Need help with brand new dyno glo 30,000 bit propane heater it keeps turning off
  • 108 Answers
SOURCE: Dyna-Glo natural gas space heater to propane gas.
Yes it is possible and a good idea. You need to have a regulator installed to reduce the pressure to the heater and this is a simple procedure. Contact your local Propane distributor and they will probably do this free to get your business.
Ray
Posted on Dec 09, 2008
clyde2j2
  • 137 Answers
SOURCE: can i convert my dyna glo 75000 btu propane
I'm sure you can, contact the manufacturer and ask if they have a natural gas jet or orfice for your model heater, these are usually very easy to replace.
Posted on Feb 28, 2009
SRF518
  • 232 Answers
SOURCE: Dyno-Glo propane heater Model RMC-FA100DLX. It
find the thermostat and jumper out the two wires if it shifts into high heat, replace the thermostat.
Posted on Oct 26, 2009
SOURCE: My glo-warm propane heater keeps shutting off automatically-pilot and all.
my heater says if the pilot light keeps going off automatically it is a safety function that means it does not have enough fresh air to operate
Posted on Dec 04, 2009
ShirleyBill
  • 51 Answers
SOURCE: I have a wall propane Dyno-Go 30,000 BTU five
Go to the Dyno-Go website, to see if they have a mauel available there.
Also you can type in the brand name in the search engine, and hopefully download a free one. If not, then check ebay for the maual
Posted on Nov 06, 2010
I have a dyna glo propane heater that keeps going out. I think its related to the oxygen sensor.
Bypass the sensor with A jumper wire to test the sensor If it lites properly the sensor is bad.The sensor is probably in the bottom.
Nov 29, 2012 | Dyna-Glo (PPH16-LP) Utility Heater
Ihave a dyno glo heater rmc-lc20ngt nateral gas can it be converted to propane
You didn't specify whether it's a vented or vent-free heater. I suspect it's Vent-free. In which case NO!
Doing so would override any of the safety features that are built-in to shut it down if something goes wrong.
Jan 19, 2011 | Heating & Cooling
I have a wall propane Dyno-Go 30,000 BTU five bricks\r\nModel RMI 80 LPT Serial 02-01628 I need a manuel so i can turn down the pilot where can i find one and the cost.
Nov 06, 2010 | Dyna-Glo D-E39 (LP) Wall Mounted Panel...
I have a dyno glo work horse kerosene heater modle rmckfa65-wh I TURN ON HEATER BUT IT WILL ONLY STAY RUNNING FOR 5 TO 6 SECONDS.WHAT DO I NEED TO DO TO KEEP IT RUNNING?
If it is a gas,thermo type heater,then the thermocouple is bad.Check and make sure the pilot lite flame is touching the tip of the thermocouple,if it is not,adjust it,to where it will.If it is not adjustable,replace the thermocouple.
Jan 15, 2010 | Dyna-Glo (PPH16-LP) Utility Heater
Dyno-Glo RMC-95-C7 kerosene heater. replaced wick
once the tank gets low(on E) put the heater outside and let the remaining fuel burn completely out. This will burn off the residue build up on the wick and make it easier to turn off manually. do this often. i also use an old toothbrush to "fluff up" the wick. if the residue is too hard for the toothbrush bristles, flip the toothbrush over and break up the residue with the back side of the toothbrush. once all (or nearly all) of the residue has burned off you may see some smoke when you ignite the wick again. also, it may smell for a bit. I always light and shut off the heater outdoors. I mounted a dolly (table withe 4 wheels) under the heater to make transporting it easier. hope this helps!
Jan 02, 2010 | Dyna-Glo Heating & Cooling
Filters for dyna-glo pro
You can make your own filters out of felt and I have also found that with some minor modifications most of the parts from Mr. Heater will work with Dyna Glo. I have a 170btu kerosene heater and just installed an ignition, a high limit control and a flame sensor from Mr. Heater and it works like new.
Nov 03, 2008 | Desa International ALL-PRO® SPC-85 Utility...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
