Question about Health & Beauty
I recently fixed a dead segway mini scooter, however i've never seen a working one in action and my mate tells me its running to fast but how do i regulate it and what are the specs
Segway mini scooter, self balancing
2 Suggested Answers
gfreed100
  • 60 Answers
SOURCE: i've recently bought a new tga sonet scooter, it's very noisy, they tell me that they are a noisy scooter can anybody tell me if this is true.
Block the rear wheels up off the floor. Now put the sccoter in gear and let her rip! Is it real noisy? Did they replace the motor or the trans-axle on which th motor is appart of. If they replaced the entire assembly and its still making noise, thats what they sound like. Ive heard some of the scooters make a winning sound. Go to a place that sells this model and compare. My scooter is a Rascal 600t it makes some noise. It shouldn't be too noisy though. Its hard to tell from here.
Posted on Jul 13, 2012
Amigo problem
I had this problem similarly on an older trike I owned and still do.
If it stutters as it goes forwards, there is probably an intermittent connection between the wig-wag (the part you push to make the scooter go) and the rest of the electronics. It could be as simple as a loose wire or the whole wig-wag might need replacing. I'd recommend you take the scooter to your local dealer and have them reproduce the exact problem you're having and hopefully they'll be able to recommend a fix.
Apr 22, 2014 | Electric Strider Mini 4 Wheel Mobility...
I have a problem with a Drive Mini Phantom scooter. If you picture the speed control dial as a clock with the slow (turtle) position at 7:00 and the fast (rabbit) position at 5:00, the scooter does not...
It could be battery problems or ECU problems i dont feel the problem stems from the dial or variable switch. if possible try and get a current tester and test how much power the battery's are actually producing. other than those suggestions i dont have any other fixes at present, keep me posted, best regards
Oct 30, 2013 | Drive Medical Mini Phantom Three Wheel...
Sometimes my electric mobility scooter acts as though it's dead - but, the batteries are fully charged and the horn will work. Other times, it acts perfectly normal. The downside is, it's left
okay now this is most likely a loose connection
does the rear axle come away from the main frame ? if so check the connectors there clean gently,,,,
Now check the battery connections does the battery pack come away from the scooter if so again check the connections here , clean and make sure connections are good.
Regards
Jan 12, 2013 | Electric Mobility Rascal Scooters,...
I've recently bought a new tga sonet scooter, it's very noisy, they tell me that they are a noisy scooter can anybody tell me if this is true.
Jul 12, 2012 | Electric Mobility Health & Beauty
Can't tell if tape is recorded.
Well thanks that you found out. i was going to tell you to do exactly what you did because the timecode rreads where it is tapes and does not where it's not.
Nov 23, 2011 | Panasonic PV-GS35 Mini DV Digital...
My scooter is too slow,the battery charges,but it only drives at very slow speed,while going backwards it goes fast.Can you tell me what to do?
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. In the future give as much info about the scooter as possible.
1. Replace the throttle pot and or the speed pot.
2. Sometimes even batteries that take a charge are not strong enough to run the scooter. Have them load tested at an auto parts store to make sure. If you have bad batteries that will make you scooter do what you say it's doing. Don't forget your reverse speed is only 1/2 as fast as the forward speed on all scooters.
Good Luck
Tim
Apr 30, 2011 | Health & Beauty
My scooter is brocin
You really need to re-post your problem. Tell us what brand your scooter is and also tell us what year, and model it is. Then tell us what is broken; it won't start, the front brake will not work, the clutch will not engage, the headlight doesn't work, horn doesn't work, what part is broken?? Also tell us what you have tried to do to it to fix it and any recent repairs that have been done. With this information one of the experts may be able to help you. Without the information no one can even try.
Apr 03, 2011 | 2001 kawasaki ZX-6R Ninja
Electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
May 05, 2010 | Electric Mobility Mobility Electric Power...
The scooter doesn't work!
This is the PC help section, my solution would be to post in the correct section for the best help.
Maybe your battery is Dead and needs replacement.
Apr 16, 2009 | Computers & Internet
Health & Beauty Logo
76 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
jeff tilburn
jeff tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
