Question about Technics Audio Players & Recorders
HI I HAVE A TECHNICS AZ6 FOR MANY EAR BUY NEW IN 1996 IT WORKED PERFECTLY BUT 1 DAY STOPPED AND SEE F03 ERROR HOW I CAN REPAIR THIS?
  • 57 Answers
SOURCE: Washing machine has a F03 code when it starts to rinse
Hi I would advise you to check the filters in the water valves and check them for being open circuit
Posted on Jul 18, 2008
Grubhead
  • 5190 Answers
SOURCE: Error F03
I suspect that only one capstan works, The belt driving it might be broken or something else on the drive.
Posted on Jan 27, 2009
  • 69 Answers
SOURCE: I bought a Whirlpool double oven AKZ161 and error code F03 appear
On this model, F03 indicates a faulty power control board (also known as the "Capricorn" board by Whirlpool technicians). A new oven with no guarantee? There is usually a reason something has no guarantee, in your case, a faulty control board. It is a relatively expensive part unfortunately.
You can try disconnecting from power, removing top panel from oven. The large square electronic board you see on the top of oven is the power control board. Check all plug connections are OK, especially the large thin multi plug that goes to the display board- I have had a poor connection at this plug causes F03 faults. If still no go, power control board will need replacing
Posted on Aug 17, 2009
SOURCE: amana ARB8057CSR
I have the same unit, same age, same problem. I'm pretty sure it's the compressor acting up. Figures, just out of warranty. Probably will end up buying a new fridge (No Amana, that's for sure!)
Posted on Feb 10, 2010
SOURCE: Dryer stops and bips - message F03
03 indicates as a rule that the alloted drain period has elapsed. Usually it is a pump failure or a blocked (or partially blocked) drain out system? You say you have cleaned out all the hoses and replaced the pump, well now it's best you just run a test to see how quickly the machine empties? In fact it should be less than 60 seconds and if it's slower than that I guess you've got a button or something blocking the drain outlet somewhere and acting as a gate valve no doubt.
The other thing you could check whilst your at it is the air chamber at the back of the tub. White clear plastic bottle above the motor, if that is gunged up you could get spurious error warnings like F03?
Posted on Feb 27, 2010
Moon roof 1996 rav4 toyota repair
Hi i never worked on it but i would try to Dryglide special product easy up open and close windows and so spry on the edges and see maybe the mechanism is going stiff and force to open u buy Dryglide from Repco good luck
Jun 14, 2014 | 1996 Toyota RAV4
Technics stereo cassette deck rs az6 spares
Tape belts are universal generally. All you do is measure the diameter of the belt in MM and if it is wider than the "string" type the width in MM again. Put the words "cassette drive belt xx MM" into Google. You don't have to precise with the measurements.
Feb 23, 2014 | Technics Audio Players & Recorders
What does F03 mean
F03 is an error code with two possible meanings.
1) battery plates are sulfated, meaning they have a buildup of lead sulfate on the battery plates. Try charging the battery using the "Recondition" button on your charger. If this does not correct the problem then it may be option 2:
2) Open cell in battery. Have battery tested at an auto parts store and be ready to buy a new battery. An open cell means the battery is no longer usable.
Nov 18, 2009 | Vector Black And Decker High Frequency...
Aug 17, 2009 | Ovens
I have had a lexmark printer/fax/scanner for about 3 years. I have never used the fax part. The printer works perfectly well but about a month ago the scanner stopped working. Can you please help. I do not...
Possible, your printer has worked out whole its resource. Even though his(its) repair technically possible, he will be expensive. Your warranty service was expiredabout 3 years. Think about buying new. Good luck.
I have bought itself from Epson.
Mar 06, 2009 | Lexmark X7170 All-In-One InkJet Printer
Jul 18, 2008 | Kenmore 46462 Front Load Washer
Error F03
Apr 28, 2008 | Audio Players & Recorders
DMR-ES40V Error Code F03
This means there is a technical error.
I suggest you go to your nearest retailer iof this and they will fix it but they will probably charge.
Hope this helps! - Josh
Feb 13, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
37 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
