Question about Porter Cable Saws
I need to reattach all wireing on a porter cable tiger saw sawall. rewire triger switch ,it was taken apart
SOURCE: need color code/wiring diagram info for Enterprise electric range installation of thermostat
I need the Oven knob for the front panel. The numbers have rubbed off on mine. Thanks, in advance, for your help!
Posted on Jul 28, 2008
muttandjeff
  • 359 Answers
SOURCE: Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Posted on Jan 11, 2009
rowdy45176
  • 2176 Answers
SOURCE: i need a wiring diagram for a milwaukee heav duty circular saw
It is probably something like a 6365 and on all the Milwaukee products they have a switch wiring diagram but nothing for the switch. I would recommend going to a local repair center with the switch and match it up with a new one probably less than 15.00 If you give me your location with zip code I can direct you to the closest one. Let me know
Posted on Apr 14, 2009
  • 187 Answers
SOURCE: hi i need to rewire my ryobi table saw switch thanx lee
What I do is to take a photo of the wiring and effected area so I can refer to it when I get lost. Just replace each wire one at a time from the old switch to the new. Good luck
Posted on May 08, 2009
  • 58 Answers
SOURCE: MY 10
call 1-800-525-2579 Ryobi technical service line:
Posted on Jun 20, 2009
Cable porter sawzall 9737
Take a stiff pin or small paper clip and push it down alongside the wire into the switch to release the wire. The wires are held in by a spring steel connector inside the switch - you have to push it back so the wire will release.
Let me know if you have any questions and I will do my best to further explain.
Aug 24, 2014 | Porter Cable VariableSpeed QuikChange...
Porter Cable Tiger saw 9735 stopped working
blow it out and spin the motor by hand you may have saw dust blocking the brushes. If that's not it check the brushes to see if they have life left in them. If not that check the cord for an open with a volt ohme meter.
Hope that helps!
Jan 24, 2012 | Porter Cable VariableSpeed QuikChange...
What weight oil do I use in Porter Cable 637 Type 1 Variable Speed Tiger Saw?
use sewing machine oil, or 3 in 1 oil, you could use WD40 as well. but not motor oil
Mar 21, 2011 | Porter Cable Variable Speed All-Purpose...
I have a Model 737 Tiger Saw that was loaned out and now I cannot load a blade. It appears that a blade may have been broken off in the quick change collar. I cannot pry it out, so I must disassemble the...
Its hot pressed onto the shaft its made not to come apart because if it did in use it would not be good. I use sawalls all of the time and fine if the blade snaps low you can get them out with a strong magnet if you hold it up side down and turn the collar shake it around mabey spray some WD40 in side first it may take a little doing but it beats takeing that change collar a part.
Jan 14, 2011 | Porter Cable VariableSpeed QuikChange...
I need to get the gear out of the back in order to pull the recipt shaft it is broken.. how do u pull the gear out I have the 9745 tiger saw
Are you serious? Dewalt sells a saw for $100.00! I like the tiger saw but choose the path of least resistance. Your saw isn't worth it . Time will be high and parts plus shipping will add up as well as the wait time.
Oct 21, 2010 | Porter Cable 9748 Tiger Saw Kit
Can't take off front off porter cable tiger 747 (rubber boot
Remove 2 screws from under front grip and the swivel foot should slide forward and out (might need a bit of a twist to loosen) plastic grip should now slide forward and off.
Dec 07, 2009 | Porter Cable Variable Speed All-Purpose...
Variable speed quit working
You would need to replace the switch, give me a model number and a location with zip code and I will try and find one locally for you, Its not that hard
Apr 25, 2009 | Porter Cable Variable Speed Quik Change...
Broken blade on a porter cable 737 tiger
This is a jigsaw miscatagorized as a chainsaw. Do you have a blade big enough to drop 24" tree? We don't answer jig saw questions in the chainsaw section.
Mar 30, 2009 | Porter Cable Variable Speed All-Purpose...
Replacing shaft on tiger saw
If the spindle is broken you have to take the front of the saw apart, but check for excessive wear in the other parts before buying just the one. Its not that hard just pay attention when you disassemble
Nov 30, 2008 | Porter Cable Variable Speed Quik Change...
Saws Logo
155 people viewed this question
Top Porter Cable Saws Experts
Frank Mangiapane
Level 1 Expert
Jim Thurston
Are you a Porter Cable Saw Expert? Answer questions, earn points and help others
