Question about Magic Chef Refrigerators
Instructions to repair the cold control for a Magic Chef refrigerator thermostat #ctb1722arw
fridgetech
  • 473 Answers
SOURCE: Magic Chef Refrigerator
Not a themostat. 3 most common causes are defrost problem (frost on back freezer panel), bad evaporator fan motor, or damper.
Posted on Oct 05, 2007
  • 1314 Answers
SOURCE: Fridge does not get cold enough
first the freezer does all the cooling there are air vents in top of the refrigerator that the evaporator fan draws air through then blows it down to cool the fridge in the fridge section you should see an air vent if you don't have a defrost problem then you have an air flow problem first do you hear the fan running if you see heavy frost on the back wall of the freezer wall where the fan is then you have a defrost problem and that's a different repair but if you don't then remove the four screws and pull the panel carefully as the fan is there see if there is heavy frost on the evaporator a large aluminum honey comb so much that air cannot come through it under that part will be an a tray with around hole in it make sure that's is not frozen and the drain hole is open then check that the square hole that goes down to the fridge is clear and check the two square styrofoam intake blocks are clea you an pull them out gently and see if its iced up under there after you check that reply to me on any fault
Posted on Dec 31, 2007
  • 2920 Answers
SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Posted on Aug 27, 2008
  • 82 Answers
SOURCE: Magic Chef Refrigerator door flys open
Sounds like you have the unit out of level front to back leaning towards the back. Try leveling or just tilted a little with the top leaning just a little toward you. This should keep it from flying all the way around.
Posted on Jun 28, 2009
  • 16 Answers
SOURCE: bottom of refrigerator not getting cold enough
have you cleaned out the coils underneath the fridge? it's very simple. pull the fridge out, look underneath(try pulling off the bottom grill from the front for more access), and start cleaning. to much dust and lint will hinder the coils from cooling. A vacuum with the brush attachment or little broom works good.
Posted on Jul 27, 2009
Magic Chef mini frig freezing everything.
The thermostat is part of the temperature control found on page 6 here=> MCBR445S1_Parts_List Parts can be found here=> MCBR445S Parts If you have questions please let me know, Thanks Sea Breeze
RF-7350-59 Temperature Control Thermostat
Dec 09, 2012 | Magic Chef MCBR445S1 Stainless Steel...
FRGIDARE SIDE GETTIN TO COLD
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced.
May 30, 2012 | Magic Chef Refrigerators
Freezer gets cool with ice buildup on back wall. Refrigerator not getting cold at all.
Hi.
The problem is a defective defrost system. The defrost system comprises defrost thermostat, heater, defrost control and fan. The parts that fail more commonly are thermostat and heater. Both parts are located behind freezer firewall and tested reading impedance with a multimeter.
Jul 14, 2011 | Magic Chef Refrigerators
Magic chef refrig model # MCBR1000W defrost thermostat
RepairClinic.com is a fantastic online site for ordering appliance parts.
Jul 29, 2009 | Magic Chef CTB1821AR Top Freezer...
Side by side Magic Chef refrigerator. Freezer
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be begining of a defrost problem.
Jun 14, 2009 | Magic Chef CTB1821AR Top Freezer...
Magic Chef Mini-Fridge not Working, Model # MCBR360S
Unplug and look for the thermostat control. Try jumping the thermostat wires together. If it runs then replace the thermostat. Also feel the compressor to see if running, they run very silently. Thanks, Sea Breeze
Apr 27, 2009 | Magic Chef MCBR440 Compact Refrigerator
Refrigerators Logo
54 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
