Question about Culligan Tools & Hardware - Others
Where do i found culligan part 01016328 seal kit
2 Suggested Answers
h2oservices
  • 306 Answers
SOURCE: Need a seal kit for a Culligan Mark 89
Your local Culligan dealer is the only place to get one. You need the retrofit kit to prevent the shaft of sealpack from bending.
RJ
Posted on Mar 15, 2012
My culligan mark 100 soft -minder water softner salt tank overfills
First check the eductor assembly. Top of valve under chrome plate. Pull it out and clean it (after bypassing and depressurizing the system)
If that is OK the the brine piston will need to be replaced. There is a rebuild kit for this series valve that is about $120 that includes the refill piston and a retrofit kit. It would be wise to rebuild the valve.
See your local culligan dealer
RJH2O
Nov 23, 2012 | Culligan Sediment Water Filter Heavy Duty
RJ
Mar 10, 2012 | Measuring Tools & Sensors
Our system is only running small amount of water through to the drain... system operating panel just says C5! Even after unpluging and repluging it doesn't change. Does the system need repair?
If it is running small amounts of water to the drain when it is in service position this means you have a bad seal pack and it needs to be replaced. The "sealpack" is the main piston and seals that control the hydraulics of the valve. When water runs to the drain constantly either the piston is jammed (which would show an error code) or there is a bad seal causing water to get by. I suggest calling Culligan or if you are handy you can do this yourself. You need a sealpack and refill piston. It takes about 20 minutes. The kit is available from Culligan.
RJ
Jan 30, 2011 | Culligan Sediment Water Filter
Piston seal pack mark 89
There is a retrofit kit to replace this that prevents the piston from binding and freezing up. It is available at Culligan.
RJ
Dec 10, 2010 | Culligan Sediment Water Filter Heavy Duty
Getting discharge water at all times
The valve is stuck in regeneration. If a Culligan unit the main piston / sealpack is jammed and may need to be replaced. Bypass the unit to stop discharge. You can get a retrofit kit from Culligan that is designed to repair this issue.
RJ
May 17, 2010 | Culligan Sediment Water Filter Heavy Duty
My culligan water softner just keeps running .
It is most likely running to drain. This is an indication that the seal pack is seized up, generally from a bent piston. You need to by-pass the softener and call Culligan for service. If you are handy there is a retro-fit kit available from Culligan to remedy this problem. It takes about 1/2 hr to install.
RJ
Jan 31, 2010 | Culligan Under Sink Water Filter
Culligan medalist softener: Water continues to run thru drain line even after regeneration ends. What to do?
Its a most common problem with culligan seal pacs. If your softener is under 5 years old you have the worst softener on the market. Culligan was bought out about 5 years ago by a canada group. they changed every thing and nothing is made in the usa any more. You will have to buy a new one from culligan and pay over 90.00 for it. The old seal pacs lasted 15 years or more now your lucky if you get 2 years.
Nov 18, 2009 | Dryers
Constant flow from my culligan soft minder twin water softner
A constant drip to drain or brine refill indicates a problem with the seals in the valve. You need to determine which tank is leaking. The piston and seals need to be replaced.
RJ
Oct 02, 2009 | Culligan Sediment Water Filter
I have a Culligan water softener and noticed recently that there is a running water sound coming from the drain tube. There is no leaking, and the sound is almost like a constant trickle. It stops if we...
There is a problem with the piston/seal pack assembly pack in the valve. The seals get worn or some debris gets stuck and causes softener to run to the drain. The seal pack assembly needs to be replaced. If you are handy, you can do this. It takes about 1/2 hour for a novice.
Parts are only available from Culligan.
RJ
Jul 12, 2009 | Culligan Sediment Water Filter
Tools & Hardware - Others Logo
37 people viewed this question
Top Culligan Tools & Hardware - Others Experts
Jim London
Jim London
Bill Boyd
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
