Question about Sony Televison & Video
How do I fix a Sony remote control RM-DX350? I am receiving a message no matter what I press "Now player checking....Can't receive. Please turn this REMOTE to a main unit."
  • Dan S
    Dan S Jul 25, 2017
    On the CD Changer press the Menu/No button, then turn the big jog knob to the right until you see "2Way Off?" and then press the knob in to hit enter. Then press the power button the remote and point it at the front left area of the CD Changer where the IR receiver/transmitter is located.
  • 473 Answers
Try removing and replacing batteries.
Posted on Jul 25, 2017
  • 4102 Answers
SOURCE: Sony RM-V202 control and Emerson DVD Player
the codes are 051     060      069
1 turn on dvd
2 press and hold s button
3 whilst holding s button press and release power button
4release set button
5 press dvd on controll
6 using key pad key in the 3 digit code
7 press enter button
8 point remote at dvd and try power button
9 if nothing work enter next code
if this still dont solve your problem post back and i will tell you how to do this manually hope this is some help
Posted on Oct 31, 2007
SOURCE: how to program remote model # RMT-D130A
Found the manual online, here it is:
http://akamaipix.crutchfield.com/Manuals/158/158DVPN600.PDF
Go to page 60. Basically, just hold the TV Power button down, hit your manufacturer's 2-digit code, and release power button. If the code is right, the TV will power off and then back on again. The manual only shows numbers 01-19 in use, so I guess you only have to trial-and-error a max of 19 codes (which is ultimately faster than downloading and opening the manual)! I hope this helps you out.
Posted on Sep 01, 2008
SOURCE: TV remote RM-ED002 for main TV works fine except volume
I had the same problem with sony remot control RM-ED002, take remot control apart and clean inside with damp cloth and dry with kitchen towel, thats it now use it! ;-)
When i opened mine it was some kind of moisture under volume and channel buttons, cleaning and drying it helped.
Posted on Nov 03, 2009
  • 148 Answers
SOURCE: I get the following error message when iI press the I/O button
It sounds like the remote and the tv are not completing the signal the remote is sending. Have you checked to see if there is anything blocking the little LED (l.e.d.) in front of the remote?...It could have gotton scratched, or even chipped, in the factory or along the way. Other than visibly seeing any defects with the receiving LED on the tv and the sending LED on the remote it could possible be a programming/ setting problem.I hoped this helped you some!
Posted on Feb 02, 2010
SOURCE: For RM-YD023, I need to control my Receiver volume
I contacted Sony support for this same concern. Their response was that there is no volume lock option, you must switch back and forth from "TV" to "AMP" :(
Posted on Mar 05, 2011
When I connect my Sony Google TV to my SANYO TV through a HDMI cable, it does not work. Please any suggestions? SONY TV model = Sony RMVZ320 Remote Control SANYO model = SANYO MODEL DP50747 ed it int
First of all, be sure that your SANYO TV is on the correct input for the HDMI port you're using. If that checks out, you might check to see that another device (e.g. blu-ray player, laptop, cable receiver, etc...) works with the SANYO TV using that same HDMI cable and port. If it does work, perhaps your Google TV box is set for a higher resolution than your SANYO TV supports.
Aug 11, 2012 | Sony RMVZ320 - RM VZ320 Universal Remote...
I have a rm-p311 remote can it be programed to run a newer unit
Sony remotes keep the same codes for all there tvs. It will run older as well as the newest tvs. Hope this helps.
May 10, 2011 | Sony RM-P311 Remote Control
My remote rm-u306 will not turn on my system but it will turn it off when i press the stand by button and the off butten together
I had the same issue. To fix it, on the receiver i pressed the Set Up button and then the Menu + button to change the input to C.MODE.AV2.
Reply
Jan 28, 2011 | Sony RM-U306 Remote Control
I am trying to program my AV3000 to work with my Dish Network Sat Receiver. Any help? Thanks so much.
Hi my nameis Mike Houston of DISH Network and I caught your post and see you want to programthe Sony RM AV3000 to the DISH Network receiver. To have full access to the menusand functions of the receiver it is best to use the DISH remote for the systemyou have, I will send a link for the RM-AV3000 to help with the setup for theremote. If you have any questions please e-mail me at michael.houston@dishnetwork.com.
Dec 26, 2010 | Sony RM-AV3000 LCD Touchscreen Remote...
Where i can find the remote
For Sony CD-M630 cd player, you need following remote control..
147711014... RM-X117 remote Control
Available in Sony Accessories Store for $34
Hope this info will help you.
Thanks.
Feb 11, 2010 | Sony CDX-M630 CD Player
Feb 02, 2010 | Sony RM-DX450 LCD Remote Control
I can not get my Sony RM-P501 to control my receiver. It was working perfectly but suddently it does not control the receiver. Seems like it lost the factory programed features
Please check & ensure the infrared is emiting from the remote control. Though we cant see this infrared beam with bare eyes, there is a trick to do so in http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html Most of the problems is weakened infared beam. Replace the batteries when needed. Hope this fix the remote control problem.
Jan 01, 2010 | Sony RM-P501 Remote Control
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Code no.?
This information is to search for any code using the SONY RM-VL990T Universal remote:
Using the code search function: Press [S]. All Component Select buttons will flash. Press the button you want to configure. Press [CH+] or [CH-] and [POWER] in turn until the component turns on or off, then press [ENT] to save.
May 09, 2009 | Sony RM-VL900 Remote Control
Remote dosen't work, trying to code my Sony RM-V302
there's a good chance it's the receiver and not the remote. Just fixed mine this afternoon with help from this blog.
http://blog.moertel.com/articles/2007/05/25/repairing-my-kenwood-a-v-receivers-remote-control-sensor
this worked on my kenwood vr-209. 10 others fixed their kenwood as well from the posts.
Jay
Dec 25, 2007 | Kenwood VR-209 Receiver
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
