I have an F16 fault on a TB Woods Etrac drive. Can u plz suggest me what should do.
  • Computers & ... Master
  • 3,368 Answers
If it is readable copy the data off immediately, if not you need to take it to a data recovery service such as ERS Data Recovery at 1.888.248.3148 What yo depends on how important the data is.
Posted on Jan 07, 2017
What causes a red light on an TB Wood Etrac XFC 1001 inverter and the motor will not start Is there an internal fuse Do I need 3 phase for the input
Is that red light flashing or continous lighting? You do not need 3 phase input for that model. Do you have the input wiring diagram? If the red light is flashing maybe the emergency stop input is active. If the red light is on continously then it maybe in stop mode or torque limit, ask electrician to check the wiring.
Dec 31, 2016 | Inverter Electronics - Others
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
What does error F:16 indicate?
no one will know without a MAKE and MODEL.
Dec 26, 2015 | Washing Machines
What do's f16 mean on the bosch classixx 6 1200 mean
F16 is a door fault, could be the door is not tightly closed before pressing start, the lock is faulty so the machine is not registering that it is closed or the wiring connection to the door lock is loose.
Apr 10, 2013 | Bosch Washing Machines
Hi im sachin want to purchase 1 tb hard disk of cgate and LCD of ither samsung or sony.... 1. will support an external USB hard drive on this lcd's ? there any other type of hard disk i need to...
I do not know if the 1 Tb external hard will work on the USB ports on the LCD TVs.
What do you want to store on the 1 Tb USB hard drive and display on the LCD TVs?
Most LCD TVs can access USB memory sticks and display DVI movies (if supported by the TV), photos etc. that are stored on these USB memory sticks.
Try inserting an USB hard drive (borrow one if necessary, can be any capacity) into the USB port to see if it works before you decide to purchase a 1 Tb USB hard drive.
My suggestion would be to purchase a 1 Tb USB memory stick. This would out perform an external USB hard drive.
May 19, 2010 | Dell Dimension 3000 PC Desktop
Error code F16
F16 on a Bosch indicates the door is open / unlocked.
If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board.
The wash programme should halt when this comes up but you should be able to restart it when the door is closed.
As the cost of a new door interlock isn't overly expensive I would suggest fitting a new lock on a "fit and see what happens" basis.
Aug 10, 2009 | Bosch Washing Machines
My woods upright freezer keeps frosting up at the top with several inches of frost. It is a manual defrost freezer. Any suggestions?
check your door seal, by closing the door on a strip of newspaper all round the seal. this fault is usually air getting inside the freezer, it rises to the top making thick ice or snow.
Dec 17, 2008 | Woods Upright Freezer MU07W
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
