Question about Cell Phones
Need pin codto housewife ho's - Cell Phones
My fluorescent shop light fixtures sometimes does not go on and sometimes the bulbs just flicker without giving much light. What's wrong?
If your shop is in your garage, and it is cold outside, the two-pin fluorescent tubes don't work very well. Garage lighting (fluorescent) should be the HO (high output) type. It operates on the same voltage. The tubes are not interchangeable. You need a HO fixture. If your shop is inside your house, then flickering tubes (assuming that you tried changing them out with new ones) indicate a bad ballast inside the fixture. You can either change out the ballast, or for almost the same price, replace the fixture.
Sep 19, 2014 | Home
No riesco ad entrare sul telephono perche mi chiede sempre il codice ed ho dimenticato il numero
controllare il pacchetto della vostra SIM card.
si dovrebbe trovare alcuni codici di l?.
Ci sono tre codici statici (PIN, PUK, PUK2)
Inserire il codice PIN per accedere al PUK telefono o utilizzare al fine di cancellare il codice PIN
Jan 30, 2011 | Samsung E2210 Cell Phone
3230 me 1,6,8 keypad nahi work nahi kar rahi hai
  • are yar keyad work nahi kar raha hai to sabse pehle uska front bord jo keypad belt k sath laga huwa hai use check karo
  • or uske bad keypad belt change karo lakin wo hard hai so ek hi solution hai koi dusra front bord change kar k dekh lo
  • is se 100% ho jayega ok
  • nahi to key pad ic change karo
  • ok
  • my name is
  • IDRISH 911
Oct 25, 2010 | Nokia 3230 Cellular Phone
I need one of the small red pins that insert in the timer face which turn the system on. Please give me a heads up on where I can order one of the pins.
you should be able to pick up one of these at your local hardware store or Home Depot if not you can order from Malibu on line
Sep 30, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Sir my zong sim s pin code block i want puk code
my zong number03117623338 block ho gi hy please help me
May 16, 2010 | Lands Phones
Network pin of motorola at&t model c168i
hi ho can give me the network pin for motorola c168i
Jul 29, 2009 | Motorola Mobility C168 Cellular Phone
How to see the lyrics along wid hearing the song in transcend 840
U need to get the LRC lyrics file for the same.
This is nothing but lyrics after the time whne it starts.Save this with the same name as the mp3 file, in the same folder. and enable the lyrics sync.
For eg: For the song Jai Ho from movie Slumdog Millionaire: Copy paste:
[ar:Slumdog Millionaire]
[ti:Jai Ho]
[al:Slumdog Millionaire]
[00:16.13]Jai Ho Jai Ho
[00:22.64]Jai Ho Jai Ho
[00:29.83]Aaja Aaja Jind Shamiyane Ke Tale
[00:33.77]Aaja Jariwale Nile Aasman Ke Tale
[00:36.77]Jai Ho Jai Ho
[00:44.08]Aaja Aaja Jind Shamiyane Ke Tale
[00:47.58]Aaja Jariwale Nile Aasman Ke Tale
[00:50.64]Jai Ho Jai Ho
[00:58.58]Jai Ho
[01:00.83]Jai Ho
[01:04.52]Jai Ho
[01:07.52]Jai Ho
[01:12.33]Ratti Ratti Sachi Maine Jaan Gavayi Hai
[01:15.45]Nach Nach Koylo Pe Raat Bitayi Hai
[01:18.97]Akhiyon Ki Neend Maine Phoonko Se Uda Di
[01:22.52]Neele Tare Se Maine Ungli Jalayi Hai
[01:26.34]Aaja Aaja Jind Shamiyane Ke Tale
[01:32.34]Aaja Jariwale Nile Aasman Ke Tale
[01:36.66]Jai Ho Jai Ho
[01:39.78]Jai Ho Jai Ho
[02:08.15]Jai Ho Jai Ho
[02:14.53]Jai Ho Jai Ho
[02:22.33]Chakh Le Ho Chakh Le Ye Raat Shahad Hai Chakh Le
[02:29.52]Rakh Le Haan Dil Hai Dil Aakhri Had Hai Rakh Le
[02:38.90]Kala Kala Kajal Tera
[02:42.17]Koi Kala Jadoo Hai Na
[02:49.41]Kala Kala Kajal Tera
[02:52.59]Koi Kala Jadoo Hai Na
[02:55.96]Aaja Aaja Jind Shamiyane Ke Tale
[03:04.23]Aaja Jariwale Nile Aasman Ke Tale,
[03:05.92]Jai Ho,
[03:06.61]Jai Ho
[03:18.49]Jai Ho Jai Ho
[03:25.49]Jai Ho Jai Ho
[03:32.48]Kab Se Ha Kab Se Tu Lab Pe Ruki Hai Keh De
[03:40.93]Keh De Ha Keh De Ab Aankh Jhuki Hai.. Keh De
[03:49.07]Aisi Aisi Roshan Aankhe Roshan Dono Bhi Hai Hai Kya
[03:55.24]Aaja Aaja Jind Shamiyane Ke Tale
[03:58.80]Aaja Jariwale Nile Aasman Ke Tale
[04:02.74]Jai Ho Jai Ho
[04:06.62]Jai Ho Jai Ho
Apr 20, 2009 | Transcend T-Sonic 840 MP3 Player
Need to remove barn doors on a 92 suburban
You do not have to pull the hinge. I just did one. The pins need to be pressed out. We used a bearing press. It is a 4 hour job. Locate the pins fisrt and you will see why they won't pound out.
Feb 28, 2009 | 1992 GMC Suburban
Kisi ko call karke katne par mobile restart ho jata hai
Check Your Charger pin or Chek it out Your HandsFree Port also.
May 28, 2008 | Nokia 6233 Cellular Phone
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
