Question about Water Water Heaters
Where is reset button on titan wayer heater. It is not heating water
SOURCE: Titan Tankless stopped working this morning.
I have the Titan SCR2 N-120. You may have a different model. On mine if you are looking at it just a inch below & 1 inch to the left of dead center will be a round black sticker(it has some white lines at&t's logo). there's a pin hole in the middle of the sticker that you can poke to reset. Or turn the breaker off then take the 2 screws out of the top of the unit. It's just a thin metal cover that you can pull back & look inside. You'll see a red circular button thats the reset button. It's right behind where the hole I was talking about & what gets pushed in. you'll also be able to see if anything burned out & can get replacement parts at titanheater.com . One of my heater elements had burn/ melted & I've ordered a replacement. It was $17 + $11 s&h but still cheaper than $200 new unit from e b a y. Best of Luck
Posted on Sep 05, 2009
  • 122 Answers
SOURCE: I have a reliance 606 electric water heater. This
you need to replace the thermostats. the elements are working, as your water is getting hot.
I would replace both upper and lower thermostats. be sure to set the temps the same for both.
the thermostats sit against the tank and read the tank temperature. if one is malfunctioning, they will over heat the water, causing you to get severe hot water.
also as a precaution, I would replace the temperature and pressure relief valve. if your water is getting that hot, and this has not "popped" then it is time to replace it.
Posted on Sep 08, 2010
  • 8404 Answers
SOURCE: I have a Titan N-120
I have not worked on this model of heater. I have several trouble shooting tips for you to try. This is the approach I would use if this were my heater. But first, you say it lights up for hot water then you ask about elements. Is this electric or is this gas fired?
If it is gas fired, it is lighting (a burn sequence) and not heating, I would suspect a flame sensor problem. The fire comes on but the sensor cannot 'see' it so the safety turns the gas valve off. If it is gas fired, there probably is a electronic ligniter ... I would take a look at that to make sure it is lighting. Normally, this is a strip of metal that heats up red hot or a sparking device. Look for the red light inside near the burner or listen for the spark.
If it is electric, I would turn the power off and with a volt/ohm meter, I would measure the resistance on the elements. Set your meter to oHm for this reading. You should read "short" if the elements are good. (Short is the same reading you will get if you cross the probes (direct contact one to the other)) If there are two elements, check both. This is step one in proving the elements. If they both check good, turn the power back on and check the voltage (set meter on 250 VAC or higher) Place the probes on the screws that hold the wires to the elements. Now then, if you get a reading (Is this 110 VAC or 220 VAC - read the volts on the meter) Your thermostat is fine. To prove this, turn the thermostat off and the voltage will drop to zero. If there are volts and still no heat, I would suspect the elements are indeed faulty and should be replaced.
I hope this answers your question. Thanks for your visit to FixYa.com today.
Posted on Feb 01, 2011
packrat1948
  • 528 Answers
SOURCE: I have a titan 120
Replace the element it is shorted out.
Posted on Feb 02, 2011
Testimonial: "I ordered one Monday. Just wanted to make sure I was doing the right thing. Thanks"
heatman101
  • 43501 Answers
SOURCE: The titan water heater does not heat. The unit
Most likely it is because the heating element is burnt out inside the heater....
You will need to replace the heating element or replace the heater...
heatman101
Posted on Feb 03, 2011
I have a Titan water heater model N-160. I turned the water off hoping to change the filter. Now There is no hot water and the screen reads : STAND BY FLOW=OFF how can I reset it?
Hey Shawn..did you turn the water back on BEFORE cutting the electricity back on? Cut the breaker off,,, wait 3-4 minutes before restarting.. MAKE sure the water is on ALL the way...
Troubleshooting the Titan tankless water heater
SCR3 160 Titan Tankless Water Heater
Jul 02, 2017 | Water Water Heaters
Where is the reset button on a titan flomaster
were can I get repair service now Titan Scr 2 N120,In Spring Hill,Fl
May 15, 2014 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Reset does not work
Did you hear a click when you push a thin hard object inside the pin hole? Follow the instructions on how to reset the Titan water heater so you do it the right way.If your water heater still doesn't work, you need to take it for repair.
May 09, 2012 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Thermostat sticking titan n180
The thermostat is there to protect the water heater. I don't think it can overheat and make the breaker trip. If you tried to reset the unit and it's still not working, you should send your Titan N180 back to the manufacturer to be repaired. The 10 year warranty if against leaks. You have 1 warranty in your Titan components.
Apr 01, 2012 | TitanNet TITANTANKLESS. COM PRESENTS THE...
The titan water heater does not heat. The unit shows that it is on.
heatman101
Feb 01, 2011 | TitanNet TITANTANKLESS. COM PRESENTS THE...
We used to have hot extremely hot water in both bathrooms. One day, the water became warm and ultimately cold in one of the bathrooms. Now, the water is also freezing in the bathroom where the water used...
Your check-valve has most likely failed at the switch.
The flow check valve works by opening when you turn the water tap. When it opens it closes a switch which turns on your heating elements. When this switch fails you will still have water flow, but no heat. Titan has parts for this but you will need to call their service Dept.
or call
Toll free support pesonnel hours (EST): Monday-Friday: 9:00am - 5:00pm
They also have an online support operator during normal business hours here
http://www.titanheater.com/livehelp/livehelp.php?department=2
Mar 24, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Jul 27, 2009 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Water Heaters Logo
48 people viewed this question
Top Water Heaters Experts
D. E. Hev
Kenneth Walker
Are you a Water Heater Expert? Answer questions, earn points and help others
