Question about Building Materials
My remote only opens the roller door about 20 inches
How do you reset an ATA TXA1 Garage roller door remote opener, can the code be changed
heeeeelllllllllo......go to youtube they have the demostration............tkx....g.scott
Jul 15, 2014 | Chamberlain Universal Garage Door Opener...
I have a 6 year old craftsman 1/2 HP model139.53985D garage door opener. Sometimes it open/closes fine - other times it opens or closes 6 inches at a time and stops. Springs are fine, worm gear is fine -...
Generally when the door is closing any problem will cause the door to reverse to the open position and stop. This is designed into it. You say your opener just stops when going up or down. This makes me think there is a bad connection somewhere and you are simply losing power. If this is so you should notice that all the small lights that are normally on go out. If this only occurs when the door is going up you may have a bad RPM sensor board. This is a small printed circuit board just in front of the motor.
Aug 31, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a LiftMaster garage door opener. It has started to act up a bit, and I can't seem to locate the problem. It opens just fine, but when we try to close it, with either the remote or the wall control,...
If the opener feels any resistance it will act like this.Make sure that the rollers on the door to frame are oiled well and turn easily, move in and out easily as well, you can also turn the screw to increase the resistance stop pressure.Oil the rollers well
Jan 22, 2011 | liftmaster Chamberlain Garage Door Opener...
I want to program garage door opener in my 2006
Hold the button on your Homelink unit for 20 seconds. The light will begin to blink fast.
Place the remote door opener within one inch of the homelink console and press and hold the button on the remote until the light on the homelink unit begins flashing slower, long blinks.
The code is programmed.
If the programming fails, try restarting the process, but pushing the remote button and holding, then repushing and holding, as some remotes do not transmit long enough to program.
Here is the factory directions for reference, it is a very large picture so I linked it:
Oct 10, 2009 | 2006 Toyota Sequoia
How to program the suv morano garage opener
1. Press and hold the two outside garage opener buttons located on rear view mirror until the red LED light blinks (could be 20 sec.)
2. Press and hold the middle button on the rear view mirror while holding a garage door remote 1-3 inches away from the mirror and pressing the remote button. Do this until the blinking LED gets noticeably faster.
3. Once programmed - use the garage door opener on the mirror thru 3 cycles or more to verify.
Jun 26, 2009 | 2005 Nissan Murano
Door only opens about 3 inches
You have a broken spring on the door. Stop tyring to open door with opener immediately or you will have a broken opener and a broken spring
Oct 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Continuous paper jam when i try to print
Hi ,
Follow the steps below -
1. check the media / paper compatibility. It sould be as per hp :
Paper tray capacity Type Weight Capacity Input tray Capacity Output tray Plain paper 60 to 90 gsm (16 to 24 lb) 150 50 (20 lb paper) Legal paper 75 to 90 gsm (20 to 24 lb) 150 50 (20 lb paper) Cards 200 gsm (110 lb index max 30 30 Envelopes 75 to 90 gsm (20 to 24 lb) 20 10 Transparency film N/A 25 25 or fewer Labels N/A 30 30 4 x 6 inch (10 x 279 mm) Photo paper 236 gsm (145 lb) 30 30 8.5 x 11 inch (216 x 279 mm) Photo paper N/A 20 20 Paper sizes Type Size Paper Letter: 216 x 279 mm (8.5 x 11 inches)
Legal: 216 x 356 mm (8.5 x 14 inches)
A4: 210 x 297 mm
A5 148 x 210 mm
Executive: 184.2 x 266.7 mm (7.25 x 10.5 inches) Envelopes U.S. 10: 105 x 241 mm (4.125 x 9.5 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches) Transparency films Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm Photo 102 x 279 mm (4 x 6 inches)
127 x 178 mm (5 by 7 inches)
Letter: 216 x279 mm (8.5 by 11 inches)
A4: 210 x 297 mm (8.27 by 11.7 inches) Labels Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm Custom 76 x 127 mm up to 216 x 356 mm (3 x 5 inches up to 8.5 x 14 inches) Print margin specifications Paper size Top Bottom US Letter
US Legal 1.8 mm (0.07 inch) 3 mm (0.12 inch) ISO A4
JIS B5 1.8 mm (0.07 inch) 6.0 mm (0.2 inch) Envelopes 1.8 mm (0.07 inches) 14.3 mm (0.5 inches) Cards 1.8 mm (0.07 inch) 6.7 mm (0.3 inches) 2. paper should be placed to the right of the tray and a little inside with a min distance within the papers of .1 mm
3. open the rear access door of the printer (with grids) on the back and reval the rollers. Take a slight moist cloth ( not cotton ) and clean the rollers with it by moving them 4 times upwards. the cartridge door ad observe the thin plastic strio on top of the steel rod on which the carriage moves. Take a small piece of paper and hold the strip with it ands swipe it once witout applying much pressure as it could come out in any direction and as much as you can
5. make sure you replace the cartridge if its refilled. It could provide obstruction.
move the carriage 4-5 times continuously with as much speed and make sure there is no obstruction in the carriage movement.
6. press set up button on the printer panel - go to print reports - ok / enter - self test report - see if the paper jams. If not good.. If yes take a look into the next step.
7. pull out the power cable directly from the printer. Press and hold # and 6 button on the printer and insert the power cable and do not release the buttons till you see te display glowing blank or some processing happening. Release the #6. If the printer turns off then press on the power button to turn it on. Continue with country and language settins as apprpriate. Choose your country during this reset. Complete the alignmet then. Take a printout to see if the paper jams again.If yes - the printer definitely needs servicing.
Apr 08, 2008 | HP Officejet 7210 All-In-One InkJet...
Building Materials Logo
71 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
