Question about Exercise & Fitness
I have a trojan stamina 310 the control panel comes on but i canr change any setting it seems to be stuck on manual mode and unable to change or start the motor
Gareth 0744781607
Circuit
SOURCE: Problem with Control Panel
Try doing the following Keep the exit button pressed for a few seconds untill you see a change on the screen when the control pannel is locked and the locked screen appears on the screen..... try it and lemme know about
Posted on Sep 02, 2006
  • 18 Answers
SOURCE: Stamina/Speed switch not working on VGN-SZ484N
It depends on the game. And how detailed the game is. like basket ball vrs. mario you know. differen't graphics differen't speeds. Some time you can adjust the speed on the game which will in turn force the speed of the graphics card.
Posted on Dec 31, 2008
localwonder
  • 6784 Answers
SOURCE: control panel on my fridge
Pull the power cord for 5 minute to reset the control board. if this control panel malfunction still exist after the reset, replace the control circuit board.
This is a typical control fault that should be corrected by pulling power for 5 minutes. if not, this reset will confirm major damaged to the circuit board.
Posted on May 25, 2009
SOURCE: stamina/speed switch
This IS very likely a hardware problem. I'm not very sure about your model but I know that many SZ users w/ G84xx/G86xx NVIDIA card out there are having similar problem -- could be due to NVIDIA chip failure.
http://www.theinquirer.net/gb/inquirer/news/2008/07/09/nvidia-g84-g86-bad
Sony had just acknowledged this problem (failed G84/G86 NVIDIA chips) recently but unfortunately SZ series models were not included in the list.
http://www.theinquirer.net/inquirer/news/1528907/sony-admits-failing-nvidia-chips-months-late
In case you're using SZ model and are having G84/G86 nvidia card, just give sony service center a call, at least to let them take your issue into their record.
Posted on Aug 19, 2009
  • 18 Answers
SOURCE: Sony Vaio STAMINA/SPEED switch not working correctly
What OS are you running? Have you tried to upgrade drivers of you machine? Also you should try any firmware upgrade before you use the warranty.
Posted on Aug 31, 2009
Testimonial: "Thanks for the info. The STAMINA/SPEED switch is now working and it doesn't restart when I close the lid. I just used the recovery disc's drivers."
Trojan stamina 310, showing error 7. What could it be?
Please calibrate the Main motor, has exceeded set limit range.
Test the controller board motor.
LED Blink Patterns on the Control Board Treadmill
Blessing
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Nov 26, 2017 | Exercise & Fitness
How can auto settings on canon elph 310 be overridden for flash fill.
In Auto mode the camera decides whether it needs flash or not. To have control over the flash you need to switch to one of the semiautomatic modes or the manual mode.
Oct 05, 2016 | Canon Cameras
Stamina/Speed Switch In Windows 7
Page 104 of the manual says you must reboot between switch changes to install the change.
The manual is here
https://docs.sony.com/release/VGNSZ400_UG_US_F.pdf
Nov 28, 2012 | Sony VAIO VGN-SZ440 Notebook
I have a Zoom H4N and i am unable to select different modes on my recorder. There is actually no 'mode' available in my menu. How do i fix this? It is brand new out of the box.
If your H4n is in STAMINA mode (Switch in battery compartment) then MODE is not viewable in the MENU. Simply Turn off the STAMINA Switch and restart your H4n (Turn H4n OFF then ON again)
Hope that Helps
Cheers
Jaysan
Nov 19, 2010 | Zoom H4 Handy Recorder
I need a manual on my stamina r360 recumbent bike how to clear the settings on the in touch monitor
If this is the same Stamina R360 as I have, you just hold down the orange oval button (labeled: MODE) until you hear a beep. This resets the readings.
Feb 28, 2009 | Stamina Products Stamina Pro 5300 Silent...
Stamina/speed switch
Oct 01, 2008 | Sony VAIO VGN-SZ480 Notebook
Sep 30, 2008 | Computers & Internet
There is trojan horse virus in my laptop. i ve a symantec norton 2004 antivirus. everytime i update my antivirus, there's some process happening n it comes again unable to hell the virus.... it got...
you need to press F8 while the pc is booting for a startup in safe mode, then when in safe mode select start windows in safe mode, go to my computer, properties>system restore tab and turn off system restore and then run the scan again as these trojans cannot be deleted when the pc is in normal use.
If your antivirus finds them but cannot heal, make a note of the file that has the trojan and then search for the file and delete it manually.
Ensure after the trojans are deleted that you tuirn system restore back on
Oct 21, 2007 | Computers & Internet
Exercise & Fitness Logo
44 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
