Question about Stoves Ovens
Does anyone know how to bypass the timer pcb on a Stoves 720gra double gas oven? The part is obsolete but there must be a way to bypass. 4 wires go to it from main board (ribbon cable)
  • 250 Answers
SOURCE: cant work oven!
I have the Stoves 720EF manual stored on the BT Digital Vault which might help. If you want a copy of it, supply an email address and I will give it access.
Also someone else has said that if you speak to Stoves nicely they may be able to send an electronic version of the manual instead of the paper copy.
Posted on Mar 25, 2009
SOURCE: need to adjust clock setting
Press + and - at the same time (manual says hold for 3? seconds) and then + or - to set the time. If from power up, as I did yesterday, I don't think you need to hold them together for any length of time, but maybe it was my imagination, since I tried it first before I read the manual.
Posted on Nov 19, 2010
SOURCE: Manual for Stoves EL716 oven
I have a Stoves Newhome EL716 double electric oven and last night, it just lost all power and stopped working - no grill, oven, lights, clock or anything. Can anyone tell me what this could be please? Thank you.
Posted on Sep 09, 2011
SOURCE: dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
Posted on Jan 02, 2012
SOURCE: Need Chambers Oven clock/timer unit, model #GBO-244
I NEED 2 KNOBS-1"
Posted on Oct 07, 2012
Why does grill ignition click when bottom oven lit
ignition probably serves both, if clicking when not lighting, fault or sticking button
Jan 04, 2016 | Stoves Premier 720GRa Gas Double Oven
How do I bypass a faulty timer unit on a stoves 720ef cooker
Try taking the power wire that goes into the timer and the power wire that comes out of the timer and put them together not hooked to the timer and that should work. If that works you should solder them together and electrical tape them good.
Make sure the power is off when you do this so you don't cook yourself.
Dec 03, 2014 | Stoves 720EF Electric Double Oven
Scan pdf file ef720
I have a similar problem and contacted Stoves. Apparently the timer unit is now obsolete which means replacing the complete oven!
Jan 05, 2014 | Stoves 720EF Electric Double Oven
Display not functioning on stoves double oven.hence bottom oven does not work
you solved this problem / replace the display . it should correct problem .. ..mm
Jul 15, 2010 | Stoves Premier 720GRa Gas Double Oven
I have had 3 engineers out to try and fix my stoves 720gra cooker and has changed all the printed circuit boards ,and all other parts but still the top oven and grill doesnt work and has now been classed...
check the voltage on the spark generator,should be 240dc or 110 ac.
or it could be the harness(wires fron spark generator to ignition) to check harness do a continuity test,an electricion will know,or get a electirc tester and do it with the instructions.
Oct 01, 2009 | Stoves Premier 720GRa Gas Double Oven
How does the q900 works
I do not know either but I would be tempted to turn off the gas, but keep the electric to the oven, and use a plastic Knitting needle to find out. It should show on a display somewhere.
Feb 11, 2009 | Stoves Premier 720GRa Gas Double Oven
I cant work out how to switcg my stoves newhomes gl706 grill oven on
this product is made by encodex. No manual could be found online. Check if pilot light is on and you don't smell alot of gas. encodex is a sub company of GFK group. Here is there number, Tel. +49 911 395-0
Dec 28, 2008 | Stoves Premier 720GRa Gas Double Oven
Hi i cant seem to get my grill or oven on can any one help
thanx for the site guys i got the no for the co and they going to get back to me thanks again
Ovens Logo
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
