is TNPX25JIG and is no longer
available...........Good Luck.
Jan 25, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
NEC Plasma
thats bs, stop calling nec, there are plenty of repibuble repair shops who have or can get aftermarket part
Oct 12, 2007 | NEC PlasmaSync PX-61XM3A 61 in. HDTV-Ready...
Somethings wrong
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Sep 30, 2007 | SanDisk Sansa e260 MP3 Player
Picture has shifted to the left
This is a known problem. Panasonic sells a jig to correct it. I had the same problem and bought the jig for about $25. It plugs into a special port in the back of the tv behind a little door. You can read all about it here: http://www.avsforum.com/avs-vb/showthread.php?t=534816
Aug 15, 2007 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Mirage DPD-4200 42 in. Plasma Television Logo
202 people viewed this question
Top Mirage Televison & Video Experts
Are you a Mirage Televison and Video Expert? Answer questions, earn points and help others
