I have a row can TV the blue button is indicating TV is on But no picture or sound-i try to turn off it won't If I wiggle the power cord it will turn on and off
techman
  • 3130 Answers
SOURCE: Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Posted on Jun 16, 2006
SOURCE: No power
Brand, and size please? Most problems come from either the power supply, or deflection circuits.
Posted on May 27, 2007
SOURCE: new Sceptre 37" LCD TV does not turn on
normally the a-v cables are color coded the white goes with white the red goes with red and yellow goes with the yellow and when putting it in the dvd player if applicable it should be the same way did your tv come with a manual showing you how to hook it up
Posted on Aug 09, 2007
Fujitsu
  • 29 Answers
SOURCE: Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
Posted on Nov 28, 2008
  • 2335 Answers
SOURCE: Philips flat screen tv will not power up.
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Posted on Dec 20, 2008
Blue light comes on but tv won t turn on no picture or sound nothing works
The blue light merely indicates power is getting to your TV. The internal power supply may have failed.
Aug 15, 2014 | NEC PlasmaSync 42VP4D 42 in. HD-Ready...
Blue light but tv won t turn on
Try these troubleshooting steps:
- Try to power on the TV using the button on the TV and not the remote
- Ensure that the power cover is securely connected
- If you are using a power strip connect the TV directly to the wall
- Try a different outlet
- Can the outlet power any other device?
Good luck
Feb 05, 2014 | Sceptre Televison & Video
X322BV-HD*WXC100
Warranty is usually 1 year parts and labor. Contact mfc for warranty service. likely main board.
May 28, 2013 | Televison & Video
My polaroid TV will turn on but there is no picture or sound
blown caps in the power supply a 470m at 16 volt cap it will be puffed up
Sep 18, 2009 | Polaroid FLM-323B Television
I turn on the tv and it has a blue screen and no
Just try to reset so picture will back to normal again, some LCD TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the LCD TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the LCD TV power button for five seconds.
4. Plug the LCD TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the LCD TV is responding again.
6. Turn off the LCD TV and reconnect the devices.
7. Turn on the LCD TV.
Hope it may help you;
Regards;
VOTIT
Apr 23, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
No Picture, No Sound While Watching
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Regards;
VOTIT
Jan 29, 2009 | RCA L37WD250 37 in. LCD HDTV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
