Question about Fisher and Paykel Washing Machines
Fisher and paykel washing machine is coming up with error 62. Seems to have stopped before the spin cycle. What do I do?
    Habit-Forming:
    Scholar:
  • Fisher and P... Expert
  • 170 Answers
Fault 62 is nothing to do with blocked pumps. It means pump is drawing too much current. Fit a new pump will usually fix the problem, if it doesn't,then you have to change the control board.
Posted on Dec 24, 2016
  • Fisher and P... Master
  • 5,323 Answers
May have a clogged water pump or hoses, check for obstruction , if clogged machine will not go into final spin
Fisher and paykel washing machine is coming up wit - 26390433-bszy215dbxllk1sw2ym4qmfg-4-0.jpg
26390433-bszy215dbxllk1sw2ym4qmfg-4-2.jpg Fisher and paykel washing machine is coming up wit - 26390433-bszy215dbxllk1sw2ym4qmfg-4-5.jpgt/uploads/images/26390433-bszy215dbxllk1sw2ym4qmfg-4-5.jpg" alt="2639043Fisher and paykel washing machine is coming up wit - 26390433-bszy215dbxllk1sw2ym4qmfg-4-9.jpg="h_mi" />
Posted on Dec 08, 2016
  • 22 Answers
SOURCE: washing machine will not spin or drain
look at my post "eco smart won't drain, smells hot". It could be something stuck in very lowest part fo drainage area. you have to remove the motor on bottom of washer to see into this area and remove blockage.
Posted on Oct 21, 2008
SOURCE: Fisher & Paykel GW712 washing machine continuously
Out of balance switch could be faulty/ coroded.
have a gw 709 and it had the same problem, out of balance switch had jammed on
Posted on Apr 15, 2009
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
  • 3 Answers
SOURCE: Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Posted on Feb 20, 2010
It was on the last cycle spin it stopped had pumped the water out but stopped spinning.
Expert Tips, Troubleshooting & FAQs - Fisher & Paykel ...
https://www.fisherpaykel.com/us/support/expert-tips/Fisher & PaykelFind Tips, Troubleshooting Information, How-tos, FAQs and Answers to Commonly Asked Questions about Fisher & Paykel Appliances.
also on Youtube
Aug 17, 2015 | Fisher and Paykel Washing Machines
Fisher and paykel intuitive wont spin or drain and hums buzzes and says code 62 needs service please help
Hi Tracy,
there are two reasons for a code 62, the first is the drain pump unit, it will not spin with water inside, the pumps likely to be blocked otherwise it will pump, stop, pump or pulsates.
Its been a while since I last logged on to here, have earlier post to describe how to check and remove the pump.
Seeing the machine has gone this far into the cycle then the second component the controllers has to be fine..
Good luck
May 09, 2015 | Fisher and Paykel Washing Machines
Fisher & Paykel GW612 won't spin
you want to check the drain pump if there is nothing stuck there sometimes a drain restriction will cause the machine to stop
Jan 27, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
During the spin cycle my fisher and paykel will stop ,with "power failure " in window and then says restarting in 10sec. I thought it had not been spin drying the clothes at times. Now this...
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. Here we need to suspect the controller board as it seems to trip or hang up.
In this case it seems that the power trips when the program controller loads or encounters a load factor. So check the motor, the capacitor, the free movement of the drive shaft and all the connections to the control panel. finally check the main power outlet for loose connection in the plug / socket.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Aug 24, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
My Fisher & Paykel washing machine continually stops and beeps on spin cycle GW703. Move clothes around and continue, goes for a while and stops again, seems it is sensing it is unbalanced.
There should be a tech sheet located underneath the control panel that has a fault code matrix. Compare the lights to what you see on the sheet, and read the details.
Mar 05, 2011 | Fisher and Paykel Washing Machines
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
Washing machine wont spin the water out.
IT IS VERY POSSIBLE THAT YOU HAVE A BAD OUT OF BALANCE SWITCH. THE MACHINE WILL NOT GO INTO A HIGH SPEED SPIN IF THE SWITCH IS BAD.
Mar 18, 2009 | Fisher Paykel EcoSmart GWL15
My fisher and paykel smartdrive 708 stops at rinse/spin cycle with machine still full of water
with no error code ... I would check you drain pump or drain hose... you first may want to try a shop vac connected to the end of a drain hose .. let me know if it helps
Dec 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
49 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
